By buying this product you get 54 loyalty points
Power amplifier mono NCORE NC500MP
Based on a Hypex NCORE NC500MP module, this class D amplifier has tremendous efficiency thanks to a switching power supply with synchronous regulation.
As for most NCORE-based power amplifiers, the frequency response is independent of the load and the EMI are strictly controlled, which significantly limit distortion.
Hattor NC500MP will thus particularly appreciated in all conditions requiring high power amplification while maintaining a high neutrality in the return signal. It suitable in a professional studio as well as in a private home.
The circuit is integrated in an aluminum housing with superb finishes and two brand-customized heatsinks on both sides of the device.
The amplifiied signal output is available on speaker terminals. The model used is a Hattor patented connector and is made of pure copper for best signal transmission.
As input, the device is capable of working from a push-pull signal (RCA CMC port) as well as from an unbalanced signal (port XLR Neutrik).
All internal connector works with copper conductors silver plated.
The user can toggle between the RCA and XLR input with ease through a switch on the back of the unit. All inputs & outputs are identified by a marking.
The device can work when powered with 230V or 110V. The integrated switching power supply automatically selects the proper input voltage depending on what is fed.
Type | Power Amplifier |
Max power | 270W / 8Ω 500W / 4Ω 400W / 2Ω |
Ratio signal / noise | 106 dB |
Gain | 26dB |
THD | 0.006% |
Input impedance | 47 kW |
Output impedance | 2.6 mΩ |
Frequency response | 2 Hz - 50kHz 0 / -3dB |
Inputs | RCA mono (unbalanced) XLR mono (balanced) |
Dimensions | 90 x 200 x 200 (height, width, depth) |
Color | Housing: Black Front: Black |
Power cable | NOT included |
Input | RCA |
Input | XLR |
Output | Speaker terminal |
Color | Black |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | Hypex Ncore |
Power (W) | 500.0 |
