QUESTYLE M15C Portable DAC Headphone Amplifier
New
The Questyle M15C DAC headphone amplifier is a high-end-looking device based on audiophile components. It is based on a CS43198 DAC chip and its proprietary “Current Mode Amplification”.
Reference : 20765
129,00 €tax incl.
107,50 € tax excl.
Questyle M15C Portable DAC Headphone Amplifier CS43198 32bit 384kHz DSD256
QUESTYLE M15C picture
The Questyle M15C DAC headphone amplifier is a high-end-looking device based on audiophile components. It is based on a CS43198 DAC chip and its proprietary “Current Mode Amplification”. This little device is therefore able to support high-resolution sampling rates up to PCM 32bit 384kHz and DSD256, while delivering up to 42.79mW of output power under a 300 ohm load. Added to this is MFI certification ensuring full compatibility with the iOS environment. Signal input is via USB-C, and two headphone outputs are available: 3.5mm jack and balanced 4.4mm jack. The M15C is ideal for enjoying high-resolution sources stored locally or via streaming applications on the move.
Questyle M15C overview
QUESTYLE M15C overview
1Status LED
2CS43198 DAC chip
3SIP current amplifier module
4Single-ended 3.5mm jack output
5Balanced 4.4mm jack output
6TOREX power management module
7Gain adjustment
8SA9312L USB controller
9USB-C input (Asynchronous, triple clock)
Product typeDAC Headphone amplifier
DAC chipCirrus Logic CS43198
USB interfaceSA9312L
Input1x USB-C
Outputs1x 3.5mm jack headphone output
1x Balanced 4.4mm jack headphone output
Output power3.5mm jack single-ended: 10.72mW @ 300 ohm (THD+N = 0.0003%)
4.4mm jack balanced jack: 42.79mW @ 300 ohm (THD+N = 0.0003%)
Frequency response±0.1dB(20Hz - 20kHz)
±1dB(20Hz - 80kHz)
THD+N0.00028%
Kunlun glass window
Power supplyVia USB-C
Dimensions62 x 28 x 12mm
Package1x Questyle M15C
1x USB-C to USB-C cable
1x USB-C to USB-A adapter
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
ClassN/A
QUESTYLE M15C Portable DAC Headphone Amplifier CS43198 32bit 384kHz DSD256
The Questyle M15C DAC headphone amplifier is a high-end-looking device based on audiophile components. It is based on a CS43198 DAC chip and its...
