By buying this product you get 299 loyalty points
This Tonewinner pack includes the AD-7300HD audio/video processor and home theater preamplifier, plus the AD-7300PA+ power amplifier. The result is an extremely powerful, high-performance home theater system. What's more, both devices feature a unique design for aesthetic integration into your audio system.
The Tonewinner AT-7300HD is a 13-channel audio/video processor and preamplifier, ideal for home theater integration in configurations up to 7.2.4. It supports all current audio formats, including Dolby Atmos, Dolby True HD, DTS:X and DTS Master. Similarly, the AT-7300HD accepts video streams up to 4K UHD 60Hz and is compatible with HDR, HDR10 and Dolby Vision technologies. This means you can enjoy the latest and greatest formats available for the most immersive sound and visual experience possible.
FIND OUT MORE ABOUT THE TONEWINNER AD-7300HD
The Tonewinner AD-7300PA+ is a 7-channel Class AB power amplifier, ideal for home theater integration. Capable of developing significant power, measured at 584W RMS for one channel powered at 4Ω or 7x190W for 7 channels powered at 8Ω, this amplifier offers great dynamics and ensures low noise levels.
FIND OUT MORE ABOUT THE TONEWINNER AD-7300PA+Technical characteristics
| General | |
| Product type | AV processor + power amplifier pack |
| Tonewinner AD-7300HD specifications | |
| Product type | AV processor Home theater preamplifier |
| Channels | 7.2.4 (13 channels) |
| Inputs | Bluetooth 6* HDMI 2.0 3* Stereo RCA 3* Stereo RCA (karaoke) 2* Coaxial 2* Optical Toslink 1* Micro SD slot 1* Mini USB (USB Audio) 1* USB-A (USB Host) 2* Microphone inputs (karaoke) |
| Outputs | Bluetooth 2* HDMI 2.0 (with 1 eARC) RCA XLR |
| Other connectors | 1* RS232 1* 5V trigger output Connectors for measuring microphone |
| Supported audio formats | Dolby Atmos Dolby True HD Dolby Digital Plus Dolby Digital Dolby Mat DTS/X DTS Master DTS Hi-Res DTS ES DTS NEO6 |
| Supported video formats / resolutions | 4K UHD 60Hz 3D Dolby Vision HDR10 / HDR10+ HLG |
| HDCP version | 2.2 |
| eARC support | |
| CEC support | |
| Automatic EQ calibration | |
| Input impedance | 20kOhm |
| Output impedance | 100 Ohm |
| Gain | >= 13dB |
| THD | <= 0.02% (A-wt, 1kHz) |
| SNR | >= 98dB (A-wt) |
| Frequency response | 10Hz-50kHz (+1/-3dB) |
| Channel separation | >= 80dB |
| Crosstalk | >= 80dB |
| Supply voltage | 100-240VAC 50/60Hz |
| Dimensions | 440*330*130mm |
| Weight | 5.5kg |
| Color | Black |
| Tonewinner AD-7300PA+ specifications | |
| Product type | Power amplifier |
| Amplification type | Class AB |
| Channels | 7 |
| Inputs | 7* Mono single-ended RCA 7* Mono balanced XLR 1* Trigger input 1* LINK input |
| Outputs | 7* Speaker terminals |
| Output power | 584W RMS @ 1 channel driver, 4Ω, 20Hz-20kHz, THD < 0.1% 307W RMS @ 2 channels driven, 8Ω, THD < 0.1% 500W RMS @ 2 channels driven, 4Ω, THD < 0.1% 190W RMS @ 7 channels driven, 8Ω, THD < 0.1% |
| SNR | >= 100dB (A-wt) |
| THD | <= 0.09% (1kHz) |
| THD+N | < 0.006% @ 100W RMS, 1kHz, 8 Ohm |
| Frequency response | 20Hz-50kHz (+1/-3dB) |
| Rated impedance | 8 Ohm |
| Gain | 28dB |
| Damping factor | > 149 @ 8 Ohm |
| Input sensitivity | 1.5V @ 8 Ohm |
| Supply voltage | 110-230VAC 50/60Hz |
| Dimensions | 440*445*197mm |
| Weight | 25kg |
| Color | Black |
| Input | SPDIF |
| Input | Bluetooth |
| Input | HDMI |
| Input | USB |
| Input | XLR |
| Input | Optical |
| Input | Micro SD |
| Input | RCA |
| Output | Bluetooth |
| Output | Speaker terminal |
| Output | HDMI |
| Output | HDMI eARC |
| Output | RCA |
| Output | XLR |
| Color | Black |
| Channel | 13 |
| Class | Class A / AB |
| Amplifier chip | Transistors |
| Power (W) | 500.0 |
| Power (W) | 580.0 |
| Power (W) | 300.0 |
| Power (W) | 190.0 |
| Remote Control | Yes |
