Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Francois Q.
Rapport Q/P incroyable
Son prix est déjà sans doute assez conséquent pour pas mal de mélomanes… sauf que quand je l’ai branché il ne m’a pas fallu...
Nicolas B.
Trop bruyant
Ces amplis, silencieux à froid, se mettent à faire de plus en plus de bruit de résidus d’alim à découpage au fur et à mesure du...
TAD KT88-STR
Power Plugs & Sockets
Power Plugs & SocketsDiscover our wide range of power plugs, IEC, Schuko or other formats, to design your HiFi power cables.
  • IEC Connectors
    IEC Connectors
    Discover our range of IEC connectors of all sizes, for the design of your HiFi power cables.
  • Schuko Connectors
    Schuko Connectors
    Discover our range of Schuko power connectors, for the design of your HiFi power cables.
  • Various Internationals
    Various InternationalsDiscover our range of sector connectors in international formats, for the design of your HiFi power cables.
  • Schuko Inlets
    Schuko Inlets
    Discover our range of Schuko plugs, for the installation of your wall sockets.
  • IEC Inlets
    IEC Inlets
    Discover our range of IEC plugs of all sizes, for the integration of a power connector on your HiFi devices.
