The O-Noorus D4 Pro is a stereo integrated amplifier capable of driving a 2.1 system with a subwoofer. Its TPA3255 amplification with PFFB technology delivers up to 200W of peak power per channel, while its adjustable filters allow the frequency distribution between speakers and subwoofer to be tailored.
Designed for Hi-Fi installations as well as TV-based systems, it offers numerous input sources, including HDMI ARC, Bluetooth 5.4, USB and analog and digital inputs. This connectivity, complemented by a three-band equalizer, makes it easy to integrate and to adjust the sound according to the equipment used.
The O-Noorus D4 Pro is a stereo integrated amplifier that can operate in a 2.1 configuration with a dedicated subwoofer output. Based on a TPA3255 chip and PFFB (post-filter feedback) technology, it delivers up to 200W per channel of peak power. The manufacturer specifies distortion below 0.005% and a signal-to-noise ratio above 98dB.
The D4 Pro features independent high-pass and low-pass filters, as well as adjustable crossover frequencies to match the speakers and subwoofer to the system configuration. A three-band equalizer also allows the sound to be adjusted to listening preferences and room acoustics.
Its selectable sources include Bluetooth 5.4, USB, optical, coaxial, RCA and balanced inputs, and HDMI ARC. The HDMI ARC connection allows the amplifier's volume to be synchronized with the TV, while the variety of inputs makes it easy to integrate into a Hi-Fi or audiovisual installation.
Technical specifications
| Specifications | |
| Product type | Integrated amplifier |
| Inputs | 1x Stereo RCA 1x Coaxial 1x Stereo 6.35mm jack 1x HDMI ARC 1x USB-C 1x Toslink optical |
| Outputs | 1x Speaker terminal 1x RCA (Subwoofer) |
| Total harmonic distortion (THD) | ≤ 0.004% @ 1KHz 5W |
| SNR | ≥ 90dB @ 1KHz 5W ≥ 106dB @ 1KHz 120W |
| SINAD | 90dB @ 1KHz 5W |
| Frequency response | 20Hz-20kHz |
| Amplification chip | TPA3255 |
| Output power | 2x 200W @ 4Ω |
| Recommended speaker impedance | 2-8Ω |
| General | |
| Supply voltage | 24-48V DC via Jack DC 5.5/2.5mm |
| Dimensions | 180 x 158 x 40mm |
| Weight | 750g |
| Color | Black |
| Package | 1x O-Noorus D4 Pro 1x Remote control (Power supply not included) |
| Input | RCA |
| Input | SPDIF |
| Input | HDMI ARC |
| Input | USB |
| Input | Jack 6.35mm |
| Input | Optical |
| Output | Subwoofer |
| Output | Speaker terminal |
| Color | Black |
| Channel | 2.1 |
| Class | Class D / T |
| Amplifier chip | TPA3255 |
| Power (W) | 200.0 |
| Remote Control | Yes |
