TOPPING B100 Mono Power Amplifier Black
The Topping B100 mono power amplifier, little brother of the B200, is a state-of-the-art amplifier in terms of performance. It uses Topping's proprietary amplifier module to deliver 100W of power at 4 ohms, while maintaining a THD+N < 1% and a DNR of 151dB.
Reference : 19759
299,00 €tax incl.
249,17 € tax excl.
Last items in stock !
Shipping date: 02-07-2025.
Topping B100 Mono Power Amplifier 100W 4 ohm Black
Topping B100 picture
The Topping B100 mono power amplifier, little brother of the B200, is a state-of-the-art amplifier in terms of performance. It uses Topping's proprietary amplifier module to deliver 100W of power at 4 ohms, while maintaining a THD+N < 1% and a DNR of 151dB. Ultra high-performance, the B100 is the amplifier of choice for setting up a dual-mono system for anyone looking for a nice reserve of power and uncompromising audio quality. On the interface side, there's a balanced TRS 6.35mm/XLR combo input and an RCA input, while the output is via speaker terminals. A 12V trigger also lets you pair the B100 with a variety of devices for quick and easy power-up. Another notable feature is that a three-level gain control is available on the rear panel, offering additional adjustment. Aesthetically speaking, the B100 is not to be complained about, as it takes on the form factor and handsome front panel of the brand's E70 and E70 Velvet DACs.
Les points forts du Topping B100
Topping B100: a powerful, low-distortion amplifier
Thanks to Topping's proprietary amplifier module, the B100 delivers up to 100W of power under a 4 ohm load, maintaining a THD+N of less than 1% and less than 0.00007% at 5W of power under 4 ohm. This enables it to rival the performance delivered by the ES9039SPRO DAC chip for the most demanding sound rendering. Under an 8 ohm load, the B100 is capable of delivering 50W of power (THD+N<1%).
Topping B100 un amplificateur puissant
Topping B100: detailed sound reproduction
The B100 mono power amplifier offers an SNR and DNR of 151dB for ultra-detailed reproduction and the ability to handle signals as complex as they are subtle.
Topping B100, un rendu sonore détaillé
Topping B100: Dual-mono configuration
To obtain a complete dual-mono configuration, it is necessary to use two B100 mono power amplifiers coupled with passive speakers.
Configuration double mono avec les Topping B100
Les petits plus du Topping B100
Topping B100: 12V trigger and gain control
The 12V trigger on the rear panel of the B100 greatly facilitates the user experience, allowing simultaneous switching of several interconnected devices. In addition, a 3-position gain control switch offers precise adjustment of the final sound according to the incoming signal.
Topping B100 overview
1Balanced TRS 6.35mm/XLR combo jack input
2Source selector
3RCA input
4Speaker terminal output
5Gain control switch
6System update port
7Trigger 12V jack 3.5mm
838V 4A power supply connector
Topping B100 review by Audio Science Review (Amir)
" Topping is clearly its own competition, constantly pushing the envelop in noise and distortion. Even when you get used to them delivering on these fronts, they come up with this amplifier where test after test shows excellence in engineering and utmost dedication to highest levels of fidelity. All of this comes in a compact enclosure with a reasonable cost. I have no choice but to bow to their mission and abilities. "
Logo Audio Science Review
Product typePower amplifier
ChannelMono
Inputs1x Balanced TRS 6.35mm/XLR combo jack input
1x RCA input
OutputSpeaker terminal block
Trigger 12V
Topping B100 measurement
Input typeBalancedUnbalanced
THD+N @ 1kHz (A-wt)<0.00008% @ 4Ω 5W
<0.00008% @ 8Ω 5W
<0.00008% @ 4Ω 5W
<0.00008% @ 8Ω 5W
THD @ 20-20kHz (90kBW)<0.00007% @ 4Ω 5W
<0.00007% @ 8Ω 5W
<0.00007% @ 4Ω 5W
<0.00007% @ 8Ω 5W
SNR (A-wt)151dB149dB
Dynamic range151dB149dB
Frequency response20Hz-40kHz (±0.1dB)
10Hz-100kHz (±0.5dB)
20Hz-40kHz (±0.1dB)
Output level56Vpp @ 4Ω
66Vpp @ 8Ω
56Vpp @ 4Ω
66Vpp @ 8Ω
Noise level measured by AP
(A-wt)
<0.7uVrms @ G=L
<1.2uVrms @ G=M
<2.6uVrms @ G=H
<0.9uVrms @ G=L
<2.3uVrms @ G=M
<6.2uVrms @ G=H
Actual noise level<0.3uVrms @ G=L
<1uVrms @ G=M
<2.4uVrms @ G=H
<0.7uVrms @ G=L
<2.2uVrms @ G=M
<6.2uVrms @ G=H
Input sensitivity26.6Vrms @ G=L
8.6Vrms @ G=M
3Vrms @ G=H
13.3Vrms @ G=L
4.3Vrms @ G=M
1.5Vrms @ G=H
Gain0dB @ G=L
10.4dB @ G=M
19.9dB @ G=H
6dB @ G=L
16.4dB @ G=M
25.9dB @ G=H
Output impedance<5mΩ<5mΩ
Input impedance20kΩ5kΩ
Output power100W @ 4Ω THD+N<1%
83W @ 8Ω THD+N<10%
70W @ 8Ω THD+N<1%
100W @ 4Ω THD+N<1%
83W @ 8Ω THD+N<10%
70W @ 8Ω THD+N<1%
Load impedance≥4Ω≥4Ω
Power supply38V DC 4A
Dimensions200x138x40mm
Package1x Topping B100 mono amplifier
1x AC adapter and power cable
Mesure du Topping B100
InputXLR
InputJack 6.35mm
Channel1 (Mono)
ClassN/A
Amplifier chipN/A
Power (W)100.0
TOPPING B100 Mono Power Amplifier 100W 4 Ohm Black
The Topping B100 mono power amplifier, little brother of the B200, is a state-of-the-art amplifier in terms of performance. It uses Topping's...
