AUDIOPHONICS LPA-M750ET Power Amplifier Purifi 1ET9040BA
The Audiophonics LPA-DM750ET is a Class D power amplifier featuring mono architecture. Integrating a Purifi 1ET9040BA amplifier module and an independent Hypex SMPS1200A180 power supply board, it is capable, with incredible ease, of delivering 1x750W into 4Ω or 1x375W into 8Ω, while offering exceptional richness and precision for a musical experience on a whole new level.
By buying this product you get 149 loyalty points
Reference : 19338
1 490,00 €tax incl.
1 241,67 € tax excl.
Shipping date: 06-05-2025.
Audiophonics Workshop amplifiers range
Audiophonics LPA-M750ET Power Amplifier Mono Class D Purifi 1ET9040BA 1x750W 4 Ohm
Audiophonics LPA-M750ET : 3/4 view
This Audiophonics LPA-M750ET amplifier will integrate seamlessly into the vast majority of HiFi systems, and can even accompany the most demanding loudspeakers.
All components are housed in a solid aluminum case, sober and modern. The design of the housing also ensures efficient heat dissipation, considerably reducing the impact of interference on the signal.
Audiophonics LPA-M750ET : Key features
Audiophonics LPA-M750ET : Purifi 1ET9040BA Amplifier Module
Audiophonics LPA-M750ET : A Purifi 1ET9040BA module in a mono architecture
Purifi's latest Class D amplifier module, the 1ET9040BA, once again represents an exceptional solution, capable of delivering both high power and very low noise levels and incredible linearity. It's based on EIGENTAKT's proprietary second-generation amplification technology, ensuring perfectly transparent sound reproduction, respecting every detail of the audio signal. Performance correlated with impeccable measurements, both in terms of THD and IMD.
The Audiophonics LPA-M750ET power amplifier features a Purifi 1ET9040BA module in a mono architecture, delivering 750W at 4Ω.
Audiophonics LPA-M750ET : Hypex SMPS1200A180 power supply module
The Hypex SMPS1200A180 switched-mode power supply is an ultra-high-efficiency model capable of developing a rated power of 1200 Watts in a compact footprint. It has been specifically designed and developed by Hypex to supply the 46V voltage required to operate the most demanding amplifier modules.
This high-quality, low-noise power supply meets the power requirements of the amplifier module in every respect. What's more, the amplifier module itself has an excellent ability to reject power supply noise. As a result, the LPA-M750ET is extremely insensitive to imperfections in the power supply network, and to voltage/current variations that can cause parasitic noise.
Audiophonics LPA-M750ET : Proprietary interface "Buffer" board
A Texas Instrument OPA1656IDR OPA is used. This is a very low distortion OPA, offering the greatest transparency with very low THD. It is mounted on a socket allowing it to be replaced if necessary.
To suit all uses we have opted for 4 gain settings: +16.55dB (x6.72) / +22.7dB (x13.64)  / +28.75dB (x27.38) / 30.8dB (x34.67). These settings are available under the device.
Audiophonics LPA-M750ET : Balanced and unbalanced connectors
The Audiophonics LPA-M750ET power amplifier features simple but effective connectors for the vast majority of applications. Inputs include single-ended RCA and balanced XLR. Output is simply via speaker terminals. A double trigger is also present (input and output), enabling the amplifier to be integrated into an automated on/off chain.
Audiophonics LPA-M750ET : Connector diagram
1ON/OFF button
2Speaker output
312V Trigger output
4Power switch
5XLR balanced input
6Input switch
7RCA single-ended input
812V Trigger output
9Power input
THD vs Frequency @ 4
Audiophonics LPA-M750ET : THD vs Frequency measurement
THD+N vs Output power @ 1kHz
Audiophonics LPA-M750ET : Mesure de THD+N vs Puissance
Frequency response @ 2.83V
Audiophonics LPA-M750ET : Frequency response measurement
Product typePower amplifier
Number of channelsMono (1)
Amplification typeClass D
Amplification modulePurifi 1ET9040BA
Output power (@ THD 1%)1x 375W @ 8Ω, 0.1% THD
1x 750W @ 4Ω, 0.1% THD
1x 1200W @ 2Ω, 0.1% THD
InputsBalanced XLR
Single-ended RCA
OutputSpeaker terminal
Gain / Sensitivity16.55dB - 4.07V
22.7dB - 2V
28.75dB  - 1V
30.8dB - 0.775V
THD+N0.0003% @ 1W, 1kHz
0.0001% @ 10W, 1kHz
0.00006% @ 100W, 1kHz
0.000045% @ 400W, 1kHz
0.0003% @ 1W, 20Hz-20kHz
0.0001% @ 10W, 20Hz-20kHz
0.00015% @ 100W, 20Hz-20kHz
0.0001% @ 400W, 20Hz-20kHz
IMD0.0001% @ 1W, 18.5kHz+19.5kHz
0.0001% @ 10W, 18.5kHz+19.5kHz
0.0001% @ 200W, 18.5kHz+19.5kHz
Dynamic range140dB(A)
Output noise4.5µV(A)
Efficiency96% @ 1kHz, 750W, 4Ω
Output current40A
Supply voltage110-230V (switchable)
Total dimensions (WxDxH)191 x 386 x 82mm
Ide power0.1W
Weight3.2kg
Package1x Audiophonics LPA-M750ET
1x Power cable
InputXLR
Channel1 (Mono)
Amplifier chipPurifi 1ET9040BA
Power (W)750
3 reviews
Enfin le son que je cherchais !
