Passive RCA preamplifier / Analog volume control ALPS RK27
Analog volume controller with rotary potentiometer. Stereo RCA connectors. Very compact aluminum housing.
4.9 / 5
Reference : 14295
46,90 €tax incl.
39,08 € tax excl.
Shipping date: 08-05-2026.
passive preampLIFIER
Analog Volume Control ALPS RK27
Attenuation passive high fidelity volume
This passive preamplifier uses a 50K ALPS RK27 rotary potentiometer and offers a passive attenuation for controlling analog signal level.
Simple and compact, it has a stereo RCA input and a stereo RCA output (unbalanced) on its rear face, with a large volume knob on its front panel. All connectors are gold plated to provide excellent conductivity.
The circuit is protected by a sturdy aluminum housing that prevents noise or interference in the signal.
TypePassive Volume Control
ResistanceRotary potentiometer 50K ALPS RK27
Inputs1x RCA unbalanced Stereo
Outputs1x RCA unbalanced Stereo
HousingAluminum
Dimensions64 x 42 x 100 mm
Weight306g
10 reviews
Passive RCA Volume Pot.
This passive volume pot, purchased to control a SMSL SU1 DAC, feeding a Nord Two ICE1200AS2 Stereo Power Amplifier.
The volume pot. works fine, with no distortion, and the sound is excellent.
My main reason for the purchase was that I like the tactile feel of a manual volume control, rather than a remote or software control of the volume.
The control is precise and smooth, and the unit it self is nicely weighted.
As a bonus, there was an RCA/RCA 1.5 metre cable included in the box.
All of the documentation supplied was in the Chinese language, but installing the unit is self explanatory.
Audiophonics service was as usual was very prompt, and I also appreciate the economical delivery charge.
I would recommend the purchase of this passive volume pot.
This review has been posted for Passive RCA preamplifier / Analog volume control ALPS RK27
Parfait
J’ai acheté ce petit potentiomètre atténuateur pour le mettre en entrée amplificateur de mon intégré dont la partie préamplificateur/ sélecteur entrée dysfonctionne. Il remplit tout à fait sa fonction avec une source streamer branchée directement dessus. La conception est robuste, très fiable dans du métal solide. Le potentiomètre est fluide tout en étant suffisamment stable . Je redécouvre le plaisir de l’écoute de mon ancien amplificateur intégré.Je recommande .
Excellent
Placé entre un tuner fm/dab dont le volume de sortie est très élevé et un preampli dont la télécommande fonctionne par increméments assez larges il me permet d’atténuer le niveau et de ne plus passer de 0 à un son trop fort en un appui sur la touche de volume. Avec du matériel haut de gamme dont l’écoute à bas volume est excellente cela permet de gérer les sources pêchues. Evidemment il faut encore deux câbles et quand on y met le prix… en tout cas je n’entends pas de perte de qualité.
Erreur sur la notice du matériel.
La valeur de résistance annoncée n'est pas de 50Kohms mais de 100Kohms. Mais très bon matériel
Simple, Robuste et Efficace - Mais...
... Mais attention à vérifier la valeur d'impédance de l'atténuateur à la réception (20kOhm attendu, livré en 50kOhm, problème réglé avec Audiophonics).
