Pack Eversolo DAC-Z8 + Eversolo AMP-F2 Amplifier + Audiophonics Wire XLR 30cm
We offer you an Eversolo product pack consisting of the DAC-Z8, the AMP-F2 amplifier and a pair of Audiophonics Wire XLR interconnect cables for balanced connection. This high-end package is perfect for anyone wishing to benefit from a large power reserve and a system capable of supporting high-resolution streams. Coupled with passive speakers, this combination is capable of reproducing the best of your music.
By buying this product you get 139 loyalty points
Reference : 19493
1 399,00 €tax incl.
1 165,83 € tax excl.
Instead of 1 528,90 €
Pack content
Pack Eversolo Eversolo AC-Z8 + Eversolo AMP-F2 Amplifier + Audiophonics Wire XLR 30cm
Pack Eversolo DAC-Z8 + Eversolo AMP-F2 Amplifier + Audiophonics Wire XLR Cables 30cm
Eversolo DAC Z-8 : DAC ES9038Pro XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
EverSolo's DAC-Z8 is a high-end DAC that is extremely powerful. It embeds high-end components with notably an ESS ES9038Pro digital/analog conversion chip and a XMOS XU316 USB interface allowing it to support high-resolution audio streams and to provide a clear and detailed sound reproduction. The DAC-Z8 also offers a wide range of features that make it a versatile and efficient device.
View complete product page of EVERSOLO DAC-Z8 Eversolo DAC Z-8
EverSolo AMP-F2: Class D Amplifier 2x250W 4Ω / 1x450W 2Ω
The EverSolo AMP-F2, developed in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. The result is a high power reserve of up to 2x250W RMS power at 4 Ohm (1% THD), great dynamics and extremely accurate sound. The all-new SAPS switch-mode power supply provides the audio circuit with a clean electrical signal, ensuring low noise and distortion. Bridgeable, the AMP-F2 is a versatile model that can be used in stereo or mono.
View complete product page of EverSolo AMP-F2 EverSolo AMP-F2
Audiophonics Wire: Stereo XLR Interconnect Cable Gold-plated OFC Copper 30cm (Pair)
These balanced XLR modulation cables, assembled in our workshop in France, comprise a Mogami Neglex W2549 cable and Neutrik NC3FXX-B and NC3MXX-B XLR connectors. They feature OFC copper conductors and integral shielding, while the connector contacts are 24K gold-plated for enhanced resistance to corrosion and oxidation.
View complete product page of AUDIOPHONICS WIRE XLR 30 cm AUDIOPHONICS WIRE XLR 30 cm
Technical  characteristics
Products typeDAC + Power amplifier + Modulation cables
Package contents1x Eversolo DAC-Z8
1x EverSolo AMP-F2
1x Audiophonics Wire XLR 30cm (pair)
DAC-Z8 Specifications
Product typeDAC
InputsBluetooth 5.0
1* USB-B
1* USB-C
1* Optical Toslink
1* Coaxial
Outputs1* Balanced stereo XLR
1* Single-ended stereo RCA
1* Jack 6.35mm headphone output
DAC chipES9038Pro
USB interfaceXMOS XU316
OPA10* OPA1612
Bluetooth receiverQualcomm QCC5125
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA
Optical / Coaxial : PCM upto 24bit 192kHz, DSD DoP up to DSD64, MQA
Supported Bluetooth codecsSBC
AAC
aptX
aptX LL
aptX HD
LDAC
ScreenLCD 3"
Control app
Recommended headphone impedance16-300Ω
XLR output performances
Output level4.1Vrms @ 0dBFS
THD+N (A-Weighted)0.000062% @ 1kHz (-124dB @ 1kHz)
THD+N (No-Weighted)0.000069% @ 1kHz (-123dB @ 1kHz)
Noise (No-Weighted)< 1.2µVrms
SNR (No-Weighted)133dB @ 1kHz
Frequency response20Hz-20kHz (±0.1dB)
Crosstalk-130dB @ 1kHz
DNR (No-Weighted)133dB @ 1kHz
RCA output performances
Output level2.3Vrms @ 0dBFS
THD+N (A-Weighted)0.000086% @ 1kHz (-121dB @ 1kHz)
THD+N (No-Weighted)0.000097% @ 1kHz (-120dB @ 1kHz)
Dynamic range (No-Weighted)133dB @ 1kHz
Headphone output performances (Low gain mode)
Output level1.2Vrms @ 0dBFS
Output power45mW @ 32Ω
THD+N (A-Weighted)0.00015% @ 1kHz (-116dB @ 1kHz)
THD+N (No-Weighted)0.00018% @ 1kHz (-115dB @ 1kHz)
Noise (No-Weighted)< 2µVrms
SNR (No-Weighted)124dB @ 1kHz
Dynamic range (No-Weighted)119dB @ 1kHz
Headphone output performances (High gain mode)
Output level2.8Vrms @ 0dBFS
Output power26mW @ 300Ω
THD+N (A-Weighted)0.00016% @ 1kHz (-116dB @ 1kHz)
Dynamic range (No-Weighted)124dB @ 1kHz
Supply voltage110~240VAC 50/60Hz
Consumption9W
Dimensions (L*P*H)270*187*50mm
Package1* EverSolo DAC-Z8
1* Remote control
1* Power cable
1* USB cable
AMP-F2 Specifications
Product typeAmplifier
Amplification typeClass D
Output power2x250W RMS @ 4Ω (1% THD)
2x145W @ 8Ω (1% THD)
Output power (BTL)280W RMS @ 4Ω (1% THD)
450W RMS @ 2Ω (1% THD)
InputsSingle-ended RCA
Balanced XLR
OutputsSpeaker terminals (beryllium copper)
Gain21.5dB
Frequency response10Hz - 20kHz (-1dB)
Max. output current per channel16.5A
33A (BTL)
THD0.003% @ 10W, 1kHz
SNR> 110dBA @ 4Ω, 260W
Input impedanceRCA : 11kΩ
XLR : 22kΩ
Input sensitivity2.7V
Output impedance0.136Ω (5Hz à 100kHz)
Minimum load impedance0.8Ω
Damping factor100
Balanced circuit
Trigger 5-12VInput and output
Supply voltage115VAC - 230VAC (switchable)
Heat65BTU / hour
ConsumptionStandby: ≤ 0.5W
Idle: ≤ 14W
Max: 900W
Dimensions270 x 228 x 80mm
Housing materialAluminum
Weight3.65kg
Audiophonics Wire XLR Specifications
Product typeStereo XLR cables (pair)
Connectors2* Male XLR
2* Female XLR
Length30cm
Mogami Neglex W2549 cable characteristics
Conductors materialOFC copper
Conductors section0.339mm² (22AWG)
Conductors diameterØ1.9mm
Insulation materialXLPE (cross-linked polyethylene)
Outer sheathPVC
Neutrik connectors characteristics
Contacts materialCopper alloy
Contacts plating24k gold
Shell materialPolyamide
We offer you an Eversolo product pack consisting of the DAC-Z8, the AMP-F2 amplifier and a pair...
