TOPPING HYNOTONE CABSCREAMER60 Power Amplifier Guitar Pedal Sized 60W
-15%
The Topping Hynotone Cabscreamer60 is a guitar power amplifier in pedal format, designed to complement a pedalboard or a system based on a preamp / multi-effects unit. It delivers 60W of power at 4 ohms (1% THD), allowing it to directly drive a guitar cabinet while maintaining an ultra-compact form factor.
Reduced price!
Reference : 21843
Limited time offer:
128,67 €tax incl.
-15%
109,37 €tax incl.
91,14 € tax excl.
Topping Hynotone CABSCREAMER60 Guitar Pedal Format Power Amplifier 60W
Photo of the TOPPING HYNOTONE CABSCREAMER60
The Topping Hynotone Cabscreamer60 is a guitar power amplifier in pedal format, designed to complement a pedalboard or a system based on a preamp / multi-effects unit. It delivers 60W of power at 4 ohms (1% THD), allowing it to directly drive a guitar cabinet while maintaining an ultra-compact form factor. It features a 6.35mm jack instrument input (100 kΩ), a 6.35mm speaker output, as well as a balanced TRS 6.35mm line output for recording or live sound applications. Power is supplied via a USB-C port compatible with Power Delivery (15V / 5A), with an additional 9V / 200 mA DC output to power other pedals. The CabScreamer60 features advanced tone controls, including Bass and Treble (±12 dB), labeled Presence and Resonance, a nod to tube amplifiers, offering precise control over the sound spectrum. Compact (approx. 120 x 124 x 56 mm) and lightweight (~470 g), it is an ideal solution for guitarists seeking a portable, powerful, and versatile system.
Please note: The CABSCREAMER60 requires a preamp to be connected before it. You cannot plug your guitar directly into it.
Connections of the TOPPING HYNOTONE CABSCREAMER60
Topping Hynotone CABSCREAMER60: a true power amplifier in pedal format
The CabScreamer60 is not just an effect pedal but a full power amplifier capable of directly driving a guitar cabinet. It is designed to be used in combination with a preamp, multi-effects unit, or amp simulator, forming a complete and compact solution for stage or studio use.
Its 60W output provides sufficient volume for rehearsals or live performances while maintaining excellent portability.
Topping Hynotone CABSCREAMER60: tone controls inspired by tube amplifiers
The CabScreamer60 integrates advanced controls to shape the sound like a traditional amplifier. Bass and Treble controls offer ±12 dB adjustment, while Presence and Resonance settings replicate the behavior of tube power stages.
This approach allows fine adjustment of high and low frequencies, bringing more dynamics, depth, and realism to the signal, especially when paired with a guitar preamp.
Topping Hynotone CABSCREAMER60: balanced line output for stage and studio
In addition to the speaker output, the CabScreamer60 features a balanced TRS line output, ideal for recording or live use.
This output allows sending the signal to an audio interface, mixing console, or PA system, offering great flexibility in modern setups (direct-to-PA, IR loader, etc.).
Topping Hynotone CABSCREAMER60: USB-C PD power supply and 9V output for pedals
The device operates via a USB-C power supply compatible with Power Delivery, allowing use with both a wall adapter and a power bank for portable operation.
A particularly practical feature is the presence of a 9V / 200 mA DC output, capable of powering an additional pedal, simplifying cabling and reducing the number of power supplies required on a pedalboard.
Topping Hynotone CABSCREAMER60: a compact solution for modern setups
With its compact size and lightweight design, the CabScreamer60 easily integrates into a pedalboard. It is an ideal alternative to traditional amplifier heads, especially for guitarists using:
  • pedal preamps
  • digital amp simulators
  • multi-effects units such as Helix, HX Stomp or Headrush
It enables the creation of a complete, portable, and high-performance system suitable for both stage and home studio use.
Technical specifications
Product typePedal-format guitar amplifier
Input1x 6.35mm instrument jack (100 kΩ)
Outputs1x 6.35mm speaker output
1x 6.35mm TRS balanced line output 200 Ohm (recording or live sound)
Tone controlTreble/Bass (±12 dB)
Other connectivity1x DC 9V / 200 mA output (5.5/2.1mm, center negative)
Power supplyVia USB-C port compatible with Power Delivery (15V / 5A)
Dimensions120 x 124 x 56mm
Weight470g
Packaging1x Topping Hynotone CABSCREAMER60
InputJack 6.35mm
OutputJack 6.35mm
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipN/A
Power (W)60.0
The Topping Hynotone Cabscreamer60 is a guitar power amplifier in pedal format, designed to complement a pedalboard or a system based on a preamp /...
