SHANLING ONIX ALPHA XI1 Portable Balanced DAC Headphone Amplifier
Shanling unveils its Onix Alpha XI1, a balanced portable DAC featuring high-quality components. It incorporates 2 CS43198 DAC chips, enabling it to support high-resolution sampling rates up to PCM 32bit 384kHz and native DSD up to DSD256 via its USB input.
Reference : 19347
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 08-08-2025.
SHANLING ONIX Alpha XI1 Portable Balanced DAC USB-C 2xCS43198 Headphone Amplifier SGM8262 32bit 384kHz DSD256
Shanling Onix Alpha picture
Shanling unveils its Onix Alpha XI1, a balanced portable DAC featuring high-quality components. It incorporates two CS43198 DAC chips, enabling it to support high-resolution sampling rates up to PCM 32bit 384kHz and native DSD up to DSD256 via its USB input. It also features two SGM8262 headphone amplifiers for a substantial power reserve, enabling it to drive a large number of IEMs and headphones available on the market. In fact, it offers output power of up to 180mW on its 3.5mm jack output, and up to 500mW at 32 ohms on its balanced 4.4mm jack output. Simple to use, 3 buttons provide access to main controls such as volume control and play/pause function. Added to this is a small 0.87-inch display with a pleasant interface for simplified navigation and display of essential information.
SHANLING ONIX Alpha XI1: balanced portable DAC
The two Cirrus Logic CS43198 DAC chips in the Shanling Onix Alpha XI1 portable DAC enable it to support 32bit 384kHz PCM streams, as well as native DSD up to DSD256 via its USB-C input. The two DAC chips work in balanced mode for clear, precise sound reproduction.
Photo of a CS43198 DAC chip
Shanling Onix Alpha XI1 picture
SHANLING ONIX Alpha XI1: a high-performance headphone amplifier
Two SGM8262 operational amplifiers take care of the headphone amplification. These low-noise, low-distortion operational amplifiers provide adequate output power for the Onix Alpha XI1 portable DAC, with up to 180mW on its 3.5mm jack output and up to 500mW at 32 ohms on its balanced 4.4mm jack output. This enables it to drive a wide range of headphones and earphones. The 0.4/0.8 ohm output impedance of the Onix Alpha XI1 contributes to its high level of compatibility.
SHANLING ONIX Alpha XI1: Eddict player app
The Eddict Player application lets you easily control the Onix Alpha XI1. It offers the possibility of adjusting the sound rendering thanks to 5 filters.
Eddict player app
SHANLING ONIX Alpha XI1: a simplified interface
Despite its compact form factor, the Onix Alpha XI1 portable DAC features a small 0.87-inch screen for easy navigation and display of essential information. This is complemented by 3 buttons for volume control and play/pause.
Shanling Onix Alpha XI1 screen picture
Product typePortable DAC
Portable Headphone Amplifier
DAC chip2x CS43198
Headphone amplification2x SGM8262
InputsUSB-C
Outputs1x Single-ended 3.5mm jack
1x Balanced 4.4mm jack
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD256
Output power3.5mm jack: 180mW
4.4mm jack: 500mW
Display0.84"
Single-ended 3.5mm jack output
THD+N0.0004% @ 32Ω (A-weighted @ 2V)
Dynamic range125dB @ 32Ω (A-weighted)
Channel separation71dB @ 32Ω
SNR126dB @ 32Ω
Output impedance0.4Ω
Balanced 4.4mm jack output
THD+N0.0005% @ 32Ω (A-weighted @ 2V)
Dynamic range129dB @ 32Ω
Channel separation99dB @ 32Ω
SNR129dB @ 32Ω
Output impedance0.8Ω
Dimensions64 x 32 x 14mm
Weight37.8g
Package1x Shanling Onix Alpha XI1 Portable DAC
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate384kHz
Max sampling rateDSD256
ClassN/A
4 reviews
très bel étui, très bonne qualité
très bel étui, très bonne qualité, conforme à la description et convient à merveille au Dac ONIX ALPHA XI1 DAC
This review has been posted for SHANLING ONIX ALPHA XI1 Portable Balanced DAC USB-C 2xCS43198 Headphone Amplifier SGM8262 32bit 384kHz DSD256
Parfait sous Linux
Fonctionne tres bien sous Linux : reconnu sans probleme, et presente ses volumes a ALSA (alsamixer).
Le son est vraiment bien aussi :D
Xl1
Livraison rapide,
le DAC fonctionne tres bien !
Excellent dongle
Un dongle bien fabriqué, avec un écran lisible et personnalisable proposant les fonctions paramétrables comme les filtres qui ont ici un impact sur le son. Une application, facile d'utilisation, permettra de faire tout ça directement sur le téléphone par exemple. Pour ce qui est du son, il n'y a aucune emphase dans les hauts médiums et aigus donc il n'y aura d'agressivité avec des intras brillants. La présentation est plutôt spacieuse avec une belle largeur de scène, des médiums avec beaucoup de détails. Le son est réaliste avec une bonne sensation d'immersion. En comparaison de mes autres dongles plus chers, celui-ci est vraiment au niveau! D'ailleurs les amplis embarqués sont de qualité. Ce qui en fait un excellent rapport prix prestations. Pour finir, la finition est bonne, cela semble solide et durable. Très satisfait
Shanling unveils its Onix Alpha XI1, a balanced portable DAC featuring high-quality components. It incorporates 2 CS43198 DAC chips, enabling it to...
