XDUOO MX-02 PRO Bluetooth 6.0 Transmitter
New
The xDuoo MX-02 PRO is a Bluetooth transmitter designed to wirelessly transmit audio from sources such as a TV, a CD player or a computer to a compatible headphone or speaker. Its optical and coaxial inputs support signals up to 24 bits / 192 kHz, while its Bluetooth 6.0 connectivity integrates several high-definition codecs, including LDAC and aptX Adaptive.
Reference : 22753
139,00 €tax incl.
115,83 € tax excl.
xDuoo MX-02 PRO Bluetooth 6.0 Transmitter
XDUOO MX-02 PRO: Front view
The xDuoo MX-02 PRO is a Bluetooth transmitter designed to wirelessly transmit audio from sources such as a TV, a CD player or a computer to a compatible headphone or speaker. Its optical and coaxial inputs support signals up to 24 bits 192kHz, while its Bluetooth 6.0 connectivity integrates several high-definition codecs, including LDAC and aptX Adaptive.
Intended for Hi-Fi setups as well as gaming and entertainment systems, it combines several audio inputs with a color display that makes it easy to monitor the source and transmission settings. This versatility makes it possible to add a wireless output to devices that lack one, while adapting the codec to the compatibility of the Bluetooth receiver.
xDuoo MX-02 PRO: High-resolution Bluetooth transmitter
The xDuoo MX-02 PRO is a Bluetooth transmitter designed to add wireless transmission to audio sources without Bluetooth, such as a TV, a CD player or a computer. Its coaxial and optical inputs accept signals up to 24 bits 192kHz, while the USB input supports audio up to 24 bits 96kHz. It then transmits the signal to a Bluetooth headphone or speaker, without requiring a wired connection between the source and the listening device.
XDUOO MX-02 PRO: Bluetooth 6.0
xDuoo MX-02 PRO: Bluetooth 6.0
Equipped with a Qualcomm chip and Bluetooth 6.0, the MX-02 PRO supports several codecs, including LDAC, aptX Lossless, aptX Adaptive, aptX HD, aptX, AAC and SBC. The format is selected from the menu, in order to adapt the transmission to the codecs supported by the receiver and to listening priorities. LE Audio support is also announced, with a stated latency of 20 ms for uses where synchronization with the picture is important.
xDuoo MX-02 PRO: Use and integration
Its TFT color display shows the active source, the connection status and the codec in use; language, brightness and auto power-off settings are accessible directly from the device. The USB port also allows it to be connected to a computer, a PS5 or a Switch to transmit their audio to a Bluetooth headphone. Its aluminum enclosure and external antennas complete a design intended for integration on a desk or in a home audiovisual system.
Technical specifications
Product typeBluetooth transmitter
Inputs1x Stereo RCA
1x Coaxial
1x Toslink optical
1x USB-C
OutputsBluetooth
Bluetooth version6.0
Supported Bluetooth codecsAAC, SBC, LDAC, aptX Adaptive, aptX Low Latency, aptX High Quality, aptX Lossless, aptX HD, aptX, LC3, aptX Lite
Transmission range50m
Supply voltage5V
Dimensions120 x 102 x 42mm
Weight360g
ColorGray
Package1x xDuoo MX-02 PRO
1x USB-C power cable (note: AC adapter not included)
OutputBluetooth
DAC / ADC ChipNC
ColorGray
Supported Bluetooth codecsLC3
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsaptX Lossless
Supported Bluetooth codecsaptX High Quality
XDUOO MX-02 PRO Bluetooth 6.0 Transmitter LDAC aptX Adaptive
The xDuoo MX-02 PRO is a Bluetooth transmitter designed to wirelessly transmit audio from sources such as a TV, a CD player or a computer to a...
