Bluetooth 5.4 Receiver / Transmitter
New
This Bluetooth 5.4 transmitter-receiver combines audio broadcasting to multiple devices with wireless reception from a compatible source. Support for BIS and CIS modes extends its LE Audio transmission capabilities, while its USB, AUX and microphone inputs allow it to be used in a variety of applications, from personal listening to sound reinforcement of a space.
Reference : 22754
19,90 €tax incl.
16,58 € tax excl.
Receiver / Transmitter Bluetooth 5.4
Receiver / Transmitter: Front view
This transmitter-receiver Bluetooth 5.4 combines audio broadcasting to multiple devices with wireless reception from a compatible source. Support for BIS and CIS modes extends its LE Audio transmission capabilities, while its USB, AUX and microphone inputs allow it to be used in a variety of applications, from personal listening to sound reinforcement of a space.
Bluetooth 5.4 Transmitter-Receiver
Its TX/RX architecture allows it to be used either as a transmitter, to send audio from a source to one or more compatible devices, or as a receiver, to receive a Bluetooth signal. It also supports two LE Audio transport modes: BIS (Broadcast Isochronous Stream), which broadcasts an audio stream to multiple receivers without individual connections, and CIS (Connected Isochronous Stream), which carries a stream between connected devices, generally point-to-point. These modes extend its audio broadcasting and linking capabilities, subject to the compatibility of the associated devices.
Receiver / Transmitter: Bluetooth 5.4 chip
Receiver / Transmitter 3.5mm Jack input and microphone
Broadcasting and audio inputs
The USB, AUX and microphone inputs allow sound to be broadcast from a computer, an OTG-compatible phone or another audio source. In USB sound card mode, the device accepts a digital signal up to 24 bits 96kHz and operates without driver installation, while priority source selection is designed to maintain broadcast continuity. This configuration can be used for sound in group classes, guided tours or spaces hosting multiple listeners.
Connectivity and use
Bluetooth 5.4 supports the BIS, CIS, LC3, SBC and AAC formats. A switch allows toggling between transmitter, receiver and Broadcast modes, to adapt the device to the source and the listening system. It can thus be integrated into a wireless setup either to transmit a signal to multiple receivers or to receive audio from a Bluetooth source.
Receiver / Transmitter: switch
Technical specifications
Product typeBluetooth Receiver / Transmitter
Inputs1x 3.5mm Jack
1x USB-C
Microphone
Bluetooth
Outputs1x 3.5mm Jack
Bluetooth
Supported Bluetooth protocolsAAC, SBC, LC3, CIS, BIS
Bluetooth version5.4
Battery550mAh
AutonomyBIS: 6h
CIS: 20h
RX: >20h
Charging time~2h
Supply voltage5V
Package1x Bluetooth Receiver / Transmitter
1x USB-C cable
1x 3.5mm Jack cable
1x Pair of earphones
InputJack 3.5mm
InputMicrophone
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipNC
Supported Bluetooth codecsLC3
Supported Bluetooth codecsCIS
Supported Bluetooth codecsAAC
Supported Bluetooth codecsBIS
Supported Bluetooth codecsSBC
This Bluetooth 5.4 transmitter-receiver combines audio broadcasting to multiple devices with wireless reception from a compatible source. Support...
