HIDIZS DH80 Portable Balanced Amplifier DAC ES9281C Pro MQA 384kHz DSD128
The Hidizs DH80 is a portable DAC and amplifier combo, in the form of a dock, allowing to connect a DAP such as the Hidizs AP80 but also a smartphone, a tablet, a computer or headphones. Versatile and practical, it is also extremely powerful, benefiting from a balanced circuit based on high-end components.
Reference : 15256
115,00 €tax incl.
95,83 € tax excl.
Hidizs DH80
Hidizs DH80 Amplificateur DAC Symétrique Portable ES9281C Pro MQA DSD128
MQA Support
The DH80 supports and decodes MQA (Master Quality Authenticated) files for studio-like sound reproduction. To indicate that it is playing an MQA file, the DH80's LED lights up purple.
DAC ESS ES9281C Pro + Dual AOP RT6863C
The DH80's digital-to-analog conversion stage is based on an ESS ES9281C Pro chip, ensuring wide dynamic range, low power consumption, very low distortion, near-zero noise and support for MQA or DSD128.
Two RT6863C AOPs support voltages of 4Vrms for the 4.4mm balanced jack output and 2Vrms for the 3.5mm unbalanced jack output.
3 Gain level & High power output
The DH80 features 3 gain levels (High, Medium, Low) for extended compatibility with all types of headphones. The balanced 4.4mm jack output allows to feed headphones with an impedance of 150Ω with a power of 2x 210mW @ 32Ω. The 30-step volume control allows precise adjustment of the sound level.
High quality components
With two clocks, 4 Panasonic capacitors and two RT6863Cn AOPs the DH80 offers beautiful dynamics and excellent channel separation. An integrated 1300mAh battery allows to deliver a more natural and clear sound, without using the battery of your smartphone.
Sampling rate display
An LED indicator shows in a simple way the sampling rate of the file being played: Red for 44.1-48kHz, blue for 88.2-384kHz and pink for MQA.
Product typeAmplifier and portable DAC
DAC ChipESS ES9281C Pro
Outputs1x Balanced Jack 4.4mm
1x Single-ended Jack 3.5mm
Supported sampling ratesPCM up to 32bit 384kHz, DSD up to DSD128, MQA
Gain levelsLow
Medium
High
OPA2x RT6863C
Power connectorUSB-C
Battery1300mAh 3.7V Li-Polymer
Charge timeAbout 2.5h
AutonomyBalanced : About 6h
Single-ended : About 8h
Supported OSWindows 10
Mac OS
iPad OS
Android
iOS
Max powerSingle-ended: 2x 125mW @ 32Ω
Balanced: 2x 210mW @ 32Ω
Frequency responseSingle-ended: 20Hz-80kHz (±0.6dB) @ 32Ω
Balanced: 20Hz-80kHz (±0.6dB) @ 32Ω
THD+NSingle-ended: 0.0006% @ 32Ω
Balanced: 0.0004% @ 32Ω
SNRSingle-ended: 116dB @ 32Ω
Balanced: 116dB @ 32Ω
CrosstalkSingle-ended: 79dB @ 32Ω
Balanced: 108dB @ 32Ω
Housing materialAluminum
Dimensions70 x 50 x 12mm
Weight82.3g
Package1x Hidizs DH80
1x USB-C Cable
1x USB-A converter
1x Female USB-C to male USB-C cable
OutputJack 3.5mm
OutputJack 4.4mm
The Hidizs DH80 is a portable DAC and amplifier combo, in the form of a dock, allowing to connect a DAP such as the Hidizs AP80 but also a...
