Patrick L.
Excellents
Je suis très...
Joseph P.
Alimentation 36v 6ampères
Milan G.
Milan G
Frederic L.
Évaluation comparative
Merci de votre évaluation de différents connecteurs, très intéressant. Le câble Ramm semble bien intéressant, pourquoi il n’apparaît pas dans la liste des câbles secteur mais seulement dans celle des câbles hp?
Peter K.
Alu enclosure
Exceeded my expectation. A very nice loooking case!
Rick B.
I returned this, but still award 5 stars!
I have a Naim UnitiNova - it is a great product but I find the sound errs on the side of resonant and bass-y. When I had a listen to the Nad M33, I discovered how good the purifi modules were.
When I saw this S400ET unit on offer by Audiophonics, I was very tempted as I could use my Naim as a pre-amp.
This little power amp is a lovely size, the casing is understated and very appealing and the quality of construction looks high.
After sourcing the appropriate leads to connect my Naim, I put the Audiophonics unit through its paces. It was thrilling! I am now totally converted to class D amplification - the sound was strong and energetic and was notably better than the amp stage of my Naim.
However, the overall sound was still resonant and bass-y, like before, not the crystalline sound I had heard from the Nad. The problem, I guess, is probably that the Naim pre-amp is putting its coloration and sound signature into the Audiophonics unit.
I did not have any other pre-amps to connect to compare, and I do not have the budget to "take a chance" and buy another preamp - which would in fact put the overall cost close to buying the Nad unit itself.
So, with a (very heavy) heart, I have had to return the unit. It is stunningly good both in terms of its output and value for money and the present (January) wait of up to 4 weeks for one attests to its deserved popularity. Well done Audiophonics!
PS - I hope I have not broken any rules by mentioning other manufacturers in this review - please edit appropriately if I have!
Patrick L.
Comparative evaluation of six AC connectors.
Le commentaire qui suit est l’exacte traduction de mon commentaire originel en Français.
The following commentary is the exact translation of my original commentary in French.
I carried out comparative tests for two years of the six AC connectors below, which allowed me to finely characterize their strengths and weaknesses.
All these connectors were mounted on the RAMM Amadeus 5 MK2 cable in length of 3 meters (Item no.: 12202); which establishes a common basis of comparison.
(Cable configuration: DOUBLERAMM, cable construction which I describe in detail in the Amadeus 5 MKII cable overview page)
The RAMM Amadeus 5 MK2 OCC Copper cable is completely transparent, a truly natural sound, it acts as a revealer of the personality of the SCHUKO-IEC connectors.
Thus, the dynamics, the definition, the sound scene will be defined by the connected connectors; this cable will always allow the qualities and defects of the connectors to pass.
Astonishing, no? These are the rarely seen abilities of the Amadeus 5.
Real advantage for a comparison. In absolute terms, the Amadeus 5 MK2 cable is a real buy-in whose audio performance is far from the price. For half a century of audiophilia (I'm 60 years old and yes I started young, the music academy educates your ear and not just your ear), you imagine that systems and cables sold at price of Gold, there are full crates, but sometimes, rarely, there is one that emerges and stands out from all the others.
The Amadeus 5 is one of those select few who work for music more than their profit margins ...
That this cable is not better known is a little mystery for me, a strangeness, a paradox ...
The general manufacturing quality of the six connectors presented below is excellent, which is the minimum given the prices charged… With a superlative addition for the FURUTECH E48 and their mirror-polished stainless steel cases connected to the earth, the top "cosmetico-technical"of the six connectors below.
On the other hand, the quality of the screws of the three electrical contacts seems to me unworthy of connectors of this price category; and this for the six connectors evaluated. M3 screws whose indentations break as soon as you tighten a little ... hard, or M4 stainless steel, always one screw per contact, that's sad (even scandalous) .... Suggestion to all manufacturers who sell connectors for several hundred $ each: for your contacts, you put two M5 copper screws (DIN 916, or grub screws) per contact, or even M6, and it will be just normal , thank you in advance….
01: YARBO RHODIUM (Ref. Article: 11020): Mounted on DOUBLERAMM cable 3 meters.
With YARBO / Rhodium connectors, we have a beauty of the timbre difficult to surpass, but a loss in dynamics. A very neutral, very fine and very defined extreme high; more than the OYAIDE M1e.
Formidable in the extreme high, very good in the rest of the spectrum, however, it has difficulties in the areas of dynamics, the separation of instruments ...
A soft and fine connector at the same time, certainly very good for classical music in small groups; not recommended for Rock N’roll….
An excellent choice in the price category 120 € incl. Tax per Schuko-IEC pair.
02: NEOTECH Gold (Ref. Article: 8939): Connectors mounted on DOUBLERAMM cable, length 3 meters.
Overall good connectors, nothing more. Listens better in the bass than in the treble.
Outstanding quality: very dynamic in the bass, its faults are less audible in these registers ...
Notable flaws: lack of definition, its rather rough in the medium, as confused. These connectors have a bit of the sound signature of a Pangea AC14 se MKII.
Poor spatialization, poor instrument separation.
Recommended use: sub-bass or bass; high limit: 300Hz.
The worst of the six audiophile connectors reviewed here ...
Price category: 150 € TTC per Schuko-IEC pair.
03: NEOTECH RHODIUM (Item no.: 10518): Connectors mounted on DOUBLERAMM cable length 3 meters.
Very good connectors, smooth listening from bass to treble.
Very good dynamics, good definition, good spatialization, a little behind the separation of the instruments. Stamps barely worse than those of YARBO Rhodium.
A listening profile that reminds me of Furutech Ag a little worse.
Recommended use: Full range, treble way.
An excellent choice in the price category 170 € incl. Tax per Schuko-IEC pair.
04: FURUTECH E48 Ag (SILVER) (Item no.: 13895): Connectors mounted on DOUBLERAMM cable length 3 meters.
Very, very good connectors, smooth listening from bass to treble.
Very good dynamics, very good definition, good spatialization, good separation of instruments, good timbres. Connectors a little better than the NEOTECH RHODIUM.
Recommended use: Full range, or any way.
An excellent choice in the price category 460 € incl. Tax per Schuko-IEC pair.
05: FURUTECH E48 Rh (RHODIUM) (Item no.: 13896): Connectors mounted on a "doubleramm" cable (section 8.5mm2), ie two RAMM5 cables, 3 meters long.
Exceptional connectors, homogeneous from bass to treble, a master buy in full range use.
