DOUK AUDIO T8 PRO Tube Equalizer Preamplifier
The DOUK Audio T8PRO is a tube preamplifier featuring a 7-band equalizer. The T8PRO is therefore able to precisely control each frequency band (50Hz / 125Hz / 315Hz / 750Hz / 2KHz / 6KHz / 16KHz) for highly personalized sound reproduction. The equalization is managed by a network of resistors and NE5532 OPAs for precise and reliable sound reproduction. In addition, the T8PRO uses two 6H1N-BN tubes coupled with JRC 2068D DIP8 OPAs, offering preamplification with a warm and smooth sound.
Reference : 21114
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 01-12-2026.
Douk Audio T8 PRO Tube Preamplifier 7-Band Equalizer
DOUK AUDIO T8PRO picture
The Douk Audio T8PRO is a tube preamplifier featuring a 7-band equalizer. The T8PRO is therefore able to precisely control each frequency band (50Hz / 125Hz / 315Hz / 750Hz / 2KHz / 6KHz / 16KHz) for highly personalized sound reproduction. The equalization is managed by a network of resistors and NE5532 OPAs for precise and reliable sound reproduction. In addition, the T8PRO uses two 6H1N-BN tubes coupled with JRC 2068D DIP8 OPAs, offering preamplification with a warm and smooth sound. Added to this is the ability to balance the channels using a potentiometer located on the far right of the front panel. In terms of connectivity, it has all the essentials with an RCA input, a balanced XLR output, and two outputs of the same type. Accessible and powerful, this tube equalizer preamplifier will delight music lovers looking for a warm and customizable sound.
DOUK Audio T8PRO overview
1Power switch / Input selector
250Hz frequency equalization (±6dB)
3125Hz frequency equalization (±6dB)
4315Hz frequency equalization (±6dB)
5750Hz frequency equalization (±6dB)
62kHz frequency equalization (±6 dB)
76KHz frequency equalization (±6dB)
816kHz frequency equalization (±6 dB)
950Hz frequency equalization (±6dB)
10Volume control
11Channel balance
12XLR input
13RCA input
14RCA output
15XLR output
1612V DC power supply
Product typePreamplifier
Equalizer
Tubes2x 6H1N-BN
OPAJRC 2068D
OPA equalizerNE5532
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Frequency response20Hz-20KHz (±1dB)
Equalization frequencies50Hz / 125Hz / 315Hz / 750Hz / 2KHz / 6KHz / 16KHz
Input sensitivityRCA: 0.775Vrms
XLR: 1.5Vrms
Output levelRCA: 1.2Vrms
XLR: 2.4Vrms
THD0.01%
SNR≥ 98dB
Power supplyDC 12V (≥2A)
Dimensions186 x 128 x 38mm
Weight685g
Package1x Douk Audio T8 PRO
2x 6H1N-BN tubes
1x 12V 2A DC jack power adapter
InputXLR
ClassTube amp
DOUK AUDIO T8 PRO Tube Preamplifier 7-Band Equalizer
The DOUK Audio T8PRO is a tube preamplifier featuring a 7-band equalizer. The T8PRO is therefore able to precisely control each frequency band...
