AIYIMA T1 PRO Tube Preamplifier
The AIYIMA T1 Pro is a valve preamplifier designed to adapt and condition the signal prior to a power amplifier. It utilises a hybrid architecture combining two NE5532P op-amps and two 5725 tubes, amplifying the signal whilst introducing a controlled harmonic signature, resulting in a more nuanced sound reproduction. This approach is further enhanced by the integration of a Bluetooth 5.1 module based on a Qualcomm QCC3040 chip, enabling wireless reception for greater ease of use.
Reference : 21916
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 17-11-2026.
Aiyima T1 Pro Tube Preamplifier 2x 6186 Bluetooth 5.1 aptX HD
AIYIMA T1 Pro : Front view
The Aiyima T1 Pro is a tube preamplifier designed to adapt and condition the signal prior to a power amplifier. It utilises a hybrid architecture combining two NE5532P op-amps and two 6186 tubes, amplifying the signal whilst introducing a controlled harmonic signature, resulting in a more nuanced sound reproduction. This approach is further enhanced by the integration of a Bluetooth 5.1 module based on a Qualcomm QCC3040 chip and compatible with aptX HD codec, enabling wireless reception for greater ease of use.
Designed for integration into a hi-fi system, it features adjustable bass and treble controls on the front panel, with the option to bypass these settings via a dedicated switch. Furthermore, the inclusion of a 12V trigger output enables synchronisation with other components in the system, allowing for coordinated power-up.
Product typePreamplifier
Inputs1x Stereo RCA
Bluetooth 5.1
Outputs1x Stereo RCA
1x Jack 3.5mm
OPA2x NE5532P
Tubes included6186
Compatible tubes6J1, 6J2, GE5654, 6J3, 6J4, 6J5, 6*1N, 6AK5
Bluetooth chipQCC3040
Compatible Bluetooth codecsAAC, SBC, APTX, APTX-LL, APTX-HD
Total harmonic distortion more noise (THD+N)≤0.23%
Frequency response20hz-20khz (±1db)
Signal-to-noise ratio (SNR)≥110dB
Bass/treble adjustment±6dB
Input sensitivity1V
AUX output level2.5V
Power supply12V DC / 1.5A
Dimensions250 x 220 x 60mm
Weight1.5kg
Package1x Aiyima T1 Pro
2x 6186 tubes
1x Mains power supply
OutputJack 3.5mm
ClassTube amp
AIYIMA T1 PRO Tube Preamplifier 2x 6186 Bluetooth 5.1 aptX HD
The AIYIMA T1 Pro is a valve preamplifier designed to adapt and condition the signal prior to a power amplifier. It utilises a hybrid architecture...
