Volume control module Board - PGA2311
This kit integrating a volume controller and a display is a solid base for the development of your DIY projects. This product consists of two plug-in modules with a 6-pin connector that can be easily separated for easy integration.
Reference : 8968
49,90 €tax incl.
41,58 € tax excl.
Volume control
PGA2311
Contrôleur de volume PGA2311
Delivered as standard without remote control, it can be controlled with an RC5 remote control.
  • 4 channel input selection via dedicated module (not included)
  • 3x7 segment display and separable rotary encoders
  • Rotary encoder used for volume control and input selection (if input selection module is connected)
  • Setting memory
Aluminium housing available here for this controller.
Volume controlPGA2311 : -95dB to +31dB by 1dB step
Power supplyAC +/- 8 to 12V
Stereo input / outputOn 3 poles XHP connectors
Rotary encoder6mm axis
IR Remote controlIncluded
Main moduleDisplay + encoder : 100 x 32mm
Secondary module85 x 32mm
Holes spacing26 x 78mm
This kit integrating a volume controller and a display is a solid base for the development of your DIY projects. This product consists of two...
