E1DA COSMOS SCALER Low Noise Variable Gain Balanced Preamplifier for COSMOS ADC
The Cosmos Scaler is a low-noise, variable-gain preamplifier designed specifically for the brand's Cosmos ADCs. It incorporates quality components such as two OPA1612 and two OPA1656 AOPs. It features 16 gain positions from 0 to 26dB, plus an automatic adjustment position.
Reference : 18315
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 13-06-2025.
E1DA COSMOS SCALER
E1DA COSMOS SCALER Low Noise Variable Gain Volume Controller Preamplifier for COSMOS ADC
The Cosmos Scaler is a low-noise, variable-gain preamplifier designed specifically for the Cosmos ADCs. It incorporates quality components such as two OPA1612 and two OPA1656 OPAs, Viking resistors, Murata and Samsung COG capacitors. In terms of connectivity, it features two balanced input channels accepting 3.5mm TRS 3-pole jacks with an impedance of 200/100kOhms (balanced/unbalanced) and up to 20/10Vrms (balanced/unbalanced). A mono mode is also available using the left-hand 3.5mm jack input. Outputs are two 3-pole TRS balanced 3.5mm jack connectors with an output impedance of 20/10Ohms (balanced/unbalanced) and power up to 20/10Vrms, depending on whether the signal is balanced or unbalanced. The Cosmos Scaler has 16 gain settings from 0 to 26dB and an automatic adjustment position.
LEDs on the front panel indicate the output power of each channel.
  • 1.7Vrms < Blue LED < 4.5Vrms
  • 4.5Vrms < Green LED < 10Vrms
  • Red LED > 10Vrms
Power for the Cosmos Scaler is supplied via a USB-C connector (+5V, idle current <500 mA).
Please note that for fully balanced operation, the E1DA COSMOS SCALER requires 3-pole TRS jack to XLR cables for connection to the COSMOS ADC.
Mono mode operation
The Cosmos Scaler can be operated in mono mode via the left channel's 3.5mm jack input. The signal is automatically transferred to the right channel for mono operation with the Cosmos ADC. The Cosmos APU's 3.5mm jack to XLR cables work in mono mode between the Cosmos Scaler and Cosmos ADC.
Gain settings
The rotary knob provides access to 16 gain adjustment positions: 0, 7, 10.7, 13.38, 15.788, 17.38, 18.673, 19.844, 21.08, 21.98, 22.764, 23.513, 24.336, 24.965, 25.527, 26.078. In the "Auto" position, the Cosmos Scaler operates as an ultra-fast autoranger (100ms), targeting the left channel output at 4.5Vrms. The right channel output voltage is ignored. The valid autoranger frequency range is 20Hz-20kHz.
Product typePreamplifier volume controller
Amplification components2x OPA1612
2x OPA1656
Inputs1x Balanced input on 2x jack 3.5mm TRS 3-poles
1x Mono input on 3.5mm jack (left 3.5mm jack input)
Outputs1x Balanced output on 2x jack 3.5mm TRS 3-pole
Gain levels16 levels: 0, 7, 10.7, 13.38, 15.788, 17.38, 18.673, 19.844, 21.08, 21.98, 22.764, 23.513, 24.336, 24.965, 25.527, 26.078.
Auto gain
Frequency response2hZ -570kHz @ 26dB gain (+0.5/-3dB)
2Hz-7/11kHz @0dB gain (Scaler output is stable up to 7m of microphone cable)
Residual noise250nVrms (A) @ 26dB gain
CrosstalkL->R -133db, R->L -158db @ 1kHz unused input short-circuited @0db gain
Power supplyUSB-C (+5V, iddle current <500 mA).
Dimensions104 x 61 x 39mm
Weight160g
Package1x E1DA COSMOS SCALER Preamplifier Volume Controller
InputJack 3.5mm
OutputJack 3.5mm
ClassN/A
A very useful accessory for E1DA Cosmos ADCiso
Accurately correspondent to specifications, perfectly fit for laboratory use, excellent support with ample explanations by the designer in Audiosciencereview's dedicated thread. Five stars.
This review has been posted for E1DA COSMOS SCALER Low Noise Variable Gain Balanced Preamplifier for COSMOS ADC
The Cosmos Scaler is a low-noise, variable-gain preamplifier designed specifically for the brand's Cosmos ADCs. It incorporates quality...
