By buying this product you get 125 loyalty points
With the Master 9 MK3, Audio-GD presents the latest version of its headphone amplifier/preamplifier. This model builds on the success of its predecessor, still being a dual mono Class A headphone amplifier. With this new iteration, Audio-GD has mainly worked on the miniaturisation of its amplifier, going from a 16kg model to a 7kg model, without making any concessions to the quality of sound reproduction.
The Master 9 MK3 incorporates a gain adjustment function, making it easy to adapt to any type of headphone, even the most difficult to drive.
- The "L" (Low) mode has a gain of 16dB, making it suitable for powering headphones with a sensitivity of even more than 100dB, or for use as a preamplifier.
- The 'H' (High) mode has a gain of 25dB, enabling headphones with a sensitivity of between 80 and 100dB to be powered.
The Master 9 MK3 has a dual mono architecture, so the right and left channels each benefit from an R-core transformer and 4 dedicated Class A power supply modules. The Class A modules used have a very high input impedance to prevent impurities from passing through the block and affecting the preamplifier, and a low output impedance, high speed and high linearity. The result is a very clean power supply with virtually no impact on the final sound reproduction.
The output stage uses a diamond structure for its circuit. This particular structure uses 4 transistors in a configuration reminiscent of a diamond crystal if represented schematically, it has the dual advantage of being fast and accepting high loads. Four 150W transistors are used per channel, operating in pure Class A. As a reminder, Class A amplification has the particularity of having its active components always in conduction. As a result, they amplify the input signal in its entirety, greatly limiting the total rate of harmonic distortion at the output. And so, thanks to its diamond structure and Class A operation, the Master 9 MK3 has signal processing that's both fast and distortion-free, for a result of rare quality.
The 100% discrete design of this amplifier (no OPA) is supported by a volume control that differs from conventional methods. Traditionally, volume control takes place in the input stage of the amplifier via a potentiometer to reduce the signal. The main problem with this method is that the quality of the potentiometer has a direct impact on the quality of the sound, which can easily lead to a loss of detail, channel imbalance or distortion that will later be amplified. So even with a quality potentiometer, its impact on the signal-to-noise ratio can be felt. To address this problem, Audio-GD uses an I/V converter located in the output stage of the Master 9 MK3. The task of this converter is to transform the signal current into voltage, so volume control depends on the conversion rate applied. This solution has a twofold advantage: firstly, it operates at the output stage, so has no impact on signal processing; secondly, the integrity of the original signal is preserved, since control is via a converter and not a resistor.
Finally, the Master 9 MK3 is equipped with ACSS output. This is a proprietary technology of the brand called ACSS for Audio-GD Current System Signal. Thanks to the company's expertise and know-how, this technology offers a less coloured, more detailed sound with unrivalled neutrality. When the ACSS output is used, the XLR and RCA outputs switch to mute mode.
The Master 9 MK3's remote control not only controls the preamplifier/headphone amplifier, but also an external Audio-GD DAC, if you wish to pair one with the Master MK3.
1 | Mute mode |
2 | Preamplifier Auto dim |
3 | Input source selection |
4 | Gain |
5 | Volume control |
6 | DAC controls |
Product type | Headphone Amplifier / Preamplifier |
Inputs | 1x Stéréo RCA 2x XLR 3-pin stereo 1x ACSS stereo |
Ouputs | 1x Stéréo RCA 1x XLR 3-pin stereo 1x ACSS stereo 1x Headphone output 6.3mm Jack 1x XLR 4-pin headphone output |
Signal-to-noise ratio (SNR) | > 130dB |
Total harmonic distortion (THD) | < 0.003% |
Volume control | 100 step, exponentiel |
Balanced headphone output power | 9000mW @ 40Ω 3800mW @ 100Ω 1250mW @ 300Ω 630mW @ 600Ω |
Single ended headphone output power | 2500mW @ 40Ω 1050mW @ 100Ω 350mW @ 300Ω 175mW @ 600Ω |
Preamplifier output level (max) | RCA : 10V XLR : 20V ACSS : 2.4+2.4MA |
Output impedance | 1Ω |
Input impedance | XLR : 90KΩ ACSS : < 10Ω |
Frequency response | 20Hz - 20kHz @ +/-0dB 1Hz - 220kHz @ +0dB, -3dB) |
Crosstalk | > 130dB |
Gain | Low Gain : +16 DB (XLR) High Gain : +25DB (XLR) |
Consumption | 45W |
Weight | 7kg |
Dimensions | 360 x 290 x 75mm |
Housing material | Aluminum |
Color | Silver |
Package | 1x Audio-GD Master 9 MK3 1x Power cable 1x Remote control |
Input | RCA |
Input | ACSS |
Input | XLR |
Output | XLR |
Output | ACSS |
Output | RCA |
Output | Jack 6.35mm |
Color | Silver |
Class | Class A / AB |
Remote Control | Yes |