Extremely good in definition, dynamics, separation of instruments, spatialization, this connector stands out especially in the treble; or it seems unsurpassed and is without a doubt the best connector of this test in this register.
The high register delivered by this connector is delicately and subtly full of emotions; it makes the music rich, natural and alive, quite simply ...
A "sound flavor" so pleasant to listen to, that happiness ...
A master purchase in the price category 480 € TTC per Schuko-IEC pair.
06: OYAIDE M1e Pt-Pd (Platine-Palladium) (Item no .: 10387): Connectors mounted on a 3-meter "DOUBLERAMM" cable.
With the OYAIDE M1e connectors, we have more dynamics, but the quality of the timbres is slightly lower (compared to YARBO/Rhodium).
OYAIDE connectors have exceptional transients ("fast" cable), and exceptional instrument separation, unique in its genre. The spatialization is extraordinary, each instrument is in its place and it stays there ... A real soundstage in three dimensions !!! However, they have a slightly "bright" high-pitched (beyond eight Kilo-hertz) and barely less definition than YARBO/Rhodium (beyond eight Kilo-hertz).
The low register has exceptional definition, dynamics and depth.
The medium, the vocals, are unmatched in dynamics, clarity, clarity and transparency. The soundstage is incredible and unparalleled, the separation of the instruments is very impressive, perfect, in fact.
The M1e is undoubtedly the best connector of those tested for sub-bass tracks; bass tracks; medium up to +/- 8 KHz. It is however less usable in full-range, because of its slight degradation in listening quality in the treble of 6-8 KHz to the high end of the sound spectrum.
In its register, it seems to me a reference hardly surpassing; the only regret is for its irrational price of 800 $ TTC the Schuko-IEC pair.
This connector is a demonstration of a manufacturer who "found" an excellent combination of plating metals and abuses that in the pricing of this product.
The message is here: if you want to access this quality, you will have to pay a maximum ...
The price of this connector is only justified by its listening performance; I can therefore only tell you (unfortunately and against my will): buy them, the result is spectacular ...
Recommended use: Sub-bass, bass & midrange amplifiers (6-8 KHz limit).
An absolute master buy in the price category of $ 800 including VAT per Schuko-IEC pair.
After numerous tests for over a year, here are my personal choices for the distribution of my AC connectors for my high-fidelity system:
For sources (DAC, crossover, preamplifier, streamer, Mac mini) as well as all-purpose "full range" (amplifier in mono-amplification): The FURUTECH E48 Rhodium. Alternative choice: the OYAIDE M1e-F1 with the treble limitations described in the evaluation, everyone to listen and build their own truth.
For amplifiers: sub-bass, bass, medium: OYAIDE M1e-F1 Platinum-Palladium.
Alternative choice to OYAIDE M1e-F1 (from the preferred choice to the less preferred choice): FURUTECH Rhodium or Silver, NEOTECH Rhodium, YARBO Rhodium (except for an treble where this is very good).
For the treble amplifier: FURUTECH Rhodium; alternative choice for the treble way: FURUTECH Silver, YARBO Rhodium.
Addendum: please note that after many tests in my own system, I found a surprising optimal combination: my DAC Audio-gd R7 (Full range, therefore…) powered by OYAIDE M1e and my treble amplifier by FURUTECH E48 Rhodium . Surprisingly and counter-intuitively, my treble has all the qualities of Furutech Rhodium, full and complete. While one might have feared that the Oyaide-powered DAC had imposed its own treble limitation; which is not the case, ... good surprise ...
The sound in my quad-amplification is therefore optimal at "all stages"; what happiness!
I also want to mention in this comment the effectiveness and relevance of the advice of our online seller Audiophonics. Always attentive to its customers, the sales team has an ability to advise you and offer you alternative solutions that I have not seen in any other. When the time comes to order and it is in stock, shipping is always immediate and the quality of the packaging is always "superlative"; kind the delivery man can swing your precious parcel by over the garden gate without causing any problem ...
On the other hand, if your purchase is not in stock, you will have to be patient ... May I suggest that management do everything possible to avoid stockouts, this will be a win-win plan. Thank you in advance ...
Can I invite you to read my review of the RAMM AUDIO Amadeus 5 MKII cable
(Item no .: 12202).
If you want to know more about the quad-amplification on which all the evaluations were carried out, go to the Ebay site and visit my announcements in the name of the pseudo luculluspatrick, and in particular: Crossover Filtre Actif Marchand XM44/4 "Audiophile edition".
Through these announcements, you can, if you wish, ask me any questions you deem useful ...
(GOOGLE translation…)
Patrick L.
(Item no .: 12202).
Patrick L.
(Item no .: 12202).
Patrick L.
(Item no .: 12202).
Patrick L.
(Item no .: 12202).
Patrick L.
(Item no .: 12202).
Patrick L.
(Item no .: 12202).
Adrien D.
SOMMERCABLE SC-PEACOCK MKII Modulation Cable OFC Copper AES/EBU Microphone 4 x 0.22mm² This Peacock MKII Sommercable cable can be used to design stereo microphone cables, or to create Cinch or Y patch cables. This Peacock MKII benefits from excellent insulation,...
Utilsé pour cabler un casque en symétrique, le cable est massif mais reste bien souple
Adrien D.
Très bonne finition
Facile à souder, une belle finition mat et compatible avec le Focal Elegia !
Tres bon cable a prix tres correct
Merci a votre équipe pour la livraison hyper rapide.
Ce câble est parfait pour mon système
Je le recommande vivement
Xavier T.
TOPPING NX3S Portable Headphone Amplifier on Battery Hi-Res OPA2140 + LME49720 The NX3s Topping is a portable, battery-powered headphone amplifier that is ideal for enjoying improved sound at home or on the go. The device offers a high quality design,...
Cet ampli nomade est d'une rare puissance dans sa gamme de prix. Topping n'a pourtant pas sacrifier la qualité. Il améliore le rendu sonore de tous mes casques et intras par rapport à la sortie 3,5mm de 80mW de mon lecteur audio. La scène sonore est approfondie et la musique devient plus vivante, enthousiasmante et réaliste. C'est une plus-value dont je ne peux plus me passer ! C'est le meilleur investissement que je pouvait faire. Un seul bémol, le connecteur 3,5mm, non blindé contre les ondes électromagnétiques, génère un léger souffle parasite lorsque je connecte mon lecteur au smartphone en Bluetooth. Le souffle disparaît en laissant un doigt sur le câble.
Christophe h.
