HATTOR NC500MP Mono Class D Amplifier NCore 1x500W 4 Ohm Black
Mono power amplifier block based on NCORE NC500MP. A massive sound, rich in detail with superb finishes.
By buying this product you get 54 loyalty points
Reference : 14272
549,00 €tax incl.
457,50 € tax excl.
Hattor NC500MP
Power amplifier mono NCORE NC500MP
Based on a Hypex NCORE NC500MP module, this class D amplifier has tremendous efficiency thanks to a switching power supply with synchronous regulation.
As for most NCORE-based power amplifiers, the frequency response is independent of the load and the EMI are strictly controlled, which significantly limit distortion.
Hattor NC500MP will thus particularly appreciated in all conditions requiring high power amplification while maintaining a high neutrality in the return signal. It suitable in a professional studio as well as in a private home.
The circuit is integrated in an aluminum housing with superb finishes and two brand-customized heatsinks on both sides of the device.
Quality connectors
The amplifiied signal output is available on speaker terminals. The model used is a Hattor patented connector and is made of pure copper for best signal transmission.
As input, the device is capable of working from a push-pull signal (RCA CMC port) as well as from an unbalanced signal (port XLR Neutrik).
All internal connector works with copper conductors silver plated.
maximum ergonomics
The user can toggle between the RCA and XLR input with ease through a switch on the back of the unit. All inputs & outputs are identified by a marking.
The device can work when powered with 230V or 110V. The integrated switching power supply automatically selects the proper input voltage depending on what is fed.
TypePower Amplifier
Max power270W / 8Ω
500W / 4Ω
400W / 2Ω
Ratio signal / noise106 dB
Gain26dB
THD0.006%
Input impedance47 kW
Output impedance2.6 mΩ
Frequency response2 Hz - 50kHz 0 / -3dB
InputsRCA mono (unbalanced)
XLR mono (balanced)
Dimensions90 x 200 x 200 (height, width, depth)
ColorHousing: Black
Front: Black
Power cableNOT included
InputXLR
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipHypex Ncore
Power (W)500.0
