The Go Link 2 from iFi Audio is a portable DAC adapter that is ideal for connecting headphones or earphones to a device that does not have a 3.5mm headphone jack, such as a recent smartphone. It also allows devices with a headphone jack to enjoy better sound thanks to the built-in high-quality DAC and headphone amplifier.
Its ESS Sabre ES9219 DAC chip delivers high-quality sound by supporting signals up to PCM 32bit 384 kHz and DSD256. Its amplifier stage delivers 79mW of power at 32Ω and 14mW at 300Ω.
The iFi Audio Go Link 2 consists of a male USB-C input on one end and an S-Balanced 3.5mm headphone output on the other. Proprietary S-Balanced technology applies the principles of a balanced circuit to a single-ended headphone output, reducing crosstalk for improved audio quality.
A flexible cable connects the input and output, making it convenient to use while reducing mechanical stress on the connectors and connected devices. In addition, it features individually insulated silver-plated copper conductors, ensuring excellent conductivity for perfect signal transmission.
The Go Link 2 is an improvement on the original Go Link model with significant enhancements. It is lighter, with a 29% reduction in weight, and more efficient, with a 63% reduction in harmonic distortion.
The Go Link 2 is the first in the Go Link range to be compatible with the iFi Nexis app. The app allows you to update the firmware instantly and wirelessly as an option*. In addition, the ability to apply two digital filters (hybrid or linear) allows you to customize the sound to suit your needs.
*Only available for Android devices.
Technical specifications
| Specifications | |
| Product type | Portable DAC |
| Input | 1x USB-C |
| Output | 1x Jack 3.5mm S-Balanced |
| DAC chip | ESS ES9219 |
| Supported sampling rates | PMC up to 32bit 384kHz DSD up to DSD256 |
| Control application | iFi Nexis |
| Compatibility | Android iOS |
| Output Power | ≥ 1.59V / 79mW @ 32Ω ≥ 2V / 14mW @ 300Ω |
| Output impedance | < 0.4Ω |
| SNR | ≥ 125dBA (2.05V) |
| THD+N | ≤ 0.0015% (1.27V @ 32Ω) |
| Frequency response | 10Hz-80kHz (-0.5dB) |
| General | |
| Consumption | No signal: ~0.2W Max signal: ~1W |
| Dimensions (L*P*H) | 137x12x7.6mm |
| Weight | 7.8g |
| Input | USB |
| Output | Jack 3.5mm |
| DAC / ADC Chip | ES9219C |
| Max sampling rate | 384kHz |
| Max sampling rate | DSD256 |
| Color | Black |
| Networking | No |
| Remote Control | Control app |