Gain très appréciable sur la réalité de l’image sonore, la qualité des silences, la richesse des timbres et des textures... Grande pureté des voix, intelligibilité accrue... tout ça par rapport à la version Gold, la FI 38, Déjà , elle sur une embase FIE30 NCF Rhodium. Le gap franchi est il dû au rhodium seul, ou au contact entre embase et connecteur maintenant homogène tout rhodium? En tout cas, pour l’instant, l’apport sur mon câble ampli, avec une IEC FI 11 gold est déjà grand, et milite pour le changement futur de l.IEC... un réel investissement, c’est vrai, mais quel gap!
Christophe h.
Utilise avec les NFXcc, constitue un excellent câble AES pour ma liaison Drive CD et Dac. Surclasse bien des cables spdif a plus de 200 euros....
Pour enfiler la bague de blindage de la XLR, il faut detresser la tresse de masse, enlever la feuille de blindage puis lisser les brins de masse le long du câble pour pouvoir faire coulisser la bague en butée de la gaine du câble.
Christophe h.
Pas encore rodé, mais constitue une excellente liaison AES entre Drive CD et Dac, , avec les XLR NC3 XCC. Pour moins de 30 euros pour un câble de 1m, surclasse des liaisons SPDIF à plus de 150 euros.... Voire plus de. 200...
Antoine G.
LINDY Ethernet RJ45 Cable Cat 8.1 S/FTP LSZH Gold Plated 3m The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded...
trés bien
Cable rapidement expédié par Audiophonics.
Correspond totalement a mes attentes.
Très astucieux protège languette (très fragile sur les prises RJ45)
Antoine G.
Trés bien
Cables bien reçus, rapidement expédiés comme d'habitude sur audiophonics. Correspondent totalement a mes attentes
Patrick L.
Evaluation comparative de six connecteurs AC.
J’ai réalisé pendant deux années des essais comparatifs des six connecteurs AC ci-dessous, ce qui m’a permis de caractériser finement leurs forces et leurs faiblesses.
Tous ces connecteurs ont été montés sur du câble RAMM Amadeus 5 MK2 en longueur 3 mètres(Réf. article: 12202); ce qui établit une base de comparaison commune.
(Configuration du câble: DOUBLERAMM, construction de câble que je décris en détail dans la page de présentation du câble Amadeus 5 MKII)
Le câble RAMM Amadeus 5 MK2 Cuivre OCC est totalement transparent, un son vraiment naturel, il agit comme un révélateur de la personnalité des connecteurs SCHUKO-IEC.
Ainsi, la dynamique, la définition, la scène sonore seront définies par les connecteurs raccordés; ce câble laissera toujours passer les qualités et les défauts des connecteurs.
Etonnant, non? Telles sont les capacités rarement vues de l’Amadeus 5.
Véritable avantage pour un comparatif. Dans l’absolu, le câble Amadeus 5 MK2 est un véritable maître-achat dont les performances audio sont sans aucune commune mesure d’avec son prix. Pendant un demi-siècle d’audiophilie(j’ai 60 ans et oui j’ai commencé jeune, l’académie de musique, ça éduque votre oreille et pas seulement votre oreille), vous imaginez que des systèmes et des câbles vendus au prix de l’Or, il y en a des pleines cagettes, mais parfois, rarement, il y en a un qui émerge et se distingue de tous les autres.
L’Amadeus 5 fait partie de ces rares élus qui oeuvrent pour la musique plus que pour leurs marges bénéficiaires…
Que ce câble ne soit pas plus connu est un petit mystère pour moi, une étrangeté, un paradoxe…
La qualité générale de fabrication des six connecteurs présentés ci-dessous est excellente, ce qui est le minimum vu les tarifs pratiqués… Avec un plus superlatif pour les FURUTECH E48 et leurs boitiers en acier inoxydable polis miroir connectés à la terre, le top "cosmético-technique"des six connecteurs ci-après.
Par contre, la qualité de la visserie des trois contacts électrique me semble indigne de connecteurs de cette catégorie de prix; et ceci pour les six connecteurs évalués. des vis M3 dont les empreintes cassent dès que vous serrez un petit peu…fort, ou M4 en inox, toujours une vis par contact, c’est triste(voire scandaleux)…. Suggestion à tous les fabricants qui vendent des connecteurs à plusieurs centaines d’Euros la pièce: pour vos contacts, vous mettez deux vis M5 (DIN 916, soit des vis sans tête)en cuivre par contact, voire M6, et ce sera juste normal, merci d’avance….
01: YARBO RHODIUM(Réf. article: 11020): Montés sur câble DOUBLERAMM 3 mètres.
Avec les connecteurs YARBO/Rhodium, nous avons une beauté des timbres difficile à surpasser, mais une perte en dynamique. Un extrême-aigu très neutre, très fin et très définis; plus que le OYAIDE M1e.
Formidable dans l’extreme-aigu, très bon dans le reste du spectre, il accuse cependant des difficultés dans les domaines de la dynamique, de la séparation des instruments…
Un connecteur doux et fin à la fois, surement fort bon pour la musique classique en petites formations; déconseillé pour le Rock N’roll….
Un excellent choix dans la catégorie de prix 120€ TTC la paire Schuko-IEC.
02: NEOTECH OR(Réf. article: 8939): Connecteurs montés sur câble DOUBLERAMM longueur 3 mètres.
Connecteurs globalement bons, sans plus. Ecoute meilleure dans le grave que dans l’aigu.
Qualité marquante: très dynamique dans le grave, ses défauts sont moins audibles dans ces registres là…
Défauts marquants: manque de définition, son assez brouillon dans le médium, comme confus. Ces connecteurs ont un petit peu la signature sonore d’un Pangéa AC14 se MKII.
Spatialisation pas terrible, séparation des instruments mauvaise.
Utilisation recommandée: voies sub-grave ou grave; limite haute: 300Hz.
Le moins bon des six connecteurs audiophile évalués ici…
Catégorie de prix: 150€ TTC la paire Schuko-IEC.
03: NEOTECH RHODIUM(Réf. article: 10518):Connecteurs montés sur câble DOUBLERAMM longueur 3 mètres.
Connecteurs très bons, écoute homogène du grave à l’aigu.
Très bonne dynamique, bonne définition, bonne spatialisation, un peu en retrait sur la séparation des instruments. Timbres à peine moins bons que ceux du YARBO Rhodium.
Un profil d’écoute qui me fait penser au Furutech Ag en un peu moins bon.
Utilisation recommandée: Full range, voie aigue.
Un excellent choix dans la catégorie de prix 170€ TTC la paire Schuko-IEC.
