AUDIOPHONICS Wire Sector Filter SCHAFFNER FN9222B CS-321B 10A
Reference : 11985
39,90 €tax incl.
33,25 € tax excl.
This wireline mains filter consists of a SCHAFFNER FN9222B, Elecaudio CS-321B cable and an IEC connector. This accessory makes it possible to rid the power supply of EMI interference and to have a proper voltage.
  • SCHAFFNER FN9222B IEC Mains Filter Noise Control/EMI 230V
The benchmark for high-performance mains filters: the FN9222B model from the Swiss manufacturer SCHAFFNER, designed to filter out disturbances when capacitors are insufficient. High efficiency against electromagnetic disturbances (EMI) propagated by radiation or conduction.
Product conforms to IEC 950, UL, CSA, TÜV, SEMKO, NEMKO and FIMKO approved standards, and meets the requirements of category II overvoltage (IEC664).
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_1.jpg
Specifications :
  • Operating voltage: 250V Max 50/60Hz
  • 10A
  • Leakage Current: 2µA
  • Operating Frequencies: Up to 400Hz
  • Capacity: 0.1µF x2
  • Chokes: 12.0 mH x 2
  • Resistance: 1MΩ
  • Operating Temperature Range: -25°C to +85°C
  • Certifications : UL, CSA, TÜV, SEMKO, NEMKO & FIMKO
  • Weight: 40g
  • Built-in dimensions: 28x20.5mm
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_3.jpg
A : 48mm
B : 22.5mm
C : 40mm
D : 38.4mm
F : 5.5mm
H : 3.3mm
J : 13.3mm
S : 90°
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_2.jpg
  • ELECAUDIO CS-321B OCC - OCC Mains Cable OCC Teflon Insulation 3x2.50mm²
    Power cable with very fine strands insulated FEP for more detail and flexibility.
Features:
  • Phase and Neutral conductors: 1x26x0.12mm OCC + 6x38x0.10 OFC = 2.5mm²
  • Earthing conductor: 1x26x0.12mm OFC + 6x38x0.10 OFC = 2.5mm²
  • Teflon conductor insulation (FEP)
  • Cotton padding
  • Mylar shielding
  • Shielding drain: 26x0.16mm
  • OFC shielding braid
  • PVC insulation
  • Outer diameter: 10mm
  • Curvature radius: ~8cm
https://www.audiophonics.fr/images2/6253/6253_FILTRESURFIL_1.jpg
Lenght 30 cm
https://www.audiophonics.fr/images2/6253/6253_FILTRESURFIL_2.jpg
Length (m)N/A
Section (mm²)N/A
ConnectorIEC C14
ConnectorIEC C13
