Jean-Claude F.
Très bon câble HP
Acheté en remplacement d'un câble Mogami 3103 pour bénéficier du bi-câblage. Ce sont les mêmes conducteurs donc j'ai...
Jean-Claude F.
Très bien
Contrepointes de bonne qualité pour un prix raisonable
Yvain C.
Mes fostex fe 208ez ce sont mises à bouger instantanément après l’installation du câble, des gravés en plus .
J’ai hâte de la...
IAN CANADA I2S to PCM Conversion Board V2.0 - reviews - There is 1 review.
Selman K.
be careful!
There wasn't any power cable in my set,but photo shows the power cable?
Also be careful about TP1 AND TP9 through holes,because silk white writing indicates dc and gnd are wrong! It is almost like a trap! Small mistake but audiophonics should write a note under this product about it!
Maybe he should add uf.l connectors into this set..
For me,uf.l pads should be on front side of the pcb(hear me Ian :)
Connectors are well aligned,I liked the pcb quality,I didn't test yet,but I powered the board without any problem.
Thanks!
This I2S to PCM conversion module from Ian Canada has been developed to improve the sound performance of audio systems using a MULTIBIT digital to...
