AC adapter 100-240V AC to 12-24V DC + 8 Jack adapters
If you find it difficult to find a power supply that matches your device, or if it is no longer available on the market, this power supply with a universal adapter will make your life a lot easier.
3.0 / 5
Reference : 12622
22,89 €tax incl.
19,08 € tax excl.
Shipping date: 22-09-2026.
Adapter and universal power supply
universal laptop charger power supply
If you have trouble finding a power supply that matches your device or is no longer available on the market, this power supply with a universal adapter will make your life a lot easier. Simply connect the corresponding tip, choose the correct voltage and connect the supplied power cable and you already have a suitable power supply. You can naturally alternate tips if many of your devices need a source of energy.
Supports many types of connectors
charge any laptop with this adapter
This power supply is provided with 8 different tips that correspond to the most used connectors in consumer electronics. They can therefore adapt to many models of laptops, amplifiers, accessories such as lighting, smoke machines ... etc. The tip installation is secure and takes only seconds. It is a very good tool to carry when traveling if you need more than one charger for multiple devices. This one can do the job without taking as much space in your suitcase.
Manual voltage selection
choose the volts that match your device
This AC adapter is equipped with a voltage selector. You will therefore be able to ensure that the specifications and requirements of your electronic devices will be respected in order to enjoy optimal interoperability. 6 Position are available, corresponding to the standards most frequently encountered on ordinary electronic devices. This universal adapter can deliver a voltage of 12, 16, 18, 19, 20, 24 volts as desired.
Caution is advised since it is not possible to change the voltage while the device is in use.
Specifications :
  • Input voltage : AC95V - 265V
  • Input amp : 0.4-0.6A
  • Dimensions : 116.7 x 57.1 x 36.2 mm
  • Power Cable length  : 95 cm
  • Length of power supply cable : 100 cm
  • 8 adapters included + Power cable
Volts12V15V16V18V19V20V24V
Amps4.5 A4.5 A4.5 A4.5 A4.5 A4 A4 A
Included adapters :
Ø External6.5 mm6.3 mm5.5 mm5.5 mm5.5 mm4.6 mm4 mm3.5 mm
Ø Internal4.4 mm3.1 mm2.5 mm2.1 mm1.7 mm1.7 mm1.7 mm1.2 mm
Output voltage (V)12.0
Output voltage (V)18.0
Output voltage (V)20.0
Output voltage (V)24.0
Output voltage (V)16.0
Output voltage (V)19.0
3 reviews
À éviter. Alimentation instable et bruyante
Le bruit généré par cette alimentation est extrêmement audible et déplaisant. Deux exemplaires commandés, deux comportements similaires. Bruit de distortion électrique très fort transmis dans l'amplificateur, non filtré, différent pour chaque voltage, et augmentant en intensité proportionnellement au voltage. INSUPPORTABLE !!
This review has been posted for AC adapter 100-240V AC to 12-24V DC + 8 Jack adapters
Qualité de fabrication très moyenne, fiches fragiles...
Abimé dès la première utilisation car les fiches de la prise secteur sont mal ébavurées coté transfo (ne faites pas comme moi, regardez bien avant de brancher!)
Heureusement, le SAV de Audiophonics est rapide compréhensif et compétent, et m'en a renvoyé un autre.
Low price, low quality, but it works.
the poles can not be replaced because the size of the two needles is not the same.
Must be a force of a gorilla to assemble
If you find it difficult to find a power supply that matches your device, or if it is no longer available on the market, this power supply with a...
