LHY AUDIO DC ELITE DC Power Supply Filter
New
The LHY Audio DC Elite is a DC power filter designed to improve the quality of the current supplied to audio devices by a wall adapter or a linear power supply. Its multi-stage CLC filtering circuit, combined with active noise cancellation, aims to reduce residual ripple and noise while providing energy storage capacity, in order to deliver a more stable power supply to compatible equipment.
Reference : 22682
99,00 €tax incl.
82,50 € tax excl.
LHY Audio DC ELITE DC Power Supply Filter with Active Noise Reduction
LHY AUDIO DC ELITE: Front view
The combination of capacitors of different values, including Samsung COG models, Rubycon/NCC electrolytics and Panasonic SMD lithium capacitors, acts across several frequency ranges and helps reduce the internal resistance of the power supply. High-current common-mode inductors complete this architecture, while the LED display allows the DC voltage to be monitored in real time.
The DC Elite accepts a voltage of 5 to 30V DC and a maximum current of 10A. Its two inputs and two outputs support Jack DC 5.5/2.1mm and Jack DC 5.5/2.5mm connectors with center-positive polarity, with the option of adapting the format between input and output. This configuration makes it easy to integrate with various power supplies and audio devices, provided their electrical requirements are respected.
Technical specifications
Product typeDC Power Supply Filter
Input1x DC Jack 5.5/2.5mm
1x DC Jack 2.5/2.1mm
Output1x DC Jack 5.5/2.5mm
Operating voltage range5-30V DC
Max. operating current10A
Dimensions90 x 45 x 110mm
Weight333g
Package1x LHY Audio DC Elite
LHY AUDIO DC ELITE DC Power Supply Filter with Active Noise Reduction
The LHY Audio DC Elite is a DC power filter designed to improve the quality of the current supplied to audio devices by a wall adapter or a linear...
