Transformer for PCB UI 39/13,5 2x6V 1.67A 18VA
This molded transformer is particularly suitable for PCB integration. It will allow you to feed small systems properly.
Reference : 12651
12,90 €tax incl.
10,75 € tax excl.
Encapsulated Transformer
UI 39/13,5 2x6V 1,67A 18VA
transformer
This encapsulated transformer is ideal for PCB mounting. It will allow you to provide your system with quality food, offering a two-compartment internal design.
Power18VA
Input voltage2x115V / 1x130V
Frequency50/60Hz
Output voltage2x6V 1,67A
Dimensions68 x 28mm
Possible assemblies
Caution: for 230V installation it is absolutely necessary to connect the 115V pins.
Schema 1
Input 230V / Output 2x6V
Schema 2
Input 230V / Output 1x6V
Schema 3
Input 115V / Output 2x6V
Schema 4
Input 115V / Output 1x6V
ColorBlue
Primary voltage (V)230.0
Primary voltage (V)2x 115.0
Secondary voltage (V)6.0
Power (VA)18.0
