Module buffer source selection 2x NE5532 4 input RCA
3.5 / 5
Reference : 13243
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 25-09-2026.
Source selection module with buffer
NE5532P 2x, 4x stereo RCA, rotary selector
Buffer module
This very versatile module offers a buffer working with two NE5532P PDO (one of which is mounted on DIP8 support). It also has a source selector function with 4x Stereo RCA inputs. The selector switch and the active source indicator are mounted on a separate PCB (included).
The set offers very good performance thanks to its regulated integrated linear power supply. The module can thus be connected directly to a compatible torique transformer.
The form-factor is thin and long which contributes to the originality of this module while opening opportunities for integration.
Buffer stage with source selector / NE5532P
Double OPA NE5532P
Two operational amplifiers NE5532P are at the heart of the buffer floor.
One of the two OPA is mounted on a DIP8 support and can be replaced in order to change the device's restitution according to one's preferences or to the specificities of an audio installation.
6 pairs of resistors with 1% tolerance allow the buffer stage to work under stable conditions to provide a stable and accurate sound reproduction.
Source selector
This module has 4 inputs stereo RCA ports. It is accompanied by a mechanical rotary switch to allow input source selection.
This switch is already mounted on a separate PCB. The PCB also includes 4 slots already arranged to receive LEDs (supplied) thus providing a visual indicator of the active source.
To preserve the sound, no audio signal flows into the source selector. The rotary selector merely supplies pairs of S9014 transistors with HK19F relay to enable / disable each output port.
Each relay is associated with 1N4148 switching diode with low leakage current.
PCB source select.
Installation diagram
installation diagram buffer selector source
TypeModule
Buffer
Source selection
InputRCA stereo x4
Output2 analog channels (XH)
Connectors Right - Left - GND
Source selector installationXH cable (soldering)
Power supplyAC (12V + 12V + 0)
Gainx10
Buffer PCB dimensions173 x 42 x 30mm
Selector PCB dimensions61 x 42 x 17 mm
Weight116g
Parts supplied
buffer modulex1
PCB source selection switchx1
LEDsx4
Interconnect Cablex1
OutputPCB Connector
Mounting typeTo weld
Channel2 (Stereo)
2 reviews
Pas convainquant
Le son subit une nette dégradation en passant par ce montage, et cela sur les 4 entrées. Un son saturé comme une station radio FM pas tout à fait sur la bonne fréquence. Un léger mieux après avoir changé le circuit intégré amovible par un équivalent sous la main, mais sans plus.
This review has been posted for Module buffer source selection 2x NE5532 4 input RCA
Que dire ..
Il est très dur de trouver un sélectionneur à faible "bruit"..
Quand la tension du transformateur est trop élevée ... plus de 19V
Les diodes n'aiment pas !!!
Dans le texte de l'article:
Chaque relais s'accompagne d'une diode de commutation 1N4148 à faible fuite de courant.
Reymond Eric
