XDUOO MH-02 Tube Preamplifier / Headphone Amplfier / DAC
Particularly versatile, xDuoo's MH-02 is a tube preamplifier, headphone amplifier and USB DAC in one. Its preamplifier stage is equipped with a pair of 6J1 tubes for a warm, musical sound. The device's Class A buffer uses transistors to deliver high power output and greater sonic precision and dynamics.
Reference : 19326
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 24-06-2025.
xDuoo MH-02 Tube Preamplifier / Headphone Amplifier / DAC CS43131 32bit 384kHz DSD256
xDuoo MH-02: Front view
Particularly versatile, xDuoo's MH-02 is a tube preamplifierheadphone amplifier and USB DAC in one. Its preamplifier stage is equipped with a pair of 6J1 tubes for a warm, musical sound. The device's Class A buffer uses transistors to deliver high power output and greater sonic precision and dynamics. The MH-02 is thus also capable of accompanying the vast majority of headphones, thanks to an output power of 1300mW at 32Ω and three headphone outputs in 3.5mm jack, 4.4mm balanced jack and 6.35mm jack formats.
In addition to its stereo RCA input and output, the MH-02 features a USB-C digital input. This is associated with a CS43131 DAC chip capable of supporting high sampling rates, up to PCM 32bit 384kHz and DSD256, while ensuring low noise levels.
xDuoo MH-02: Description diagram
1Jack 6.35mm headphone output
2Jack 4.4mm balanced headphone output
3Jack 3.5mm headphone output
4Volume control
5Gain selector
6AUX RCA input
7AUX RCA output
8USB-C input
9Power input
10Power switch
Product typeTube preamplifier
Headphone amplifier
DAC
Inputs1x USB-C
1x Stereo RCA
Outputs1x Stereo RCA
1x Jack 3.5mm single-ended headphone output
1x Jack 4.4mm balanced headphone output
1x Jack 6.35mm single-ended headphone output
DAC chipCS43131
Tubes2x 6J1
DSD up to DSD256
Headphone output power1300mW @ 32Ω
Frequency response10Hz - 60kHz (±0.5dB)
Gain (switchable)+12/18dB
THD+N≤ 0.8% (1kHz, 32Ω)
SNR118dB
Crosstalk≥ 70dB
Supply voltage12VDC 2A (Jack 5.5 / 2.5mm)
Dimensions12 x 7.8 x 4cm
Weight350g
Housing materialsAluminum
colorGray
Package1x xDuoo MH-02
1x 12V power adapter
1x USB-C to USB-A 1m cable
OutputJack 6.35mm
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
ColorGray
ClassN/A
XDUOO MH-02 Tube Preamplifier / Headphone Amplifier / DAC CS43131 32bit 384kHz DSD256
Particularly versatile, xDuoo's MH-02 is a tube preamplifier, headphone amplifier and USB DAC in one. Its preamplifier stage is equipped with...
