WONDOM AA-AB41147 Volume Control Module NJM1109
The Wondom AA‑AB41147 is a stereo volume control card with digital management, designed to precisely adjust analogue audio signal level while maintaining its integrity. It leverages proven adjustment module combined with separation of analogue and digital power supplies, enabling limitation of parasitic interference and signal clarity preservation throughout processing. This architecture extends to optimized thermal dissipation, avoiding external heatsink addition while ensuring stable operation over time.
Reference : 22260
14,91 €tax incl.
12,42 € tax excl.
Shipping date: 17-11-2026.
WONDOM AA-AB41147 Digital Volume Control Module NJM1109
WONDOM AA-AB41147 : Front view
The Wondom AA‑AB41147 is a stereo volume control board with digital management, designed to precisely adjust analogue audio signal level while maintaining its integrity. It leverages proven adjustment module combined with separation of analogue and digital power supplies, enabling limitation of parasitic interference and signal clarity preservation throughout processing. This architecture extends to optimized thermal dissipation, avoiding external heatsink addition while ensuring stable operation over time.
Conceived for custom integration, it combines direct connectivity: two stereo RCA inputs and one 3.5mm jack input, replicated at output, with multiple wiring modes facilitating insertion into existing project. This approach extends to two-card design, separating audio section from control interfaces, thereby enabling potentiometer relocation to front panel while simplifying internal arrangement. The assembly finally integrates overheat, overcurrent and polarity reversal protections, ensuring reliable use in prototyping or custom integration environments.
Product typeVolume control module
Inputs2x RCA
1x 3.5mm jack
Outputs2x RCA
1x 3.5mm jack
Volume control chipNJM1109
Maximum input level3Vrms
Maximum output level2.5Vrms
Control range-107.5dB ~ -10dB
Precision1dB/step
Output noise15.89µV
Total harmonic distortion (THD)0.03%
Signal-to-noise ratio (SNR)92.2dB
Operating temperature20℃ ~ 50℃
Storage temperature-20℃ ~ 105℃
Power supply12V DC / 0.5A
Idle current10mA
Dimensions91.4 x 66.6mm
Package1x Volume control module
1x Potentiometer module
InputJack 3.5mm
OutputJack 3.5mm
Channel2 (Stereo)
The Wondom AA‑AB41147 is a stereo volume control card with digital management, designed to precisely adjust analogue audio signal level while...
