FIIO Q11 Portable DAC Headphone Amplifier CS43198 Balanced 32bit 384kHz DSD256
The ideal companion for any smartphone without headphone output, the FiiO Q11 is a high-performance, stylish and affordable portable DAC and headphone amplifier combo. It allows you to enjoy a quality listening experience at home or on the go, to make the most of your music.
Reference : 17309
99,00 €tax incl.
82,50 € tax excl.
FiiO Q11
FiiO Q11 DAC Amplificateur Casque Portable CS43198 Symétrique 32bit 384kHz DSD256
CS43198 DAC
The Q11's digital-to-analog conversion stage uses a high-performance CS43198 DAC chip to ensure efficient decoding of the audio stream and thus provide accurate and faithful sound reproduction. This chip also supports high resolution formats, up to 32bit 384kHz PCM and DSD256.
Comfortable power
The amplifier section of the FiiO Q11 provides a comfortable power output of up to 650mW on its balanced output. It can therefore be combined with high impedance headphones as well as with high sensitivity headphones.
Q11Q1 Mark II
Single-ended output power≥ 310mW @ 16Ω, THD+N < 1%, USB input≥ 112mW @ 16Ω, THD+N < 1%, AUX input
≥ 165mW @ 32Ω, THD+N < 1%, USB input≥ 75mW @ 32Ω, THD+N < 1%, AUX input
≥ 19mW @ 300Ω, THD+N < 1%, USB input≥ 11mW @ 300Ω, THD+N < 1%, AUX input
Balanced output power≥ 640mW @ 16Ω, THD+N < 1%, USB input≥ 240mW @ 16Ω, THD+N < 1%, AUX input
≥ 650mW @ 32Ω, THD+N < 1%, USB input≥ 220mW @ 32Ω, THD+N < 1%, AUX input
≥ 75mW @ 300Ω, THD+N < 1%, USB input≥ 45mW @ 300Ω, THD+N < 1%, AUX input
Volume & Gain
This adaptability of the Q11 to many headphones and earphones is reinforced by a two-level gain control, which can be changed at any time depending on the equipment used. A knob allows a quick and precise adjustment of the volume level.
Balanced & Single-ended
The FiiO Q11 has two outputs, the first one in single-ended Jack 3.5mm format and the second one in balanced Jack 4.4mm format, always with a view to versatility and adaptability. The Jack 3.5mm output can also be used as a coaxial output.
More than 13 hours of battery life
With its 2600mAh battery, the FiiO Q11 can reach an autonomy of more than 13h. It can thus accompany you on the move for a listening throughout the day.
LED Indicator
The small open window on the FiiO Q11's circuitry also features an LED indicator, changing color depending on the sample rate of the file being played. The Q11 can also be controlled by the free FiiO Control mobile application, allowing to activate or deactivate the LED indicator but also to access options such as audio filters.
  • Bluu: PCM 48kHz and below
  • Yellow: PCM above 48kHz
  • Green: DSD
Product typePortable DAC and headphone amplifier
Input1* USB-C
Outputs1* Single-ended Jack 3.5mm
1* Balanced Jack 4.4mm
DAC chipCS43198
Native DSD up to DSD256
Output powerSingle-ended: 165mW à 32Ω
Balanced: 650mW @ 32Ω
Battery2600mAh
Battery life> 13h
SNRSingle-ended: ≥ 122dB @ 32Ω, A-weighted
Balanced: ≥ 125dB @ 32Ω, A-weighted
Noise floorSingle-ended: < 1.8µV (A-weighted)
Balanced: < 2.4µV (A-weighted)
Output impedanceSingle-ended: < 1.2Ω @ charge 32Ω
Balanced: < 2.0Ω @ charge 32Ω
THD+NSingle-ended: < 0.0006% @ 1kHz, 32Ω
Balanced: < 0.0006% @ 1kHz, 32Ω
Dimensions60.5*105.7*16mm
Weight150g
Package1* FiiO Q11
1* USB-A to USB-C cable
1* USB-C to USB-C OTG cable
1* USB-C to Lightning OTG cable
1* Silicon strap
1* Silicon pad
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate384kHz
Max sampling rateDSD256
The ideal companion for any smartphone without headphone output, the FiiO Q11 is a high-performance, stylish and affordable portable DAC and...