04: FURUTECH E48 Ag (ARGENT)(Réf. article: 13895): Connecteurs montés sur câble DOUBLERAMM longueur 3 mètres.
Connecteurs très très bons, écoute homogène du grave à l’aigu.
Très bonne dynamique, très bonne définition, bonne spatialisation, bonne séparation des instruments, bons timbres. Connecteurs un petit peu meilleurs que les NEOTECH RHODIUM.
Utilisation recommandée: Full range, ou n’importe quelle voie.
Un excellent choix dans la catégorie de prix 460€ TTC la paire Schuko-IEC.
05: FURUTECH E48 Rh (RHODIUM)(Réf. article: 13896): Connecteurs montés sur câble "doubleramm"(section 8,5mm2),soit deux câbles RAMM5 longueur 3 mètres.
Connecteurs exceptionnels, homogènes du grave à l’aigu, un maître-achat en usage full range.
Extrêmement bons en définition, dynamique, séparation des instruments, spatialisation, ce connecteur se distingue spécialement dans l’aigu; ou il semble insurpassable et est sans aucun doute le meilleur des connecteurs de ce test dans ce registre là.
Le registre aigu délivré par ce connecteur est d’une finesse et d’une subtilité pleine d’émotions; il rend la musique riche, naturelle et vivante, tout simplement…
Une "saveur sonore" tellement agréable à écouter, que du bonheur…
Un maître achat dans la catégorie de prix 480€ TTC la paire Schuko-IEC.
06: OYAIDE M1e Pt-Pd (Platine-Palladium)(Réf. article: 10387): Connecteurs montés sur câble "DOUBLERAMM" 3 mètres.
Avec les connecteurs OYAIDE M1e, nous avons plus de dynamique, mais la qualité des timbres est légèrement en retrait(par rapport aux YARBO/Rhodium).
Les connecteurs OYAIDE ont des transitoires exceptionnelles (câble "rapide"), et une séparation des instruments exceptionnelle, unique dans le genre. La spatialisation est extraordinaire, chaque instrument est à sa place et il y reste… Une véritable scène sonore en trois dimensions!!! Cependant, ils ont un extrême-aigu(au delà de huit Kilo-hertz) un petit peu "brillant" et d’une définition à peine moins bonne que les YARBO/Rhodium(au delà de huit Kilo-hertz).
Le registre grave est d’une définition, d’une dynamique et d’une profondeur exceptionnelle.
Le médium, les voix, sont d’une dynamique, d’une limpidité, d’une clarté et d’une transparence sans équivalent. La scène sonore est incroyable et sans égal, la séparation des instruments est très impressionnante, parfaite, en fait.
Le M1e est sans aucun doute le meilleur connecteur de ceux testés pour les voies sub-grave; grave; médium jusque +/- 8 KHz. Il est cependant moins utilisable en full-range, à cause de sa légère dégradation de qualité d’écoute dans l’aigu de 6-8 KHz jusque l’extrémité haute du spectre sonore.
Dans son registre, il me semble une référence difficilement surpassable; le seul regret est pour son prix irrationnel de 800€ TTC la paire Schuko-IEC.
Ce connecteur est une démonstration d’un fabricant qui à "trouvé" une excellente association de métaux de plaquage et qui abuse de cela dans la tarification de ce produit.
Le message est ici: si vous voulez accéder à cette qualité, vous allez devoir payer un max…
Le prix de ce connecteur n’est justifié que par ses prestations aux écoutes; je ne peux donc que vous dire(malheureusement et à mon corps défendant): achetez-les, le résultat est spectaculaire…
Utilisation recommandée: Amplis voies sub-grave, grave & médium(limite 6-8 KHz).
Un maître achat absolu dans la catégorie de prix 800€ TTC la paire Schuko-IEC.
Après moult essais durant plus d’un an, Voici mes choix personnel de répartition de mes connecteurs AC pour ma chaîne haute-fidélité:
Pour les sources (DAC, filtre actif, préampli, streamer, Mac mini)ainsi que tout usage "full range"(amplificateur en mono-amplification):Le FURUTECH E48 Rhodium. Choix alternatif: le OYAIDE M1e-F1 avec les limitations dans l’aigu décrites dans l’évaluation, à chacun d’écouter et de se construire sa propre vérité.
Pour les amplis: voies sub-grave, grave, médium: OYAIDE M1e-F1 Platine-Palladium.
Choix alternatif au OYAIDE M1e-F1 (du choix préféré vers le choix le moins préféré): FURUTECH Rhodium ou Argent, NEOTECH Rhodium, YARBO Rhodium(sauf pour une voie aiguë ou celui-ci est fort bon).
Pour l’ampli d’aigus: FURUTECH Rhodium; choix alternatif pour la voie aiguë: FURUTECH Argent, YARBO Rhodium.
Addendum: veuillez noter que après de nombreux essais dans mon propre système, j’ai trouvé une combinaison optimale surprenante: mon DAC Audio-gd R7 (Full range, donc…) alimenté par OYAIDE M1e et mon ampli d’aigus par FURUTECH E48 Rhodium. Etonnement et contre-intuitivement, mon aigu a bien toutes les qualités du Furutech Rhodium, pleines et entières. Alors que l’on aurait pus craindre que le DAC alimenté par l’Oyaide eu imposé la limitation dans l’aigu propre à celui-ci; ce qui n’est pas le cas, …bonne surprise…
Le son dans ma quadri-amplification est donc optimal à "tous les étages"; que du bonheur !
Puis-je vous inviter à aller lire mon commentaire du câble RAMM AUDIO Amadeus 5 MKII
(Réf. article: 12202).
Patrick L.
Patrick L.
Patrick L.
Patrick L.
Patrick L.
Patrick L.
Tous ces connecteurs ont été montés sur du câble RAMM Amadeus 5 MK2 en longueur 3 mètres(Réf. article: 12202); ce qui établit un base de comparaison commune.
Pour les sources (DAC, filtre actif, préampli, streamer, Mac mini) ainsi que tout usage "full range"(amplificateur en mono-amplification):Le FURUTECH E48 Rhodium. Choix alternatif: le OYAIDE M1e-F1 avec les limitations dans l’aigu décrites dans l’évaluation, à chacun d’écouter et de se construire sa propre vérité.
Patrick L.
This cable respects your music …
I am making with the Amadeus 5 MKII cable two iterations of AC cables that I have named "Rsimple" and "DoubleRamm".
