By buying this product you get 62 loyalty points
The SMSL DO400 MK2 is a DAC featuring balanced headphone amplification and a preamplifier mode, designed to centralize digital-to-analog conversion and volume control in a Hi-Fi or desktop setup. Its ESS ES9039MSPRO chip and XMOS XU-316 USB interface support PCM streams up to 32 bits 768kHz and DSD512.
Intended for headphone listening as well as integration with an amplifier or active speakers, it combines extensive digital connectivity, Bluetooth 5.4 and several signal processing settings. This versatility allows it to take a central place in the system, handling conversion, headphone amplification or output level management.
The SMSL DO400 MK2 is based on an ESS ES9039MSPRO chip, configured for 8-channel parallel processing to reduce distortion. The third-generation XMOS XU-316 USB interface supports PCM streams up to 32 bits 768kHz and DSD512, while the USB, coaxial, optical and AES/EBU inputs also allow DSD transmission up to DSD64. Hardware MQA processing is supported via USB, optical, coaxial and AES, with decoding up to 8x, as well as MQA-CD playback.
To stabilize data synchronization, the DO400 MK2 combines a 10MHz OCXO oscillator, rated at ±5ppb stability, with its CK-04 clock processing circuit. This circuit reclocks the inputs to limit jitter and phase noise, an approach intended to preserve playback regularity of high-resolution streams. DPLL digital processing, adjustable over 15 levels, allows jitter rejection to be tuned according to the source used.
Its fully balanced PLFC circuit drives headphones of various impedances, with a rated power of 2x6W into 16Ω, 2x3W into 32Ω, 2x700mW into 300Ω and 2x350mW into 600Ω. This headroom allows the unit to be paired with planar or dynamic headphones, including high-impedance models. The headphone outputs include a 6.35mm jack, a 4.4mm balanced output and a 4-pin XLR socket.
The DO400 MK2 offers 8 PCM filters and 4 DSD filters, as well as headphone gain adjustable over two levels. Nine sound coloration modes complete these options and allow the sound to be adapted to different headphones or listening preferences. Settings are made from the unit, whose display also allows selection of the I2S phase mode, brightness, function key and interface language: Chinese, English or Japanese.
The USB, optical, coaxial, AES/EBU, I2S and Bluetooth inputs allow various digital sources to be connected. Bluetooth 5.4 supports the LDAC, aptX HD, aptX, AAC and SBC codecs; LDAC accepts streams up to 24 bits 96kHz. The RCA and XLR outputs are used to connect an amplifier or active speakers, while the preamplifier mode allows their level to be adjusted directly from the DO400 MK2, without a separate preamplifier. The unit thus combines the functions of DAC, headphone amplifier and preamplifier in a single system.
Technical specifications
| Specifications | |
| Product type | DAC Headphone amplifier Preamplifier |
| Inputs | 1x USB-B 1x Coaxial 1x Optical Toslink 1x HDMI I2S 1x AES/EBU Bluetooth 5.4 |
| Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR 1x Single-ended 6.35mm Jack headphone output 1x Balanced 4.4mm Jack headphone output 1x Balanced 4-pin XLR headphone output |
| DAC chip | R2R |
| Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
| Output level | XLR: 5.2Vrms RCA: 2.5Vrms |
| Output power | 2x 6000mW @16Ω 2x 3000mW @32Ω 2x 700mW @300Ω 2x 350mW @600Ω |
| THD+N | XLR: 0.00005% RCA: 0.00007% HPA: 0.00009% |
| Dynamic range | XLR: 133dB RCA: 128dB HPA: 126dB |
| SNR | XLR: 133dB RCA: 128dB HPA: 126dB |
| Output impedance | Line output: 100Ω HPA: →0Ω |
| Gain | Balanced: +20dB Unbalanced: +14dB |
| Supported Bluetooth codecs | Windows 7 / 8 / 8.1 / 10 / 11 (Driver required) Mac OSX and later, Linux (Driverless) |
| USB compatibility | SBC, AAC, aptX, aptX HD, LDAC |
| General | |
| Supply voltage | 100-240V AC |
| Dimensions | 245 x 186 x 42mm |
| Weight | 1.45kg |
| Color | Silver |
| Package | 1x SMSL DO400 MK2 1x Remote control 1x Power cable 1x USB cable |
| Input | SPDIF |
| Input | Bluetooth |
| Input | AES/EBU |
| Input | USB |
| Input | Optical |
| Input | I2S via HDMI |
| Output | RCA |
| Output | Jack 6.35mm |
| Output | XLR |
| Output | Jack 4.4mm |
| Color | Black |
| Class | N/A |
| Remote Control | Yes |
