QUESTYLE CMA 18P Portable DAC Headphone Amplifier
The Questyle CMA 18P is a compact, high-performance headphone DAC/amplifier featuring a high-performance AKM AK4493 DAC chip and a XMOS XU316 USB interface, mostly used in sedentary DACs. This chipset enables the CMA 18P to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512.
Reference : 19564
699,00 €tax incl.
582,50 € tax excl.
Questyle CMA 18P Portable DAC Headphone Amplifier AK4493 XMOS XU316 Bluetooth aptX HD 32bit 768kHz DSD512
QUESTYLE CMA 18P picture
The Questyle CMA 18P is a compact, high-performance portable DAC/headphone amplifier featuring a high-performance AKM AK4493 DAC chip and a XMOS XU316 USB interface, mostly used in sedentary DACs. These chipsets enables the CMA 18P to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. The brand's proprietary CMA amplification technology with SIP CC630/CA630 chips (current-mode amplification) also provides the CMA 18P with considerable output power, up to 5W / 2A peak. A Bluetooth receiver chip also enables it to support high-definition Bluetooth codecs: aptX, aptX HD and LDAC. In terms of interface, the Questyle CMA 18P boasts extensive connectivity with USB-C input, mini-Toslink/jack 3.5mm cmbo and balanced jack 4.4mm inputs, as well as analog jack 3.5/4.4mm outputs and USB ADC output. The whole unit is powered by a 4500mAh battery offering over 10h of autonomy. Coupled with a smartphone, tablet or computer, this little DAC/headphone amplifier is an ideal ally for enjoying your music library or streaming services.
Questyle CMA 18P: AK4493 DAC and XMOS XU316 USB interface
The AKM AK4493 2-channel 32-bit DAC featuring Velvet Sound technology, coupled with a third-generation XMOS XU316 USB interface, supports sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. This combination of chips is usually found in sedentary devices, making the Questyle CMA 18P an ultra-high-performance portable headphone amplifier DAC thanks to its high-end components.
Questyle CMA 18P: ADC function
As well as being an efficient DAC, the Questyle CMA 18P can convert an analog signal into a digital one. This feature allows you to rip vinyl records, audiocassettes or your favorite radio programs, for example.
QUESTYLE CMA 18P ADC function
Photo of QUESTYLE CMA 18P with headphones
Questyle CMA 18P: CMA amplification with CC630/CA630 SIP chips
The Questyle CMA 18P features a current-mode amplification (CMA) circuit with SIP CC630/CA630 chips, enabling it to develop considerable power up to 5W / 2A peak. With 1W of power @ 32 ohm on its balanced output, it can drive many of the headphones and IEMs available on the market.
Questyle CMA 18P: Bluetooth reception
Thanks to its Bluetooth functionality, the Questyle CMA 18P supports reception of high-definition Bluetooth codecs: SBC, AAC, aptX, aptX HD and LDAC. It can therefore guarantee high-quality wireless transmission via a smartphone, for example.
QUESTYLE battery
Questyle CMA 18P: a high-performance battery
A 4500mAh lithium battery working in conjunction with a powerful power management system enables it to be recharged in 3.5h for an autonomy of over 10h. This power management system prevents overheating and preserves battery life through complete optimization.
Questyle CMA 18P: LED system operation
QUESTYLE CMA 18P LED diagram
  • Status indicator - indicates operating mode:
    • REC: LED lights up orange when the recording function is activated
    • GAIN: LED lit orange for standard gain, red for high gain
    • DATA: LED lit orange for standard sampling rate, lit red for HD sampling rate
  • Source indicator - indicates the source used:
    • Off when charging
    • Source LED lights up orange when in use
    • For Bluetooth: LED flashes slowly to indicate no connection, rapidly to indicate pairing in progress, steady to indicate Bluetooth connected
  • Battery / volume indicator - indicates battery charge status and sound level
  • USB Connection Indicator - lights up orange when the CMA 18P is powered via USB
  • iP chips - amplifier modules :
    • 2 LEDs light up when unbalanced output is used
    • 4 LEDs light up when balanced output is used
Questyle CMA 18P: a portable, sedentary DAC
Thanks to the Questyle CMA 18P's analog line-level inputs and outputs, it can be completely inserted between a streamer and the rest of your Hi-Fi system, transforming it into a sedentary DAC. This is made possible by using RCA to 3.5mm stereo jack or XLR to 4.4mm balanced stereo jack modulation cables. It can also be used as a Bluetooth receiver at the beginning of your Hi-Fi system, for quick and easy access to streaming services.
Questyle CMA 18P overvierw
QUESTYLE CMA 18P overview
1ON/OFF button
2Volume control
3Source selection
4Gain adjustment
5NC
6Balanced 4.4mm stereo jack input
7Mini-Toslink/Jack 3.5mm input
8USB-C input/charging port
9Jack 3.5mm output
10Balanced 4.4mm jack output
Product typeDAC / headphone amplifier
DAC chipAKM AK4493
AmplificationCurrent-mode amplification with CC630/CA630 SIP chips
Inputs1x USB-C
1x Balanced 4.4mm stereo jack
1x 3.5mm/Toslink jack
Outputs1x 4.4mm stereo balanced jack (headphones and line)
1x 3.5mm stereo jack (headphones and line)
Supported sample ratesUSB : PCM 32bit 768kHz, DSD DoP256, DSD512
Optical Mini- Toslink (3.5mm jack) : PCM 24bit 192kHz
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Max. output power1W @ 32 ohms (Balanced output)
THD+N0.0003%
SNR> 120dB
CompatibilityMFI certification for IOS, Harmony OS, Android 5.1 and +
Windows 10 version 18.3 and + (without driver)
MAC OS
BatteryLithium 4500mAh
Charging time3.5h
Autonomy>10h
Dimensions110 x 70 x 10mm
Package1x Questyle CMA 18P
1x USB-C to USB-C cable
1x Lightning to USB-C cable
1x USB-C to USB-A adapter
1x Toslink to 3.5mm optical jack adapter
1x USB-C to USB-C charging cable
InputJack 3.5mm
InputOptical Mini-Toslink
InputJack 4.4mm
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipAK4493
Max sampling rateDSD512
Max sampling rate768kHz
ClassN/A
QUESTYLE CMA 18P Portable DAC Headphone Amplifier AK4493 XMOS XU316 Bluetooth aptX HD 32bit 768kHz DSD512
The Questyle CMA 18P is a compact, high-performance headphone DAC/amplifier featuring a high-performance AKM AK4493 DAC chip and a XMOS XU316 USB...