The Rsimple is an Amadeus 5 cable around which I thread a fiberglass-silicone sheath (not yet on sale at our usual online seller ...) which tightens the cable and very effectively dampens vibrations; around this sheath I put a black 18-25mm Cotton sheath (Item no .: 5590) which is also very effective at damping micro-vibrations. Also for an impeccable exterior presentation ...
Three wires for the Phase, three wires for the Neutral, the shield wire connected to the Earth contacts. This gives me a cable of 4.2mm # section per phase. Either a current capacity of 25 Amp ..
The DoubleRamm is more sophisticated: First of all, you should know that OCC wire is directional; this direction is indicated on the black rubber cable sheath by silver-colored screen-printed arrows. This orientation is necessary due to the asymmetric molecular structure when OCC copper is drawn during the manufacture of the conductor wire. (Source: the manufacturer RAMM AUDIO, with whom I am in correspondence)
So I take two Amadeus 5 cables that I twist together, one in the direction of the directional arrows; the second oriented in the opposite direction.
I connect the Schuko connector to the Phase with the direction of the arrows towards the IEC connector, the other cable, with the arrows pointing from the IEC to the Schuko will be used for Neutral; my two cables are therefore optimally oriented with respect to the molecular structure of the wires.
I put a fiberglass-silicone sleeve around this twist to perfectly tighten my twist and, on the outside, a black Cotton 18-25mm sheath (Item no .: 5590).
The wires of all shields (of both cables) are connected to the earth contacts.
With the Amadeus 5 MKII cable, you must not forget to strip the tiny PE sheaths that surround four out of seven copper strands in each of the six wires, otherwise you are missing out on the qualities of this cable ...
All this together gives me a cable of 8.5mm # section per phase, or a current capacity of about fifty Amps ...
I would also like to point out that this type of "DoubleRamm" assembly is also totally relevant for the realization of cables for loudspeakers; in this case, I advise you to connect the shielding wires of the cables to the earth via an "extension" in 1.5 # yellow-green wire to an earth point.
Advice: do not leave your "DoubleRamm" AC cables or speakers lying around on the floor, I use 25cm sections of Polyethylene tubing to raise them (primary use: plumbing insulation, on sale in all good brico's …) Diameter 9cm, positioned "upright" on the ground, at intervals of about fifty cm, supporting the cable. The benefit of this assembly will be a more airy sound, deeper silences.
In my DoubleRamm AC cables I have connected and tested six different AC connectors; the results are spectacular, this cable construction is a real benchmark… My favorite AC connectors with this cable are the OYAIDE M1e-F1 (Platinum-Palladium) (Item no .: 10387) & FURUTECH E48 Rhodium (Item no .: 13896) .
With such equipment, you just have the impression that you have bought new amplifiers !!!! Kind very very expensive, moreover !!!!! (Which puts the cost of your DoubleRamm cable into perspective….) Surprising, isn't it?
Your first impression when listening will be a very natural and a great fluidity of the musical message. This cable is particularly neutral and lets express the qualities and faults of the connectors you have chosen and fitted. With M1e or E48 Rh connectors the pleasure is immense.
With the OYAIDE M1e-F1 (Platinum-Palladium) connectors (Item no .: 10387), you get an ultra-defined and ultra-dynamic sound, the instrument attacks are sharp and incisive without ever being aggressive. But the most impressive of these connectors, are the separation of the instruments as well as the spatialization of these… Really, the result is spectacular, this connector is an absolute master-buy… You identify very clearly each instrument, perfectly separated from all the remains, it is in its place, and it remains there; the soundstage is truly three-dimensional, with a feeling of transparency and a quality of rarely heard "silences". The slightest vibrato of a voice, the clarity and naturalness of an acoustic piano, the definition, the depth and the "tension" in the bass, you have to have heard that to be believed… No one is perfect, the performances of this connector degrade very slightly in the extreme acute, beyond six-eight KHz, it loses a little in definition …
With the FURUTECH E48 Rhodium connectors (Item no .: 13896), we have a profile full of the qualities of Oyaide, with definition and finesse and much better subtlety in the high and the extreme highs; the E48 Rh is unmatched in the treble…. This connector is ideal for "full-range" use, because it is perfectly homogeneous from the lowest to the highest ... Without ever being aggressive ....
However, it should be noted that this E48 Rh is slightly behind in terms of quality compared to OYAIDE M1e in the field of dynamics and the separation of instruments; the E48 Rh is a little "softened", "disciplined" where the OYAIDE is "mastered and unrestrained ardor".
Some fans of "classical" music will find the E48 Rh very musical with a superlative beauty of the timbres, perhaps more to their taste than the Oyaide.
Anyway, at this level, everyone must do their own listening and make their choice (s) according to their equipment and their personal expectations ...
Given all of the above, there is no doubt that this amazingly performing cable has unrivaled value for money; that it is questioning compared to certain manufacturers of cables "assembled" which seem to have no limit in the pricing of their products, sometimes to the point of indecency ...
Thanks to RAMM AUDIO for achieving such a technical feat…. And commercial….
I also want to mention in this comment the effectiveness and relevance of the advice of our online seller Audiophonics. Always attentive to its customers, the sales team has an ability to advise you and offer you alternative solutions that I have not seen in any other. When the time comes to order and it is in stock, shipping is always immediate and the quality of the packaging is always "superlative"; like the delivery man can swing your precious package over the garden gate without any problem ...
May I invite you to go and read my comment called "Comparative evaluation of six AC connectors." in the presentation pages of these.
If you want to know more about the quad-amplification on which all the evaluations were carried out, go to the Ebay site and visit my announcements in the name of the pseudo luculluspatrick, and in particular: Crossover Active Filter Marchand XM44/4 "Audiophile edition".
Through these announcements, you can, if you wish, ask me any questions you deem useful …
(GOOGLE translation….)
Patrick L.
Ce câble respecte votre musique...
Je réalise avec le câble Amadeus 5 MKII deux itérations de câbles AC que j’ai dénommés "Rsimple" et "DoubleRamm".
Le Rsimple est un câble Amadeus 5 autour duquel j’enfile une gaine fibre de verre-silicone(pas encore en vente chez notre vendeur en ligne habituel…)qui resserre le câble et amortis très efficacement les vibrations; autour de cette gaine j’enfile une gaine Cotton noire 18-25mm (Réf. article: 5590) également très efficace pour amortir les micros-vibrations. Egalement pour une présentation extérieure impeccable…
Trois fils pour la Phase, trois fils pour le Neutre, le fil des blindages raccordé aux contacts de Terre. Cela me donne donc un câble de 4,2mm# de section par phase. Soit une capacité en courant de 25 Amp..
