AUDIOPHONICS PRE-01 PGA2310 Preamplifier Volume Control Input Selector Bluetooth 5.0
The Audiophonics PGA2310 preamplifier is an extremely versatile device at a more than affordable price. If it is first presented as a preamplifier, it also offers volume control and input selector features, with additional Bluetooth 5.0 support.
4.5 / 5
Reference : 13285
89,00 €tax incl.
74,17 € tax excl.
Audiophonics PGA2310 Préamplificateur Contrôle de Volume Sélecteur de Source RCA Bluetooth 5.0
Audiophonics PGA2310 préamplificateur sélecteur de source contrôle de volume
An excellent volume controller
As its name suggests, the device incorporates a volume control based on a PGA2310 TI chip offering very good audio performance. This allows a very precise volume adjustment from -90 to 0dB. This chip allows to obtain a very low distortion of 0.004%, a dynamic range of 120B, a THD+N of 0.0004% at 1kHz and a crosstalk of -126dBFS.
Connectic
The Audiophonics PGA2310 offers both classic connectivity with 4x stereo RCA inputs but adds Bluetooth in version 5.0, thanks to its JL AC1820AP chip. It is thus possible to stream your music remotely from a device with this connectivity such as a smartphone or tablet for example. Bluetooth version 5.0 ensures excellent stability and transmission speed for quality listening. A Bluetooth antenna is included to improve transmission.
The output side is simply one stereo RCA to connect the PGA2310 to an amplifier. Finally, power is supplied directly via the IEC cable (not provided) from a mains socket. The unit's power supply circuit incorporates efficient multi-channel regulation to significantly reduce noise.
Audiophonics PGA2310 Connectique
Power circuit
The quality of the power supply being decisive in the quality of the sound reproduction of an audio system, the Audiophonics PGA2310 benefits from a neat circuit. Thus, it integrates an efficient multi-cana regulation allowing to limit considerably the noise as well as an EMI / RFI filter allowing to filter the interferences which could generate noise.
Audiophonics PGA2310 Filtre EMI / RFI
Simple but effective design
In terms of design and ergonomics, the Audiophonics PGA2310 is simple and efficient. The components are integrated in a robust brushed aluminium housing with the most beautiful effect. A 51 x 20mm front panel screen displays both the active source from the 4 available and the sound volume, the latter up to an absolute value of 100. The white LED display provides excellent readability for easy adjustments. The unit also comes with an infrared remote control, allowing access to all settings, including volume adjustment, mute mode and source selection.
Audiophonics PGA2310 télécommande et écran
The IR receptor is very sensitive to directionnality. The remote will not work if the transmitter angle is too wide.
Power cable sold separately.
Product typePreamplifier
Volume control
Input selector
ChipPGA2310
Distortion0.004%
Dynamic range120dB
THD+N0.0004% @ 1kHz
Crosstalk-126dBFS
InputsBluetooth 5.0
4x Stereo RCA
Output1x Stereo RCA
Output impedance215 ohm
DisplayRed LED display, 51 x 20mm
Bluetooth chipBTM308
HousingBrushed Aluminium
Supply voltage230V AC
Total dimensions (With antenna + volume button)Approx. 196 x 130 x 48mm
Value / Volume-90dB à 0dB
Weight820g
ColorSilver
Power cableNOT included (available as accessories)
Package1x Audiophonics PGA2310
1x IR Remote Control (CR2032 batteries not included)
ColorSilver
ClassN/A
Remote ControlYes
25 reviews
Meilleur
Rachat du même modèle, sauf que le nouveau est bien plus performant, il y une nette préamplification que ce modèle n'avait pas vraiment avant, et la qualité du son est bien meilleure.
Je m'en sers pour contrôler le volume sur un signal ligne venant de mon PC avant l'entrée dans la console de mixage (pour avoir accès au volume à distance via la télécommande depuis la mezzanine).
Très satisfait.
This review has been posted for AUDIOPHONICS PRE-01 PGA2310 Preamplifier Volume Control Input Selector Bluetooth 5.0
Top
Ma sono est au -1 et ma cuisine au RDC, du coup j'avais besoin d'une télécommande pour piloter le volume sans avoir à descendre à chaque fois.
Produit au top, bonne pré-amplification, réponse en remote très satisfaisante.
Si je devais chercher la petite bête je dirais que par rapport au volume en direct on n'a que de la diminution possible, mais si on calibre bien sa sono, ça n'est pas un problème. Un bon gain en entrée et on se prépare la plage de volume de confort sans souci.
En nettoyant ma sono je l'ai fait tomber. Il est mort. RIP. Je viens de commander le même. Tout est dit.
L
Heel handig
Voelt betrouwbaar aan vanwege stevige afwerking en prettige bediening. Lekker veel ingangen.
Très Sympa
Il n'augmente pas la puissance du signal, mais reste très bon dans ce qu'il fait.
Le Bluetooth est très sympa..
Je l'ai donné à mon frère qui est ravie de ce produit aussi !
Vue le prix, c'est 5 étoiles sans pb !
Un préampli vraiment ?
Un bon produit pour le prix, mais je ne pense pas qu'on puisse le qualifier de préamplificateur, car il faut pousser le volume au maximum pour retrouver un volume normal.
En tant que contrôleur de volume/sélecteur de source/récepteur BT, en revanche, il fait un très bon job.
The Audiophonics PGA2310 preamplifier is an extremely versatile device at a more than affordable price. If it is first presented as a preamplifier,...
