rodrigue Y.
Connecteur RCA
Très bonne qualité de fabrication, donne une impression de robustesse au touché. Par contre il faut utiliser un câble avec le...
Franck M.
très bel étui, très bonne qualité
très bel étui, très bonne qualité, conforme à la description et convient à merveille au Dac ONIX ALPHA XI1 DAC
Franck M.
excellentissime
petit dac très bien construit, tout en métal avec des boutons physique, design rétro magnifique et dac très performant, très...
MOGAMI 3104 OFC Copper Speaker Cable 4x4.0mm² Ø 14.5mm - reviews - There are 22 reviews.
stoica r.
Neotech 3200
Best cable for the money.
I have exchanged my 3200 with mogami. I lost a sens of 3d on the super lowe frequency. Overall I gained in naturala musical dimension . I have a audio gd master 11 Singularity with audio gd master 1 he vacuum and 2H monoblocs. Speaker go to 2 ohms
Benjamin B.
Best purchase ever and best value
I was sceptical enough to just buy 2 times 3 meter cabel without bananas because I did not want to make a bigger investment just to try the cable. That was a mistake. I imediately ordered banana plugs for the cable. I exchanged the cable for a chord company clearway which is almost exactly the same price but the performance of this Mogami is of a completeley another level.
My System is: Audio Note AN-J with a Hegel Röst as amplifier and I use the Dac of the röst with an Pro-Ject streamer.
At the beginning you notice that it is much cleaner sounding but the base was gone and the treble was to bright. After about 10 hours the base came back suddenly and the treble is also not so bright anymore and it is getting better and better now. Just listended 20 hours. Cable needs break in time! Who would belive that a cable needs break in time? Ridiculous. I would not have believed it if you told me but it does need break in time.
Together with a furutech FP-TCS31 my system is on a completely different level. If you would tell me the dac or the amplifer was exchanged for another component of double the price I would have believed it but is was just cable upgrade.
The changes were not subtle at all! Much better system now. Best value ever.
Niek S.
Amazing
I never was into special speaker cables, but I really should have tried this sooner. It really makes a difference, never expected that! I am using these with neutrik 4 wire speakon connector on hypex nc-400 monoblocks with Q-acoutics 3050i. Sounds amazing, much more depth and soundstage, better highs. Using Wiim pro plus with external dac SMSL m500.
Recommended!
Tomas H.
Buy with confidence!!
The best Speaker Cable I´ve built so far!
I´ve paired it up with Viborg VB402R connectors with very nice result!
I´ve f.ex. recently built one "RAMM AUDIO AMADEUS 5 MK2" that´s about three times as expensive/meter. Burned the RAMM in with NordOst-equipment, but still it is NOT as musical as my old MOGAMI.
the Mogami is far mor lively and presents music more "real" and with more energy.
It´s just a fantastic cable that I absolutely and with confidence can recommend for all you DIY´rs out there!!
Just remember to order big enough connectors, since this is a large snake.
Davor M.
Excellent
After the long break-in period I can only say that cables are
amazing. I have 5 time more expensive cables but this is pure music. Recommended.
rob m.
Incredible
My system is a BlueSound Node through a Audiolab 8300A and Kef LS50 Meta. The Mogami opened up the system, it's unbelievable what this cable can do, Highly recommended
Mickael c.
Très bon cable
Utilisé en 5 et 6m sur des bw 801 alimentée par des mcintosh 601.tres bon, équilibré, dynamique et scène très correct. Je recommande
stoica r.
Natural sound
After tray diferent cables from vdh neotech3200 and furutech i receve a pair from a frend to tray. My speakers go to 2ohms amp is purifi with sparkon. Sound is natrual base is down and texturate afte 500h of burn in.
Benjamin S.
Beaucoup de détail et spatialisation.
Cable de très bonne facture associé à des fiches Viborg monté sur des Tannoy Co axiales. J'ai été étonné par un grand gain en détail et en placement des différents instruments. Je découvre de nouvelles choses sur mes albums. Très fin à l'écoute, excellent pour les voix. Peut être un léger manque pour ceux qui veulent des grosses basses.
Buelent T.
Just AMAZING!!!
I tested the Audioquest William Tell Zero and wasnt really impressed from the Quality, after making some research i found the Mogami W3104 and i have to say i just blown away from the Sound Quality, send the William Tell back and saved alot of money :-)
Manuel Q.
Fast shipping
The product is as specified. Shipping to Spain very fast. Just one problem. Due to the thickness of the cable, I asked them to send it to me cut into two equal pieces and they have not done it, they have sent it in a single piece. They should not read the order notes.
Vaclav S.
OK
Super
Michael Ø.
Perfect
Great cable! Fine price! Rapid shipping! No problems! Dealer highly recommended!
14/03/20
Guy B.