Le DoubleRamm est plus sophistiqué: Tout d’abord, il faut savoir que du fil OCC est directionnel; cette direction est renseignée sur la gaine en caoutchouc noir du câble par des flèches sérigraphiées couleur argent. Cette orientation est nécessaire en raison de la structure moléculaire asymétrique lorsque le cuivre OCC est étiré lors de la fabrication du fil conducteur. (Source: le fabricant RAMM AUDIO, avec qui je suis en contact épistolaire)
Je prends donc deux câbles Amadeus 5 que je torsades ensembles, un dans le sens des flèches directionnelles; le second orienté dans le sens opposé.
Je raccorde le connecteur Schuko à la Phase avec le sens des flèches vers le connecteur IEC, l’autre câble, avec les flèches orientées de l’IEC vers le Schuko servira pour le Neutre; mes deux câbles sont donc orientés optimalement par rapport à la structure moléculaire des fils.
J’enfile autour de cette torsade une gaine fibre de verre-silicone pour parfaitement serrer ma torsade et, en finition extérieure une gaine Cotton 18-25mm (Réf. article: 5590).
Les fils de tous les blindages(des deux câbles) sont raccordés aux contacts de terre.
Avec le câble Amadeus 5 MKII il ne faut surtout pas oublier de dénuder les minuscules gaines PE qui entourent quatre brins sur sept de cuivre dans chacun des six fils, sinon, vous passez à côté des qualités de ce câble…
Tout cet ensemble me donne un câble de 8,5mm# de section par phase, soit une capacité en courant d’environ une cinquantaine d’Ampères…
Je souhaite également préciser que ce type de montage "DoubleRamm" est également totalement pertinent pour la réalisation de câbles pour enceintes acoustiques; dans ce cas, je vous conseille de relier les fils de blindages des câbles à la terre via une "rallonge" en fil 1,5# jaune-vert jusqu’à un point de terre.
Conseil: ne laissez pas vos câbles "DoubleRamm" AC ou d’enceintes trainer à même le sol, J’utilise pour les surélever des sections de 25cm de tube en Polyéthylène(usage primaire: isolation de plomberie, en vente dans tous les bons brico’s…) diamètre 9cm, positionnées "debout" sur le sol, à intervalles d’une cinquantaine de cm, en support du câble. Le bénéfice de ce montage sera un son plus aéré, des silences plus profonds.
Dans mes câbles AC DoubleRamm j’ai raccordé et testé six connecteurs AC différents; les résultats sont spectaculaires, cette construction de câble est une véritable référence… Mes connecteurs AC préféré avec ce câble sont les OYAIDE M1e-F1(Platine-Palladium)(Réf. article: 10387) & FURUTECH E48 Rhodium(Réf. article: 13896).
Avec pareil équipement, vous avez tout simplement l’impression d’avoir acheté de nouveaux amplificateurs !!!! Genre très très cher, en plus !!!!! (Ce qui relativise le coût de votre câble DoubleRamm….) Etonnant, non??
Votre première impression aux écoutes sera un très grand naturel et une grande fluidité du message musical. Ce câble est particulièrement neutre et laisse s’exprimer les qualités et les défauts des connecteurs que vous avez choisis et montés. Avec les connecteurs M1e ou E48 Rh le plaisir est immense.
Avec les connecteurs OYAIDE M1e-F1(Platine-Palladium)(Réf. article: 10387), vous obtenez un son ultra-définis et ultra-dynamique, les attaques des instruments sont nettes et incisives sans être jamais agressives. Mais le plus impressionnant de ces connecteurs, sont la séparation des instruments ainsi que la spatialisation de ceux-ci… Vraiment, le résultat est spectaculaire, ce connecteur est un maître-achat absolu… Vous identifiez très clairement chaque instrument, parfaitement séparé de tout le reste, il est à sa place, et il y reste; la scène sonore est vraiment en trois dimensions, avec une sensation de transparence et une qualité des "silences" rarement entendus. Le moindre vibrato d’une voix, la clarté et le naturel d’un piano acoustique, la définition, la profondeur et la "tension" dans le grave, il faut avoir entendu ça pour le croire… Personne n’étant parfait, les performances de ce connecteur se dégradent très légèrement dans l’extrême aigu, au delà de six-huit KHz, il perd un peu en définition…
Avec les connecteurs FURUTECH E48 Rhodium(Réf. article: 13896), nous avons un profil plein des qualités du Oyaide, avec une définition et une finesse et une subtilité bien meilleure dans l’aigu et l’extrême aigu; le E48 Rh est sans égal dans l’aigu…. Ce connecteur est idéal en usage "full-range", car d’une homogénéité parfaite du plus grave jusqu’au plus aigu…Sans jamais être agressif….
Il faut cependant noter que ce E48 Rh est légèrement en retrait qualitatif par rapport au OYAIDE M1e dans le domaine de la dynamique et de la séparation des instruments; le E48 Rh est un petit peu "adoucis", "discipliné" là ou le OYAIDE est la"fougue maitrisée et sans retenue".
Certains amateurs de musiques "classique" trouveront le E48 Rh très musical avec une beauté des timbres superlative, peut-être plus à leur goût que le Oyaide.
Quoi qu’il en soit, à ce niveau là, chacun doit réaliser ses propres écoutes et faire son ou ses choix en fonction de son matériel et de ses attentes personnelles…
Etant donné tout ce qui précède, il ne fait pas de doute que ce câble aux performances étonnantes a un rapport qualité-prix sans concurrence; que ça en est interpellant par rapport à certains fabricants de câbles "assemblés" qui semblent ne pas avoir de limite dans la tarification de leurs produits, parfois jusqu’à l’indécence…
Merci à RAMM AUDIO de réussir un tel exploit technique….et commercial….
Puis-je vous inviter à aller lire mon commentaire dénommé "Evaluation comparative de six connecteurs AC." dans les pages de présentations de ceux-ci.
 (14)
Dimitris P.
Excellent upgrade
This was a very good upgrade indeed from my previous cable, which was a ofc tin plated good value but inexpensive cable. Face-lift is the list I could say. Right out of the box much detail revealed, deeper and more bass, it felt that my system almost needed no equalizing anymore. This is not to say that this cable is pre equalized but just maybe it brought forward my systems character. now my accuphase and Sopra1's no1truly sing. I was and still am impressed. Next revelation was my Amp new power cable which improved much the imaging. I terminated just one side (speaker) with spades, red copper from yarbo sc1005Y. Amp side left it bare cause that was best suited for my amps type of binding posts, Preparation was easy, cable its not so elastic due to solid core though, so better not force it much. You just need to straighten it by hand quite a bit before installing. Its not expensive cable compared to others, that's really good cable for not so power-hungry systems, it has a 2.1square mm thickness.
