It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money).
It is difficult to open and change the OPAs. Acrylic side plates are annoying.
The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The ZP3 is ideally suited to audiophile and professional use, given its performance and connectivity, including TRS/XLR combo jack inputs and a balanced XLR output. In addition, there are controls for low and high tones and channel balance, for tailor-made rendering. Three additional features are also available. These include a subwoofer output (20Hz-200Hz) for installation of a 2.1-channel system, as well as an XLR/RCA frequency crossover switch (20Hz-20kHz / 80Hz-20kHz / 120Hz-20kHz) and a bypass mode switch. All in all, the ZP3's performance and functionality make it the preamplifier of choice.
1 | Power / Input selection |
2 | Input indicator |
3 | Channel balance adjustment |
4 | Bass control |
5 | Treble adjustment |
6 | Volume control |
7 | 2x RCA input |
8 | Balanced TRS/XLR combo jack input |
9 | RCA output |
10 | SUB output |
11 | XLR output |
12 | Trigger IN/OUT |
13 | Switching on / IEC power supply |
14 | Bypass switch |
15 | RCA/XLR frequency cut-off switch |
Product type | Preamplifier |
AOP | NE5532 |
Inputs | 2x Single-ended stereo RCA 1x Balanced Jack TRS/XLR combo |
Outputs | 1x Single-ended stereo RCA (20Hz-20kHz / 80Hz-20kHz / 120Hz-20kHz) 1x Balanced stereo XLR (20Hz-20kHz / 80Hz-20kHz / 120Hz-20kHz) 1x Subwoofer output (RCA) (20Hz-200Hz) |
XLR balanced output specifications | |
SNR | ≥ 112dB |
Dynamic range | ≥ 112dB |
THD+N | ≤ 0.0007% |
Noise floor | ≤ 6uV |
RCA output specifications | |
SNR | ≥ 115dB |
Dynamic range | ≥ 115dB |
THD+N | ≤ 0.0008% |
Noise floor | ≤ 4uV |
Power supply | AC 100-240V |
Package | 1x Fosi Audio ZP3 preamplifier 1x IR remote control 1x 12V trigger cable 1x Mains power cable |
Input | Jack 6.35mm |
Input | RCA |
Input | XLR |
Output | XLR |
Output | RCA |
Output | Subwoofer |
Color | Black |
Class | N/A |
Remote Control | Yes |
Average votes 4.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Robert C.
Robert g.
Nicolas B.
