IBASSO D18 CROTALUS R2R ULTRA R2R DAC Portable Headphone Amplifier
New
The iBasso D18 is a portable R2R DAC with an integrated headphone amplifier, designed to convert digital sources and drive headphones or an external amplifier. Its 8-channel R2R Ultra architecture is paired with an 8.4V battery and amplification rated at up to 1,750mW per channel into 32Ω with an external 12V power supply.
Reference : 22788
469,00 €tax incl.
390,83 € tax excl.
iBasso D18 Crotalus R2R Ultra R2R DAC Portable Headphone Amplifier 32bit 768kHz DSD512
IBASSO D18 CROTALUS R2R ULTRA: Front view
The iBasso D18 is a portable R2R DAC with an integrated headphone amplifier, designed to convert digital sources and drive headphones or an external amplifier. Its 8-channel R2R Ultra architecture is paired with an 8.4V battery and amplification rated up to 1750mW per channel into 32Ω with an external 12V power supply.
Intended for Hi-Fi listening as well as gaming, it combines USB-C, coaxial and optical inputs with single-ended and balanced headphone outputs, as well as line outputs. Its OLED display, settings accessible from the device or the iBasso app, and its dedicated gaming equalizer make it easy to integrate into a variety of setups.
iBasso D18: R2R Ultra DAC
The iBasso D18 is a portable R2R DAC combined with a headphone amplifier, designed to bring together Hi-Fi listening and gaming in a single device. Its R2R Ultra architecture is based on an 8-channel differential network with 344 precision resistors, driven by an S.S. master FPGA with an evolving algorithm. For this architecture, iBasso specifies a dynamic range of 130dB, a THD+N of −97.5dB and a noise floor of 1.1µV; four proprietary digital filters also allow signal processing to be tailored to the listener.
IBASSO D18 CROTALUS R2R ULTRA: R2R DAC
IBASSO D18 CROTALUS R2R ULTRA: Battery and output power
iBasso D18: Power supply and amplification power
The D18 integrates a low-impedance 8.4V lithium-polymer battery, whose voltage can swing up to 16.8V, compared with 3.7V for a conventional battery. This power reserve aims to stabilize the output, support transients and reduce ripple caused by DC-DC conversion. For headphone listening, an external 12V power supply feeds the amplifier section; iBasso then specifies up to 1,750mW per channel into 32Ω, making it suitable for pairing with more demanding headphones.
iBasso D18: Extensive connectivity
The USB-C, coaxial and optical inputs allow the D18 to be connected to a computer, a phone or a digital transport. On the output side, the 3.5mm single-ended and 4.4mm balanced headphone jacks accommodate different types of headphones, while the corresponding line outputs allow the signal to be sent to an external amplifier. The 3.5mm headphone jack also supports a microphone, a useful feature for calls and in-game voice chat.
IBASSO D18 CROTALUS R2R ULTRA: EQ
iBasso D18: Settings and interface
The 1.3-inch OLED display shows operating information, while the multifunction switch provides access to settings directly on the device. For more detailed control, the iBasso Android app and the online control panel allow adjustment of equalization, filters and gain, as well as selection of different EQ profiles. A dedicated Gaming mode completes these settings to tailor playback to games, movies or music listening.
iBasso D18: Aluminum chassis and tempered glass
The CNC-machined aluminum chassis combines an anodized finish with a two-layer engraved stainless steel rear panel, while a tempered glass face reveals and protects the internal components. Beyond headphone listening, the digital inputs, line outputs and microphone jack allow it to be integrated with a computer or a Hi-Fi system. iBasso also states that a future update will add virtual 7.1 surround processing, intended to enhance in-game spatialization.
Technical specifications
Product typeDAC
Headphone amplifier
Inputs1x USB-C
1x 3.5mm Jack Coaxial / Optical
Outputs1x Balanced 4.4mm Jack headphone output
1x Single-ended 3.5mm Jack headphone output
1x Balanced 4.4mm Jack line output
1x Single-ended 3.5mm Jack line output
Supported sample ratesUSB-C: PCM up to 32bit 768kHz, Native DSD512
3.5mm Jack Coaxial: PCM up to 32bit 768kHz, DSD256 DoP
3.5mm Jack Optical: PCM up to 32bit 192kHz, DSD64 DoP
DAC chipsR2R
Output levelLow gain: 4.2Vrms
Medium gain: 6.2Vrms
High gain: 7.6Vrms
Output power2x 1530mW @ 32Ω, high gain, battery
2x 1750mW @ 32Ω, high gain, DC Jack
THD+N-95dB
Dynamic range128dB
SNR128dB
Crosstalk142dB
Frequency response10Hz-40kHz (-1dB)
Noise1.5µV
Output impedance0.7Ω
Output levelHigh gain: 4.2Vrms
Low gain: 3.5Vrms
THD+N-97.5dB
Dynamic range130dB
SNR129dB
Crosstalk129dB
Noise1.4µV
3.5mm headphone jack output
Output levelLow gain: 2.1Vrms
Medium gain: 3.1Vrms
High gain: 3.8Vrms
Output power2x 440mW @ 32Ω, high gain, battery
THD+N-93dB
Dynamic range123dB
SNR123dB
Crosstalk129dB
Noise1.2µV
Output impedance0.4Ω
3.5mm jack line output
Output levelHigh gain: 2.1Vrms
Low gain: 1.75Vrms
THD+N-92.5dB
Dynamic range120dB
SNR120dB
Crosstalk110dB
Noise1.1µV
Supply voltageUSB: 5V, 2A
DC jack: 12V, 1.5A
Dimensions140.4 x 75.3 x 18.8mm
Weight271g
ColorSilver
Package1x iBasso D18
1x Protective case
1x USB-A to USB-C cable
1x USB-C to USB-C cable
1x Lightning to USB-C cable
1x 3.5mm jack to 3.5mm jack cable
1x 4.4mm jack to 4.4mm jack cable
1x 12V power adapter
InputOptical Fiber
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
ClassN/A
IBASSO D18 CROTALUS R2R ULTRA R2R DAC Portable Headphone Amplifier 32bit 768kHz DSD512
The iBasso D18 is a portable R2R DAC with an integrated headphone amplifier, designed to convert digital sources and drive headphones or an...
