Tanchjim's Luna is a compact and efficient portable DAC. Its elegant CNC machined aluminum finish housing a pair of CS43198 DAC chips coupled with quality circuits to convert signals up to PCM 32bit 768kHz and DSD256 while delivering rich, powerful audio quality with impressive dynamic range.
The Luna features an elegantly curved CNC-machined aluminum case. The brand logo is adorned with a reflective surface, completing a design that is both refined and minimalist.
The Luna's digital-analog conversion stage is based on a pair of Cirrus Logic CS43198 DAC chips, enabling it to support an audio stream up to PCM 32bit 768kHz and DSD256, while offering precise, noise-free reproduction with an incredibly low level of harmonic distortion.
The Luna has also benefited from special attention in its circuit design. Each stage of signal processing is supplied with independent voltage, thanks to a low-noise power supply supported by synchronous rectifier technology, ensuring rich, powerful sound with impressive dynamics.
The Luna boasts excellent performance, with a dynamic range of 132.5dB and a signal-to-noise ratio (SNR) of 132dB. Furthermore, it also boasts a harmonic distortion rate of just 0.00014%, allowing you to enjoy a listening experience that's both rich in detail and devoid of imperfections.
Thanks to the Tanchjim application available here, you can modify many of the Luna's parameters, including gain level, channel balance and the ability to switch from Class AB operation for greater stability and linearity, to Class H operation for greater efficiency.
To make volume control as pleasant as possible, the Luna features a non-linear progression of attenuation, while decoupling the volume control from the output stage for transparent attenuation to the ear.
The Luna is supplied with a high-quality USB 2.0 standard cable, with silver-plated single-crystal copper conductors to guarantee high-performance data transmission without electromagnetic interference.
The Luna has a single-ended 3.5mm jack output and a balanced 4.4mm jack output. This makes it compatible with most headphones for everyday use.
" I am happy to recommend the TANCHJIM Luna DAC. We have arrived at a new era in portable products, achieving near top-end desktop class performance. "
Product type | Portable DAC |
Input | 1x USB-C |
Output | 1x Single-ended Jack 3.5mm headphone output 1x Balanced Jack 4.4mm headphone output |
DAC Chip | 2x CS43198 |
Output power | 175mW @ 16Ω 285mW @ 32Ω 54mW @ 300Ω |
Output voltage | Balanced output : 4Vrms (High) / 2Vrms (Low) Single-ended output : 2Vrms (High) / 1Vrms (Low) |
Frequency response | 8Hz - 80kHz |
Total harmonic distortion more noise (THD+N) | 0.00014% |
Background noise | Balanced : 1.3µV Single-ended : 1µV |
Dynamic range | Balanced : 132.5dB Single-ended : 127dB |
Supported samples rates | PCM up to 32bit 768kHz DSD up to DSD256 |
Color | Silver |
Package | 1x Tanchjim Luna 1x USB-C cable 1x USB-A to USB-C adapter |
Input | USB |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
DAC / ADC Chip | CS43198 |
Max sampling rate | DSD256 |
Max sampling rate | 768kHz |
Color | Silver |
Networking | No |
Remote Control | No |
