DENAFRIPS HADES 15TH Preamplifier Black
Elevate your audio experience with the Denafrips Hades 15TH preamplifier, a masterpiece born from an uncompromising dedication to audio perfection. Designed for discerning audiophiles, the Hades is the pinnacle of technical precision and sonic sophistication.
By buying this product you get 166 loyalty points
Reference : 21421
1 669,00 €tax incl.
1 390,83 € tax excl.
Denafrips Hades 15Th Discrete Balanced Preamplifier Pure Class A Black
Photo of DENAFRIPS HADES 15TH
Elevate your audio experience with the Denafrips Hades 15Th preamplifier, a masterpiece born from an uncompromising dedication to audio perfection. Designed for discerning audiophiles, the Hades is the pinnacle of technical precision and sonic sophistication.
Developed and manufactured with precision and care, the Hades features a fully discrete, fully balanced pure Class A line stage.
Its 60-step attenuator, controlled by a microprocessor and equipped with precision-matched resistors, ensures perfect channel balance and extremely low distortion, measured at just 0.00023%. The result is sound of incredible purity, clarity, and precision.
All of the Hades' components are housed in a sturdy, modern aluminum chassis. It also features a front panel display to show the selected volume level.
KEY FEATURES:
  • Pure Class A. High-quality line stage, completely discrete and fully balanced.
  • Microprocessor-controlled 60-step relay volume attenuator.
  • High-precision resistors and components throughout with perfect channel balance and low distortion.
  • Remote control.
The structure of the Denafrips Hades 15TH
#1 Discrete Class A gain
The gain is achieved using a network of resistors and balanced transistors.
#2 Attenuator
Relay with 60 steps controlled by microcontroller (CPU).
#3 Proprietary Type-O Transformer
This is not a universal transformer, but one specially designed for the Class A architecture and high-precision components of this preamplifier. This design prevents performance losses caused by “excessive or insufficient power supply,” ensuring that every unit of electrical energy is used precisely for signal amplification.
#4 Low-noise linear power supply capacitors
A set of custom-made low-noise linear capacitors suppresses ripple interference from the power supply source; combined with a linear power supply architecture, it reduces power supply noise to an extremely low level.
Denafrips Hades 15Th overview
Denafrips Hades 15TH overview
1Input selection / ON-OFF button
2Screen
3Volume control
4Analog inputs: 1x RCA / 2x XLR
5Analog outputs: 1x RCA / 1x XLR
6115V/230V AC power port
Product typeDiscrete balanced preamplifier
ArchitecturePure class A
AttenuatorMicroprocessor-controlled 60-step relay attenuator
Inputs2x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Input impedanceSingle-ended: 12.2kΩ
Balanced: 60kΩ
Output levelRCA: 2Vrms
XLR: 4Vrms
Output impedanceSingle-ended: 200Ω
Balanced: 400Ω
GainUnit gain, 0dB
Frequency response10Hz - 85kHz (-0.3dB)
THD+N0.00045%
SNR122dB
Dynamic range> 121dB
Crosstalk-110dB
Supply voltage100-240VAC 50/60Hz
Consumption25W
Dimensions322 x 392 x 74mm
Weight9kg
Package1x Denafrips Hades 15TH
1x Remote control
InputXLR
ClassClass A / AB
Remote ControlYes
Download
DENAFRIPS HADES 15TH Discrete Balanced Preamplifier Pure Class A Black
Elevate your audio experience with the Denafrips Hades 15TH preamplifier, a masterpiece born from an uncompromising dedication to audio perfection....