Je viens d’installer une paire d’amplificateurs mono de puissance en classe D sur mes Focal Electra 1028 Be. Pour être honnête, j’étais plutôt réservé au départ… La classe D traîne encore pas mal d’idées reçues. Mais dès les premières écoutes, tout a été balayé.
Le rendu est d’une grande musicalité : c’est naturel, précis, avec une belle transparence et une scène sonore profonde. Les timbres sont justes, les détails ressortent sans agressivité, et le tout reste toujours fluide et cohérent. Les enceintes sont parfaitement tenues, même à bas volume, avec un grave propre et bien maîtrisé.
Chaque session d’écoute me surprend par le niveau de qualité et l’émotion que ce système arrive à transmettre. Pour moi, c’est une vraie révélation, presque une finalité : je ne ressens plus le besoin de chercher mieux.
Un grand merci à David Aubert pour son accompagnement, ses conseils précieux et la documentation autour de ces amplis.
This review has been posted for AUDIOPHONICS LPA-M750ET Power Amplifier Mono Class D Purifi 1ET9040BA 1x750W 4 Ohm
Impressionnant !!
Dans le cadre d’une évolution progressive de mon système en 5.2 Je viens de m’équiper de 2 bloc mono LPA-M750ET (1ET9040BA) qui sont branchés sur les sorties Pre-Out d’un Yamaha RX3060 (qui a terme sera remplacé par un préampli multicanal plus performant). Mes enceintes principales un peu exigeante (Panneaux Magnepan 1.7i) étaient depuis quelques mois alimentées par un HPA-S500ET (1ET7040) qui déjà m’avait bluffé, mais là avec les 2 bloc mono (choisi pour des questions d’intégration plutôt que la version double mono qui doit avoir le même rendu sonore j’imagine). C’est une autre dimension, séparation des canaux, profondeur, très analytique, je redécouvre quasiment toutes les prises de son. Le réglage du gain est un plus incontournable pour pouvoir associer ces amplis avec les sorties pré out du Yamaha. Le HPA-S500ET est passé sur les enceintes arrière (JMLab Micron Titane) ça les a bien réveillés ! Prochaine étape un bloc mono pour la voie centrale (Dynaudio Gemini). Merci à Audiophonics pour les conseils et rapidité d’expédition.
Parfait
Il dépasse largement, ce qui est étonnant déjà, le HPA-S500ET version ampli stéréo que j'ai apprécié beaucoup pendant quelques mois. Maintenant passé sur les voix surround G et D.
Avec sa propre alimentation Hypex on a un sytème double mono incroyable.
Il est plus subtile. On entend clairement les niveaux de basses, les détails fourmillent. A faible volume les détails sont présents à fort volume pas de distortion. Un régale.
On a non seulement un sytème en HC formidable pour les dynamiques importantes dans les flms en RCA (vraiment un apport important en front, surround et back avec les audiphonics le son est clair et ne casse pas les oreilles même avec des transtoires complexes alors que j'ai le NAD T778 déjà réputé pour sa dynamique sur tous les canaux) et en stéréo XLR sur un bon lecteur réseau comme le UD-701 TEAC un son merveilleux pas du tout fatiguant. Pour un prix vraiment raisonnable et un très bon SAV et surtout de bons conseils pour optimiser l'installation.
Avec un HPA-S400ET également pour les surround back G et D on obtient des détails impressionants sur des films surround sans avoir les oreiles qui vrillent même à fort volume c'est génial. Grand merci à Audiophonics pour nous permettre d'accéder à ce niveau de son.
 (3)
The Audiophonics LPA-DM750ET is a Class D power amplifier featuring mono architecture. Integrating a Purifi 1ET9040BA amplifier module and an...
