Bruno V.
Au top !!!
Bonjour à tous. Cette fiche est vraiment remarquable. Très bien construite et bien meilleure qu'une grande marque bien...
Niels G.
PS. Solid performer
This little CD transport will perform even better, if you give it an external linear analogue power supply ( like...
Sodobne tehnologije d.o.o. B.
E1DA 9039 is a great USB DAC for listening music on the go
This USB DAC has great sound, sandblasted, anodized aluminum chassis looks great and is not conspicous, in hands it feels fine....
AUDALYTIC HP70 Headphone Amplifier Preamplifier Balanced Silver - reviews - There are 2 reviews.
Massimiliano G.
very good value for money, but needs good matching with power amp
Despite the size the HP70 is a rather solid and well built item; much better in real life than in a picture. I bought it to use it in a second system but I first tested it in my main system, with a Lector 0.6T CD player, Norma power amp and Spendor A7 speakers. Its gain was set at the maximum (+28dB) but I noticed that in order to have a familiar sound pressure level I had to use volume levels of about 70/100 or more. Even removing the psychological effect of rotating the volume knob up to there, I thought it was giving me not much useful range with the volume. The sound quality was very good indeed: it was a very clean (no background noise at all) and very detailed presentation, pretty neutral but not too cold, really impressive considering the size and value of the object. Then I tested it on the other system (Thorens TD124/Denon DL110, Manley Chinook, XTZ Edge power amp and Diapason Adamants speakers), and here the situation was much better. The pressure was more convincing. The volume level was around 60/100, still a bit high but more manageable. I guess the key is a different input sensitivity of the power amp. So I have decided to keep it. I will use it mainly as a preamplifier. Probably as headphones amp it is more universal, but if you want to use it as line preamp have a look at the input sensitivity of your power amp: 2V or close can be too low sensitivity.
KONSTANTINOS L.
Very satisfied
I use it only as a headphone amplifier. The 4 different headphones - three dynamic and one planar - perform excellently. After hours of listening, it does not heat up much. I noticed a big difference when I used the audiophonics lpsu25 power supply instead of the mains supply. As if I were listening to two different audalitic! The minuses - expected at this price - are the lack of presets, e.g. for gain and the absence of equalizer, crossfeed. With power from a linear power supply, the amplifier performs excellently.
The Audalytic HP70 is a high-end headphone amplifier and preamplifier designed to deliver exceptional sound quality thanks to its fully balanced...