Formidable rapport qualité-prix
J'ai acheté du Mogami 3104 pour passer en bi-cablage. J'utilise le modèle 2 conducteurs de longue date. Comparé à plusieurs autres câbles de grandes marques je lui trouve un rapport qualité-prix imbattable. Il fait beaucoup mieux que des câbles de prix équivalent ou plus chers. Seuls des câbles beaucoup plus chers apportent une discrète amélioration, mais la différence de plusieurs centaines d'euros vaut-elle le coup?
 (3)
Jean Francois G.
Dans ma configuration , tout simplement exceptionnel !
ce câble n est pas meilleur que les autres , mais après 20 ans de mariage de differents modèle de modulation et hp et a tout prix je viens enfin de trouver le Graal avec celui-ci . mais encore une fois c est une question d associations et de chance . curieusement je l ai testé avec le mogami 2549 en modulation , quelle déception !
Alors comme j'en ai plusieurs paires à la maison je les ai tous passer en revue et le meilleur a été et de loin une série professionnelle Monster câbles studio pro 2000 .
L'écoute est devenu somptueuse .
Je ne l'ai pas utilisé en bi cablage mais j'ai simplement doubler les fils pour passé en 2x8 mm , le défi a été de trouver des fiches bananes adapté à cette taille heureusement internet est là .
ce câble ne vous conviendra peu être pas , mais il a fait mon bonheur .
 (5)
Nicolas V.
Super cable
BOnjour
Très bon rendu.
bien mieux que mes anciens cables YBA.
J'ai enfin redécouvert mes enceintes....
jean christophe f.
essai en mono cablage
J'ai essayé ce câble en doublant le conducteur de 4mm,et là ,je doit avoue ,r le résultat est aussi au rendez vous, l'écoute est très intimiste et plus chaleureuse (sur de la musique de chambre) qu'en bi câblage c' est une expérience à tenté pour ceux que cela intéresse
 (3)
jean christophe f.
surprenant
L'ayant conseillé pour un ami et pour l'avoir testé sur son système les résultats ont été à la hauteur de toute attente. Fini les duretés sur le médium, une meilleure définition du message, plus de clarté ,une meilleure spatialisation de l'orchestre. Je l'ai donc commandé pour l'essayé et là même conclusion: douceur, qui ne veut pas dire mou ,mais au contraire naturel dans le sens des instruments, il y a chez ce câble le coté spectaculaire sans le coté démonstratif ,expressif sans être agressif ,détaillant le moindre détail sans fatigue auditive. Un seul bémol réside , lors du montage le code couleur est un peu délicat . système : ampli Jadis orchestra/enceinte Spendor S8e/Lecteurs microméga solo et Rega planet/ DAC audiolab.
 (4)
Dominique B.
difficile de faire mieux !
Câble d'excellente facture donnant beaucoup de naturel aux enregistrements. Bonne profondeur , détachement des instruments, sans aucune surbrillance ni mise en avant exagérée , tout est à sa place avec beaucoup d'aération. Bref, un grand câble...
Marc T.
Excellent en medium, le meilleur en grave.
Excellent cable testé en bi amplification, pas d'équivallent à ma connaissance quelque soit le prix.
Atomique dans le grave et bas medium , vraiment le meilleurs cable jamais testé dans ce registre. Dans le medium, bien qu'excellent je lui préfere le 3103 plus fruité et mélodieux.
Après nombreux essais l'idéal est d'avoir le grave avec du 3104 en doublant les conducteurs et le medium en 3103.
 (9)
 (3)
VINCENT C.
Pour faire simple : sur un ensemble Myryad (ampli + pré-ampli) + B&W CM7, un véritable bon qualitatif à très peu de frais !
Bien mieux sur beaucoup de points que tous les câbles "audiophiles" que j'ai testés (des QED, des MPC, des Audioquest, des ..., etc. : j'ai bien dû tester au moins 30 câbles, de 10 à 500 euros le mètre !). Au final, ras le bol : j'ai suivi les avis des forums (ce câble y est souvent plébiscité) ... et je ne le regrette pas.
Pour moi qui écoute beaucoup de classique et de jazz (CD et vinyle mais aussi radio), le meilleur apport est sur l'homogénéité, point souvent totalement oublié des constructeurs de câbles "audiophiles" (encore des guillemets !) : rien n'est mis en avant et c'est TRÈS agréable. Aucune fatigue à l'écoute, beaucoup de clarté, etc.
Autre point : les voix gagnent en cohérence dans le médium et mes enceintes colonnes atteignent enfin la qualité des bibliothèques sur ce point, ce qui n'avait jamais été le cas auparavant. Si, comme moi, vous aimez la radio (en particulier celles de radio france), c'est un point très, très important !
Bref, extrêmement satisfait ... surtout à ce prix !
(du coup, je vais tester les câbles de modulation)
 (7)
Eric B.
Trés bon cable pour le bicablage,trés bien sur des enceintes abordables : une son trés limpide,et une belle image sonore,ça respire enfin !!!
Bien mieux que le sommercable (mais c'est vrai que c'est pas le meme tarif)
 (5)
The Mogami 3104 cable has been designed to provide high audio performance. It integrates 4 OFC Copper conductors with a cross-section of...