Vlaho K.
Excellent small amp
I use SMSL SA300 in desktop nearfield setup paired with two Anthony Gallo Nucleus Micro speakers and REL Tzero sub.
Crisp clear sound, nice stereo definition.
Although SMSL SA300 is packed in small chassis, it has enough power to push speakers and fill 20 m2 room with great sound without noticeable quality loss on high volumes.
Connection to SMSL SA300 is solely via Bluetooth from Mac. Works flawlessly, no drops, always reconnects automatically.
Overall, I’m very satisfied with it and would definitely recommend it.
Gérard D.
Très déçu qualité médiocre.
JF B.
Impressionnant!
Installés dans des ébénisteries DIY à pavillon arrière replié, le résultat est impressionnant.
Juan Alberto V.
Son de calidad
Son buenos, si bien tengo otros de otra marca igual de buenos y cuestan menos de la mitad. El precio se eleva, pero llega el producto muy rápido.
michal w.
un peu de raison
Salut a tous, je post ca en comparaison d'un autre classe D que je voulais remplacer (qui vaut 400 balles donc bon) qui est le poppulse t180, en fait ce qui me cassait les pieds c'etait la taille de mon gros ampli car je suis en config bureau/near field etc..., donc cet ampli pour le prix et l’encombrement est absolument génial, en revahcne et la ca pique, la dif de prix et de taille est "remarquable" je le met comme ca car je l'ai remarqué. les aigus plus cleans, plus riches, les mediums idem et les basses pareil. Le ratio prix qualité est valable ? non pas vraiment, le smsl est minuscule a coté, il fait le taff carrément pour le prix, mais il n'arrive pas a me faire vibrer comme le poppulse t180, en gros j'ecrit ca pour les gens qui pensent comme moi je pensait que la techno a assez avancer pour miniaturiser la taille et le prix depuis le temps, mais en fait non. Pour le prix encore une fois c'est un ampli incroyable, mais ce n'est pas un produit hifi, c'est au mieux un ampli qui va remplacer une carte son de merde sur un PC si vous avez un DAC devant ou si vous avez besoin du bluetooth, le son en BT est degeu et le DAC dedans bah je pense qu'il vaut 10 ou 15 balles a tout peter. Mais si vous cherchez un ampli allinone compact pas cher c'est dur de le battre.
Nicola G.
Connettore veramente ben costruito. Ottimo il servizio di Audiophonics
Johann a.
Bonnes bases!
Bonnes bases!
Après plusieurs jours de rodages, de tests et de combinaisons, on s'était dit avec mon pater que ce serait cool de lasser un petit avis... plus ou moins long
Alors, pourquoi le P1? Sûrement par mon saut dans le monde FX-Audio, avec le Tube 02 (ampli casque) et le Tube 03 (pré-amp). Saut qui n’a pas été sans conséquences. Des appareils assez Impressionnants, surtout le petit Tube 03. Les produits FX-Audio semble vouloir dépoussiérer le rapport qualité/prix. Surtout après un changement des tubes-stock. Oui les tubes fournis ne sont pas mauvais-mauvais, mais un changement par des équivalents (comme le GE 5654 présent sur le site) ou des NOS Russes/Américains/British/Allemands ne feront qu’apporter de vrais plus. Il est d'ailleurs difficile de faire marche arrière après ces modifications, paroles d'audiophiles.
Le P1 semble suivre la même logique que le Tube 02 et 03, prix attractif et bonne base avec un choix de tube équivalent assez large sur le marché. C’est un appareil intéressant, avec de bons composants électroniques (des photos qui circulent sur le net où l’on remarque des éléments de choix) comme des condos Wima et Nichicon. On peut se demander comment ils font pour rentrer tout ça dans le prix…
Bref, au même prix c’est sûr qu’en Classe D ça se bouscule déjà pas mal côté choix. Sauf qu' en ampli à loupiote, ‘faut enquêter. D’ailleurs merci Audiophonics pour votre prix, apparement le plus bas du net!
J’ai mis quatre étoiles pour deux raisons (à destination du fabriquant):
- l’alim a lâché au premier démarrage. Comment reconnaître la panne: son brouillon avec craquements et manque de puissance. On a pensé que les tubes étaient en fin de vie. Un branchement sur alimentation de labo (indiquant une crête de consommation de 2,75A) a permis de repérer la panne. Merci à la rapidité du SAV Audiophonics pour l’alim de rechange
- la prise de l’alim n’est pas assez serré et pas très profond…
Côté écoute, il a fallu du temps et plusieurs combinaisons sur des sources Vintage (Philips CD880 ou Marantz CD80) et câblés OFC plaqué-argent chez Audiophonics. Idem côté câblage Haut-Parleurs (branché en bi-cablâge); des Supravox 215 RTF en baffle-plan et tweeter Dayton AMT (visibles sur le site). Le pré-amp Tube 03 s’insère parfois entre la source et l’ampli:
- les tubes-stock 6P1 sonnent mieux après 20h de rôdage. Attente d’adapteur pour passer en 6AQ5 / EL90 et en EL85 que mon père a en stock
- Les 6J1 ont un médium assez prononcé, et ont été remplacés par des 6AK5 et/ou EF95
Attention à la chaleur très élevée des tubes, même quelques dizaines de secondes après leurs fonctionnements. Manipulations réservés aux connaisseurs!
Conclusion, le tube P1 intègre de bonnes bases pour découvrir à prix doux l’univers de ce genre d’amplificateur. Pour 2,5W par canal, c’est amplement suffisant. On retrouve l’aération et le volume sonore typique aux amplis à tubes.
Peut-etre un jour un P1 Mark II ? :-)
xavier C.
Réception dans les 3 jours qui ont suivi la commande. Produit très simple à mettre en œuvre, et répondant parfaitement à ce que j'attendais. En rapport qualité/prix/fonction le produit est vraiment très bien placé. L'application sur le portable est basique, mais plus agréable que sur certaines marques plus prestigieuses !! ( ex Marantz !!)
Juste un point de détail à connaitre, le wifi du IEAST ne fonctionne qu'en 2.5 Ghz, donc pour démarrer il faut un téléphone qui soit connecté au réseau via cette fréquence et non sur 5Ghz... une fois la connexion faite, on peut rebasculer le téléphone sur les 5Ghz...
