VIABLUE NF-B T8 RCA Subwoofer Interconnect Cable 2.5m
New
The Viablue NF-B is a coaxial RCA interconnect cable designed to carry the signal between an amplifier and a subwoofer. Its AWG 14 OFC copper conductor is combined with a triple shielding structure and a stated capacitance of 125 pF/m, in order to limit interference pickup during connection.
By buying this product you get 22 loyalty points
Reference : 22798
224,99 €tax incl.
187,49 € tax excl.
Shipping date: 01-12-2026.
Viablue NF-B RCA to RCA Subwoofer Cable OFC Copper Triple Shielding and Ferrite Filter 2.5m Cobra
VIABLUE NF-B: Front view
The Viablue NF-B is a coaxial RCA interconnect cable designed to carry the signal between an amplifier and a subwoofer. Its AWG 14 OFC copper conductor is combined with a triple shielding structure and a stated capacitance of 125pF/m, in order to limit interference pickup during connection.
Fitted with 24-carat gold-plated Viablue T8 connectors and a ferrite filter, it suits Hi-Fi and home cinema systems with a dedicated RCA subwoofer link. Its flexible braided sleeve makes installation easier, while its construction is intended to preserve the signal in common electronic environments.
Viablue NF-B: Designed for low frequencies
The Viablue NF-B is an RCA interconnect cable specifically intended for connecting a subwoofer. Its coaxial construction combines a solid central conductor, made of fine OFC copper strands, with a dielectric insulation developed for the transmission of low-frequency signals. With an AWG 14 conductor cross-section and a stated capacitance of 125pF/m, it is designed to carry the subwoofer signal between a source or amplifier and the subwoofer's RCA input.
VIABLUE NF-B: Cable cross-section view
VIABLUE NF-B: Shielding cross-section view
Viablue NF-B: Shielding against interference
The conductor and its insulation are surrounded by a semi-conductive LDPE layer, followed by two counter-rotating spiral shields, one in tinned OFC copper and the other in pure OFC copper. This triple shielding structure is intended to limit the pickup of electromagnetic disturbances that may be superimposed on the signal. A Viablue ferrite filter housed in a metal shell completes the design by attenuating high-frequency electromagnetic interference.
Viablue NF-B: Connectors and finish
The NF-B is fitted with 24-carat gold-plated Viablue T8 RCA connectors, designed to ensure a firm contact with the device's sockets. A flexible Cobra braided sleeve protects the cable while making it easier to handle during installation. Its outer diameter, including the sleeve, is 9.5 mm; the ferrite filter has a diameter of 20mm.
Technical specifications
Product typeInterconnect cable
Connectors2x RCA
Length2.5m
Shielding
Conductor materialsOFC copper
Contact platingGold
Insulation
Cable diameter9.5mm
ColorCobra
Package1x Viablue NF-B
Length (m)2.5
ShieldingYes
Section (mm²)2.08
ConnectorRCA
VIABLUE NF-B T8 RCA to RCA Subwoofer Cable OFC Copper Triple Shielding and Ferrite Filter 2.5m Cobra
The Viablue NF-B is a coaxial RCA interconnect cable designed to carry the signal between an amplifier and a subwoofer. Its AWG 14 OFC copper...
