FURUTECH THE EMPIRE PLUS E Power Cable 1.8m
The Furutech Empire Plus E is a high-end power cable designed to meet the demands of audio professionals and the most discerning audiophiles. Developed in Tokyo in collaboration with musicians and sound engineers, this cable embodies Japanese craftsmanship and technological innovation to deliver a listening experience of unmatched precision and dynamics.
By buying this product you get 50 loyalty points
Reference : 21752
509,00 €tax incl.
424,17 € tax excl.
Furutech The Empire Plus E Power Cable Schuko Type E/F Shielded Alpha Treated Copper Gold Plated 1.8m
The Furutech Empire Plus E is a high-end power cable designed to meet the demands of audio professionals and the most discerning audiophiles. Developed in Tokyo in collaboration with musicians and sound engineers, this cable embodies Japanese craftsmanship and technological innovation to deliver a listening experience of unmatched precision and dynamics. Thanks to its meticulous design and premium materials, it ensures optimal signal transmission. This new version of the Empire Plus is now also equipped with a non-magnetic stainless steel main cable clamp, providing a more robust mechanical hold and further reducing mechanical and electrical distortions.
Furutech The Empire Plus E : Composition diagram
Furutech The Empire Plus E: A design inspired by traditional craftsmanship
The Empire Plus E cable is based on patented PC-Triple C (Alpha) technology, an exclusive forging process inspired by the craftsmanship of katanas. This treatment, which involves repeated cycles of bending OFC copper under high pressure, reorganizes the boundaries of the crystal grains on a microscopic scale. The result: electrical current flows with exceptional fluidity, reducing distortion and improving the clarity of the audio signal.
Furutech The Empire Plus E: Materials and technologies designed to enhance performance
The Furutech The Empire Plus E incorporates several technological innovations for optimal performance:
  • Furutech FI-E11-N1 (G) et FI-11-N1 (G) connectors with gold-plated contacts that ensure a reliable connection and minimal electrical resistance.
  • Noise-reduction shielding (Alpha) that effectively protects against electromagnetic interference and noise, thereby preserving signal integrity.
  • RoHS-compliant flexible PVC sheath: Reduces vibration and improves mechanical insulation, contributing to a more stable transmission.
  • Patented Floating Field Damper™ grounding system, which minimizes electrical and mechanical distortion for a purer, more consistent sound.
Product typePower cable
Length~1.8m
Connectors1x Schuko Type E/F
1x IEC C15
Cable conductor materialPC Pure copper
Connectors contacts platingGold
ShieldingBraided OFC Copper 0.12mm
Internal sheath materialPVC
Outer sheath materialPVC
Covering sheathBraided nylon (RoHS)
Outer diameterØ16mm
ColorBlue / Black
Package1x Furutech The Empire Plus E
Length (m)1.8
ShieldingYes
Section (mm²)N/A
ConnectorIEC C15
ConnectorType E (CEE 7/5 - CEE 7/6)
ConnectorSchuko
ConnectorType F (CEE 7/3 - CEE 7/4)
FURUTECH THE EMPIRE PLUS E Power Cable Schuko Type E/F Shielded Alpha Treated Copper Gold Plated 1.8m
The Furutech Empire Plus E is a high-end power cable designed to meet the demands of audio professionals and the most discerning audiophiles....
