Le son est de très haute qualité. Testé sur smartphone Android avec poweramp et neutron.
Vraiment impressionnant.
DAC USB OTG, headphone amplifier
The SMSL iQ is the second generation of mobile SMSL DAC SMSL with USB XMOS208 input. It thus offers a theoretical resolution up to DSD512 or 32bit 384Khz bringing the highest definition on a nomadic set.
Featuring two ES9018Q2C DAC chipset with truly symmetrical high performance headphone amplification, the SMSL iQ benefits from high decoding accuracy supported by two Hy brand clocks with multiple separate frequencies (49.152Mhz and 45.1584mhz) with low noise phase. (jitter). The SMSL iQ thus proposes measurements and distortion figures comparable to sedentary hifi DACs.
The SMSL iQ offers two headphone outputs, a classic 3.5mm jack and a 2.5mm balanced jack output for high quality Hifi headphones. Thanks to its symmetrical topology since the conversion the SMSL iQ allows a listening comparable to its classical Hifi channel.
The SMSL iQ offers the best in a nomadic DAC with ultra-low noise voltage regulators, separate low drift clocks, a 15W413 LAP volume controller renowned for its balance between stereo channels. The figures show this high level construction with a background noise of -125dB and a total harmonic distortion of 0.00033%.
Spécifications | |
THD+N | 0.00033% |
Dynamic ratio | DAC : 125dB |
SNR | 118dB |
Transmission USB | Asynchrone Xmos U208 |
sampling rate / Bitrate | USB : 32bit 768kHz & DSD512 (22.5792MHz) |
Power jack 3.5mm | 55mW 32Ohm / 33mW 64ohm / 21mW 150ohm / 12mW 300ohm |
power jack 2.5 balanced | 91mW 32 Ohm / 78mW 64 Ohm / 53mW 150 Ohm / 32mW 300 Ohm |
Battery charge voltage DC | 5V DC |
entrées / Sorties | |
USB input | 1x 16bit/24bit/32bit/1bit et DSD64/DSD128/DSD256/DSD512 |
2x | |
Headphone Jack 3.5mm | 1x |
Général | |
Dimensions | 95 x 56 x 9mm |
Weight | 200g |
Material | Alluminium CNC |
Color | black |
Package | 1x câble USB-B vers USB-A mâle 1.5m, 1x câble IEC 1.5m, 1x télécommande (nécessite 2 piles AAA non fournies), manuel en anglais |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
David L.
Pierre S.
