FIIO SNOWSKY TINY B DAC Portable Headphone Amplifier Black
The FiiO SNOWSKY Tiny B is a small, portable, and convenient USB DAC and headphone amplifier USB portable that allows you to listen to music simultaneously on two pairs of headphones. Its DAC chip SpaceTouch SPV4040 supports signals up to PCM 32bit 384kHz and DSD256.
Reference : 21563
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 12-05-2026.
FiiO SNOWSKY TINY B DAC Portable Headphone Amplifier 3.5mm / 4.4mm Jack 32bit 384kHz DSD256 Black
FiiO Tiny B
The Tiny B has a USB-C input and either an single-ended 3.5mm jack or a balanced 4.4mm jack for audio output. In addition, the Tiny B is compatible with the FiiO Control app, which includes a 10-band parametric equalizer.
The headphone amplifier stage of the FiiO SNOWSKY Tiny B delivers 68mW of power at 16Ω and 34mW at 32Ω on its single-ended 3.5mm jack output, while the balanced 4.4mm jack output delivers 45mW at 16Ω and 34mW at 32Ω. The Tiny B is equipped with an LED sampling rate indicator and supports UAC2.0 and 1.0 protocols, making it easy to use with a wide variety of devices.
Conveniently, the TINY B also supports headphone/earphone cables with remote controls, allowing for simplified control of your media, volume, or calls. The whole unit is encased in an elegant metal shell that is both sturdy and lightweight.
FiiO Tiny B: Characteristics
FiiO SNOWSKY Tiny B: Additional features with the FiiO Control app
The FiiO Control app, available for Android and iOS devices or via a web browser on a PC, provides access to additional customization features. These include access to a parametric equalizer (PEQ), the ability to change the UAC protocol version, and precise volume adjustments.
FiiO Tiny B: FiiO Control App
Product typePortable DAC and headphone amplifier
Input1x USB-C
Output1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
Supported sampling ratesPMC up to 32bit 384kHz
DSD up to DSD256
Control appFiiO Control
CompatibilityAndroid
iOS
Windows
Mac
UAC supportUAC 1.0
UAC 2.0
Single-ended Jack 3.5mm headphone output performances
Output power≥ 68mW @ 16Ω, THD+N < 1%
≥ 34mW @ 32Ω, THD+N < 1%
THD+N0.0034%
Output impedance< 0.5Ω
SNR≥ 105dB (A-wt)
Balanced Jack 4.4mm headphone output performances
Output power≥ 45mW @ 16Ω, THD+N < 1%
THD+N0.01%
Output impedance< 0.2Ω
SNR≥ 100dB (A-wt)
Dimensions35 x 24 x 10.8mm
Weight~ 10g
ColorNoir
Package1x FiiO SNOWSKY Tiny B
OutputJack 4.4mm
OutputJack 3.5mm
Max sampling rateDSD256
Max sampling rate384kHz
ClassN/A
FIIO SNOWSKY TINY B Portable DAC Headphone Amplifier Jack 3.5 / 4.4mm 32bit 384kHz DSD256 Black
The FiiO SNOWSKY Tiny B is a small, portable, and convenient USB DAC and headphone amplifier USB portable that allows you to listen to...
