DD TC44A DAC CS43131 Male Lightning to Female Jack 4.4mm 32bit 384kHz DSD256
This TC44A DD adapter for smartphone is composed of a male Lightning connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal for a clear and precise reproduction.
Reference : 15929
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 28-04-2026.
DD TC44A
Adapter DAC CS43131 Male Lightning to Female Jack 4.4mm 32bit 384kHz DSD256
DD TC44A Adaptateur DAC CS43131 Lightning Mâle vers Jack 4.4mm Femelle 32bit 384kHz DSD256
This TC44A DD adapter for smartphone is composed of a male Lightning connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal for a clear and precise reproduction, while supporting high resolution streams, up to PCM 32bit 384kHz and DSD256. The robust connector body is made of CNC machined aluminum. Its practical "T" shape allows for a compact design.
Product typeAdapter and DAC
Connectors1x Male Lightning
1x Female Jack 4.4mm
DAC ChipCS43131
DSD up to DSD256
Output power60mW @ 32Ω
Dynamic range> 120dB
THD+N< -110dB
SNR> 120dB
Dimensions19.5 x 21 x 12mm
Weight5.5g
InputLightning
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
ColorBlue
Portable and high quality
Connects easily with my iPhone and with my 4.4mm balanced earphones. Decent sound quality
This review has been posted for DD TC44A DAC CS43131 Male Lightning to Female Jack 4.4mm 32bit 384kHz DSD256
This TC44A DD adapter for smartphone is composed of a male Lightning connector and a female 4.4mm jack. It also includes a CS43131 DAC for...
