FOSI AUDIO CA30 4-Channel Car Amplifier
The Fosi Audio CA30 is a power amplifier for car audio systems. Designed around the Infineon IR4322 amplifier chip, it delivers 4×100W under 4Ω, or 2×320W under 4Ω in bridged mode, using a high-efficiency architecture that delivers stable current while limiting internal heat build-up. This design results in a SINAD ≥ 80dB and THD+N ≤ 0.008%, ensuring low distortion reproduction, while a signal-to-noise ratio ≥ 100dB and background noise limited to ≤ 200μV preserve the clarity of micro-information, regardless of the listening level.
Reference : 21534
159,99 €tax incl.
133,33 € tax excl.
Fosi Audio CA30 4-channel Car Amplifier 4x100W 4 Ohm 10Hz-40kHz
Fosi Audio CA30 : Front view
Designed for car audio systems requiring both dynamic reserve and configuration flexibility, it can be used in four independent channels to power a front/rear set, or in two bridged channels to drive more demanding loads. Beyond pure performance, this approach is accompanied by a set of active protections to guard against overheating, short circuits, overvoltage, undervoltage and polarity reversal, continuously monitoring electrical parameters to secure the installation and speakers.
Fosi Audio CA30 : Diagram
Product typeCar amplifier
Inputs4x RCA
1x 8-pin Molex
Output4x Screw terminal block
Output power4x100W RMS @ 4Ω
4x160W RMS @ 2Ω
2x320W RMS @ 4Ω
SINAD≥ 80dB
Total harmonic distortion more noise (THD+N)≤ 0,008%
Signal-to-noise ratio (SNR)≥ 100dB
Background noise≤ 200μV
ProtectionOverheating
Short circuit
Overvoltage
Undervoltage
Polarity reversal
Frequency response10Hz-40kHz
Low-pass filter50Hz-250Hz
High-pass filter50Hz-250Hz
Damping factor≥ 140
Power supply voltage12V DC
Dimensions186 x 101 x 44.2mm
Package1x Fosi Audio CA30
1x 8-pin ribbon speaker cable
InputMolex
OutputScrew terminals
Channel4
Amplifier chipInfineon IR4322
Power (W)100.0
Power (W)320.0
FOSI AUDIO CA30 4 Channel Car Amplifier 4x100W 4 Ohm 10Hz-40kHz
The Fosi Audio CA30 is a power amplifier for car audio systems. Designed around the Infineon IR4322 amplifier chip, it delivers 4×100W...
