SPARKOS ARIES FULL Discrete Preamplifier Headphone Amplifier
Sparkos offers with the Aries a high-end preamplifier and headphone amplifier for audiophiles looking for the best sound quality. It is based on an architecture composed solely of discrete components to ensure exceptional performance.
By buying this product you get 299 loyalty points
Reference : 14190
2 990,01 €tax incl.
2 491,67 € tax excl.
Sparkos Aries
Sparkos Aries Préamplificateur Discret Amplificateur Casque
In the heart of Sparkos Aries
The main audio circuit of the Aries is on the right side of the unit and consists mainly of two pairs of SS2590 discrete PDOs developed by the brand. The latter constitute the input and output stages, between which the impressive switched relay attenuator is revealed. No capacitors are used on the audio signal circuit and DC potential differences are managed by a DC servo.
The Aries power supply is regulated by a pair of discrete voltage regulators and the toroidal transformer is shielded with Mu Metal shielding to significantly reduce the magnetic field and humming. The AC input is universal and can operate with 120V and 240V. The signal is the ground of all inputs are switched with high quality latching relays. Switching the ground of the inputs (rather than simply connecting them together) will prevent ground loops from forming between the different connected devices.
The microcontroller that controls the attenuator and operates the screen will switch to standby mode when music is playing to further reduce potential noise.
Relay attenuator
The volume and balance controls use a switched reed relay attenuator. The choice of Reed relays greatly reduces the noise of "clicks" when relays are switched. The attenuator has 64 steps, one step corresponding to 1 dB. The film resistors used in the attenuator but also and generally on the audio circuit offer a tolerance of only 0.1%. The output impedance of the attenuator is 180Ω consistently in order to achieve a very low level of resistance noise (Johnson noise) at any volume level. Relay attenuators also provide better consistency between the volume levels of the left and right channels, essential for a true headphone listening experience.
Connectivity
The Aries offers a classic and efficient connection system that allows it to be easily integrated into an audio system. The input includes a balanced XLR and two stereo RCAs on the rear panel and a 3.5mm jack on the front panel. On the output side the Aries has a stereo RCA, a balanced XLR, as well as a 6.35mm Jack headphone output at the front. All connectors are gold plated, ensuring good conductivity and oxidation resistance.
Touchscreen
The Sparkos Aries' simple front panel features a touch screen for intuitive access to source selection and gain control. It also displays the volume attenuation level and the balance, which are adjusted using the two massive rotary knobs.
Product typeDiscrete preamplifier
Headphone amplifier
Inputs2x Single-ended stereo RCA
1x Balanced XLR
1x Jack 3.5mm
1x Balanced XLR
1x Jack 6.35mm headphone output
Discrete AOPSS2590
Gain settings+10dB
+20dB
+30dB
Relay attenuator (volume / balance)64 steps, 1dB per step
Frequency response2Hz - 350kHz (-3dB)
Precision film resistors0.1%
Max. output level14V 355mA
Transformer shieldingMu Metal
Discrete voltage regulatorsSS78XX / SS79XXX
Output impedance< 0.1Ω
High damping factor-
Headphone output impedance16-300Ω
Touchscreen
Noise1.6µV RMS @ 0dB, 20Hz-20kHz, Unweighted
Power supply capacitance per rail9400µF
Dimensions317.5 x 317.5 x 101.6mm
Power supply120V/240V 50Hz/60Hz AC
Case materialAluminium
Schuko power cableIncluded
InputXLR
InputJack 3.5mm
OutputJack 6.35mm
ClassN/A
Un fil droit avec du gain ?
C'est en tout cas ce que revendique le concepteur et c'est ce que je ressent, un effacement total devant la musique.
Voilà tout est dit.
Quelques fonctions bien pensées, une balance qui ne dégrade pas le son, une sortie casque et une sortie préampli qui peuvent fonctionner simultanément et qui sont débraillables séparément.
L'appareil ne chauffe pas du tout.
Attention a la performance du cordon secteur.
Ne manque qu'une télécommande.
This review has been posted for SPARKOS ARIES FULL Discrete Preamplifier Headphone Amplifier
Sparkos offers with the Aries a high-end preamplifier and headphone amplifier for audiophiles looking for the best sound quality. It is based on an...
