FOSI AUDIO DS3 Headphone Amplifier Portable DAC Black
With the DS3, Fosi Audio presents a compact DAC and headphone amplifier featuring an ESS ES9039Q2M chip and an XMOS interface, supporting signals up to PCM 32-bit/768 kHz and DSD512. It also offers a virtual 7.1 mode that improves spatialisation, which is particularly useful for gaming. Finally, its CNC-machined aluminium chassis with tempered glass window not only looks great, but also guarantees rock-solid robustness.
Reference : 21324
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 18-11-2026.
Fosi Audio DS3 Headphone Amplifier Portable DAC ES9039Q2M 32bit 768kHz DSD512 Black
Fosi Audio DS3 : Front view
With the DS3, Fosi Audio presents a compact DAC and headphone amplifier featuring an ESS ES9039Q2M chip and an XMOS interface, supporting signals up to PCM 32bit 768kHz and DSD512. It also offers a virtual 7.1 mode that improves spatialisation, which is particularly useful for gaming. Finally, its CNC-machined aluminium chassis with tempered glass window not only looks great, but also guarantees rock-solid robustness.
Fosi Audio DS3: ESS DAC chip and XMOS interface
The DS3 features a high-end ESS ES9039Q2M DAC chip coupled with an optimised XMOS USB interface. This architecture allows native playback of high-resolution files up to 32bit 768kHz PCM, as well as DSD512, enabling faithful and detailed reproduction of your favourite tracks.
Fosi Audio DS3 : ESS DAC
Fosi Audio DS3 : 7.1 spatialisation
Fosi Audio DS3: 7.1 spatialisation
The DS3 incorporates a 7.1 virtual spatialisation algorithm, transforming a conventional stereo signal into an expanded soundstage. This improves the localisation of sound sources, which is particularly relevant for gaming sessions or for greater immersion in films and video games.
Fosi Audio DS3: As classy as it is durable
The DS3 features a CNC-machined aluminium chassis for increased rigidity and heat dissipation, complemented by a tempered glass window that reveals the internal circuit board. This combination offers a sleek and refined look while providing exceptional strength and durability.
Fosi Audio DS3 :toughened glass window
Fosi Audio DS3 on black background
Fosi Audio DS3: Volume control
In addition to offering physical volume control, the DS3 conveniently remembers the last volume level used. This means you don't have to readjust the volume every time you boot up or start a new session, ensuring the smoothest possible user experience.
FOSI DS3 Review by Audio Science Review
"The DS3 is an overachiever, combing almost perfect measurements with superb functionality. There is some kind of glitch in balanced out but otherwise, the performance and functionality plus good looks easily justifies its cost and then some.
I am happy to recommend the Fosi DS3. Engineering excellence squeezed into tiny enclosure that weighs almost nothing."
Product typePortable headphone amplifier and DAC
DAC chipESS ES9039Q2M
USB interfaceXMOS
InputUSB-C
OutputsSingle-ended Jack 3.5mm
Balanced Jack 4.4mm
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Output power220mW @ 32Ω
Output levelJack 3.5mm : 2Vrms
Jack 4.4mm : 4Vrms
Volume control
Package1x Fosi Audio DS3
1x USB-C to USB-C cable
1x USB-A to USB-C adapter
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9039Q2M
Max sampling rateDSD512
Max sampling rate768kHz
ClassN/A
FOSI AUDIO DS3 Headphone Amplifier Portable DAC ES9039Q2M 32bit 768kHz DSD512 Black
With the DS3, Fosi Audio presents a compact DAC and headphone amplifier featuring an ESS ES9039Q2M chip and an XMOS interface, supporting signals...
