DOUK AUDIO L1 Line Level Preamplifier
The Douk Audio L1 is a compact line preamplifier designed to boost the output level of low-voltage audio sources by up to 20 dB. It relies on an amplification circuit with adjustable gain, a wide frequency response and an interchangeable NE5532P operational amplifier, to match the signal to the requirements of various Hi-Fi devices.
Reference : 22507
39,90 €tax incl.
33,25 € tax excl.
DOUK AUDIO L1 Line Level Preamplifier NE5532P 20dB
DOUK AUDIO L1: Front view
The Douk Audio L1 is a compact line preamplifier designed to boost the output level by up to 20 dB of low-voltage audio sources. It relies on an amplification circuit with adjustable gain, a wide frequency response and an interchangeable NE5532P operational amplifier, to match the signal to the requirements of various Hi-Fi devices.
Douk Audio L1: Preamplification and adjustable gain
The Douk Audio L1 is a line preamplifier designed to boost the output level of low-voltage audio sources by up to 20 dB. Its amplification circuit operates at 26 V to provide an output voltage of ±12.5 V, allowing the level of sources such as a television, a game console, an MP3 player, a smartphone or a tablet to be aligned with that of the other devices in the setup.
Thanks to its various interfaces, the L1 fits between a source and an amplifier to compensate for an insufficient output level or to allow the use of a longer connection between components. Its adjustable gain range matches the signal strength to the system's needs, while maintaining a wide frequency response and a high signal-to-noise ratio.
Douk Audio L1: Customizable audio circuit
The double-sided printed circuit board hosts a NE5532P operational amplifier mounted on DIP8 to be interchangeable, allowing the preamplifier's sonic behavior to be adjusted by replacing the component. This architecture aims for a natural and warm reproduction, while limiting distortion when raising the signal level.
DOUK AUDIO L1: Op-amp on DIP8
DOUK AUDIO L1: In a hand
Douk Audio L1: Compact format
Housed in a low-footprint metal enclosure, the Douk Audio L1 limits its exposure to electromagnetic interference while integrating easily into a Hi-Fi setup. Its mini format is thus suited to systems requiring additional gain without adding a bulky device.
Technical specifications
Product typePreamplifier
Inputs1x Jack 3.5mm
1x RCA stereo
1x DIN 5 pins
Outputs1x RCA stereo
1x DIN 5 pins
Frequency response20Hz-20KHz ( ± 0.5dB)
SNR>80dB
THD+N0.06%
Output level±12.5V
Gain20dB
Input sensitivity150mW/50KHz @1KHz
Supply voltage5-24V DC
Dimensions87 x 63 x 48mm
Weight155g
Package1x Douk Audio L1
1x USB to DC cable
1x Jack 3.5mm to RCA cable
1x RCA stereo cable
InputDIN 5
InputJack 3.5mm
OutputDIN 5
ClassN/A
The Douk Audio L1 is a compact line preamplifier designed to boost the output level of low-voltage audio sources by up to 20 dB. It relies on an...