Fais le job
Ideal pour le son d'un téléviseur .
Jakub P.
Very, very good DAC
Well, one year passed since I bought this DAC, and everything works perfect. There weren`t any problems with it. Sound quality is amazing, especially if the DAC is powered properly (by linear power supply). Take in consideration playing DSD files, then Audiophonics spreads its wings.
Jakub P.
CS8416 Source Selector Module 2 SPDIF Inputs to 1 I2S Output This module is an input module with a coaxial input and an optical input. It is based on a Cirrus Logic CS8416 digital audio receiver supporting sample rates up to 192kHz. The...
Not for Raspberry Pi
The quality of the product is good, that`s why I give it 5 stars, but unfortunatelly it doesn`t work with Raspberry Pi/Audiophonics ES9038Q2M. If you want to have an optical or coaxial S/PDIF input in your DIY streamer, then just buy an optical/coaxial spdif socket and connect it to spdif + ground pins (+5V for optical socket) on Audiophonics DAC. You must also take into account the necessity of adding two capacitors to avoid "reloading" effect (lags in audio via optical spdif input).
Défaut de finition
Fibre dépassant de son logement, extrémité en champignon: le chinois a oublié de polir les extrémités !!!
ça m'a d'ailleurs abîmé une prise Toslink femelle qui ne retient plus son complément mâle.
Toutefois, câble repris sans Pb.
Stéphane C.
Coup de boost
30 ans...30 ans que mes enceintes DITTON étaient équipées de câbles de qualité...basique dirons nous. Et là..quel renouveau... ! Des basses plus présentes, plus rondes, des médiums plus clairs...et un gain dynamique indéniable...même sur des formats compressés...un bonheur.
Romain L.
ARYLIC UP2STREAM AMP MONO Amplifier Board WiFi Bluetooth 5.0 60W 4 Ohm The Arylic Up2Stream AMP Mono is a small, powerful and versatile amplifier module offering advanced wireless connectivity. The amplifier stage of the module is capable of...
Ma vieille TSF s’est transformée en enceinte connectée ; tout marche nickel !!
steve B.
Tres bien pour le prix , mais ....
Je l'ai acheter pour une seule chose , mes 3 blocs amplis de puissance Nuprime STA-9 n’ayant pas de prise trigger 12v , il me fallait une multiprise de bonne qualité non filtré avec une fiche IEC pour pouvoir lui mettre le petit bloc trigger 12v de chez Audiophonics et ainsi pouvoir commander l'allumage et l'extinction de cette multiprise .
PS: le petit module Trigger 12v de chez Audiphonics n'est bien sur pas livré avec cette multiprise , il coute environ 30e sur le site d'Audiophonics.fr
L'objet et de qualité correcte malgré quelque trucs qui m'ont un peu laissé pantois .
Déjà posé sur une surface plane , elle est bancale , 1 des 4 pieds en caoutchouc est plus court sur pattes ... surement une changement de lot a la prod' .
2eme: , et ca c'est plutôt gonflé ... le câble d'alimentation du cette multiprise est en 3G0.75MM² !!! 3x0.75mm² , mais c'est une blague alors que l’intérieur est câblé en 2.5mm² ... A REMPLACER d'office svp .
Bon moi j'avais prévu le coup car il me fallait rapidement un 3G1.5mm² de 5m , j'ai donc commandé un Oehlbach 3g1.5 de 5m avec , et 2 ferrites en 9mm pour ce câble . 30e en tout . Bon j'ai pas besoin de gros gros cable j'ai que 1200w a y faire passer
3eme: j'ai ouvert l'engin , car j'avais lu plusieurs fois que certaine vis étaient mal serrer , et j'ai bien fait ! un des câble bleu sur le gros bornier de la platine était insérer que sur 2 ou 3mm ... d'ailleurs on le vois sur les photos .
De l'autre coté sur la platine , c'est un câble de terre qui dépasse ...
J'ai tout re-cablé proprement et serrer les vis correctement .
Bon en règle générale , c’était pas trop mal .
C'est un câblage en ligne , ce qui n'est pas trop hi-fi dans l’âme ... il aurait été mieux d'avoir un câblage en étoile , mais gardons a l'esprit que cette multiprises coute 122e.
Le filtrage est minimaliste , mais ça devrait suffire a enlever les grosses EMI-RFI du réseau crée par le congélo , micro-ondes et ballon chauffe eau ou lampe Halogène/Led par exemple .
J'ai également vérifié le fonctionnement du détecteur de phase , ça marche bien et c'est juste .
Bon je ne suis pas déçu par cette engin , mais j’enlève 1 étoile quand même pour ces 2 câbles partiellement enfilés dans leurs bornes et pour ce câble d'alimentation en 3G0.75 !
Merci de m'avoir lu , et merci pour votre petit vote "utile" ou non ;)
a+ , pour les photos interne , allez vois mon avis sur amazon.fr
 (16)
Remi P.
ravi
Acheté en remplacement du M8 première version (ES9018) qui m'a lâché après 5 ans de loyaux services, ce petit dac avec son alim externe SMSL P1 redonne un vrai peps et de l'aération à mon installation hifi fixe. Vraiment ravi de cet achat.
Pierre-Jean G.
Produit conforme et expédition très rapide. A conseiller
Jean-Pierre L.
PARFAIT
Excellent produit, fabrication très soignée, très facile d'utilisation, améliore sensiblement l'écoute et surtout les contacts. colis très bien protégé et parvenu dans les délais; produit correspondant tout à fait à mes attentes.
Ronan L.
Satisfait mais pas conquis
Fabrication qualitative.
Ce câble m'a permis de relier directement la cellule au prephono, il m'a fallu souder 4 petites cosses (travail d'orfèvre).
La platine (LE TALLEC) attend sa nouvelle courroie, donc je ne peux donner un avis precis, mais c'est plus délié et plus de bruit parasite... c'est déjà pas mal...
Bruno C.
Excellent câble hp
Utilisé en bi-câblage avec ampli numérique Nuforce dda100 et enceintes Mission M33, ce câble me donne entière satisfaction. La restitution sonore est riche en détails et aérée. Une impression de limpidité s'en dégage. L'on se surprend à se mettre à apprécier des albums pour lesquels l'intérêt était jusqu'ici limité.
pierre a.
tres pratique
embouts de cable tres pratiques
sertis avec la pince cela fait une terminaison de cable tres propre
je recommande
