Gilles G.
Pratique
Bastien P.
Epoustouflant !
C'était la première fois que j'achetais des enceintes sans les écouter auparavant, juste en me fiant aux mesures ......
Sherman M.
Great DAC!
I absolutely love this DAC because you can switch between the two chips while you are listening to music to hear the difference.
Customers reviews - There are 20793 reviews.
Jean-marc B.
Ne pas hésiter
en remplacement de l’embase d’origine sur un NAD C638, l’apport est sans conteste, tout est mieux et surtout les graves sont plus définis.
jm
Pier Luigi C.
High Value for Money
Are you seeking for a low cost an alternative to Sonos Amp? Here it is! I used only with the app via wifi (non bluetooth or other) and it works great able also toi pilot in decent way A pair of B&W AM-1 on my terrace. A50 is hidden in a big box (3 times the tiny amp) and is working fine. I reccomend it
Andrius M.
Huge leap in listening experience
What can i say compared to my old dac, it got left in the dust. On a rating scale last dac 5/10 this one 9/10. To hear new crisp details in the recording ive listened to a hundred times is really something. Almost cant believe this inexpensive sabre dac is so good.
On the packaging. Its in a neat little box, inside it the dac comes packaged in all around bubble wrap so theres zero chance of any damage from tossing during shipment. The connections look really nice. Driver setup is easy. DSD works, Highly recommend. I hear the engineer behind this board have made a few more products. But as is this is probably 90% as good and cant go wrong.
Elsa A.
Clés Allen indispensables pour certaines fiches
Bon matériel , pratiques avec le support à petits modèle, quasi impossibles à trouver ailleurs.
à compléter avec les dimensions anglaises!
Elsa A.
Fiches bananes correctes
Pas chères , font le job
Elsa A.
FI E48 NCF
Très belle construction qui va de pair avec un excellent rendu sonore propre à la technologie NCF
Elsa A.
Monacor SPX 30M
Excellent HP qui a remplacé 2 HP (tweeter et médium) d'une mini enceinte
à voir sur la durée.
Rémi B.
Très bien mais pas très bon marché
Rémi B.
Rémi B.
DAYTON AUDIO CE32A-4 Mini Speaker Driver Full Range 2W 4 Ohm 81dB 240Hz - 20kHz Ø3.2cm This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for small DIY designs
Cool
Bon produit mais vraiment petit
Herve J.
tres bon ampli
dynamique fantastique ,aeré et precis
hautement recommandé
Hervé T.
Le point chaud tourne même à froid et c'est normal s'il n'est pas arrêté en rotation. En dehors de sa température maxi d'utilisation ( 400°C env ), le PTFE est aussi utilisé pour son pouvoir autolubrifiant ( Teflon ). Finalement, grâce à ça, on peut orienter le point chaud comme on veut pour la soudure et le fabriquant n'a pas à se faire ch...! à le positionner avec précision avant le surmoulage au PTFE et cela doit se retrouver sur le prix de vente. Du coup, il n,y a pas vraiment de raison de s'en plaindre.....Pour le reste, même avis que pour le blanc !
Hervé T.
Achetée pour remplacer les embases d'origine qui s'étaient déformées lors d'un changement de fils audio. Belle finition, montage depuis l'intérieur ( on peut donc faire les soudures avant le montage, ce qui est bien pratique ) et soudure facile et tout cela pour un tarif raisonnable. Que du bonheur ! Pas besoin de plus
Hervé T.
Même avis que pour le noir. A moins d'être féru d'ésotérisme, cette prise remplit à peu prés toutes les conditions : Belle qualité, robuste, dorée pour l'oxydation (quand on a comme moi une transpiration acide, c'est indispensable), soudure facile, cables de fortes sections et tarif contenu. Que demander de plus ?
Hervé T.
Très bonne prise
Bonne finition, repérage facile car tout le corps est à la couleur, soudure aisée, l'isolant n'a pas bougé à la soudure du point chaud, permet des fils de forte section (mogami 2524) et on peut même enlever l'embout souple pour les plus gros cables. Tout cela pour un tarif très raisonnable. Soyons pragmatiques, on n'a pas besoin de plus.
Guy G.
Un excellent produit mais pour mon utilisation il est un peut petit il faudrait un diamètre supérieur d'un millimètre...
Guy G.
produit parfait
Ce produit est bien mails il ne me convient pas je ne peux pas l'utiliser pour mes enceintes que je possède.
Gérard F.
Très bonne surprise !
Pour alimenter mon Dac Sanskrit je l'ai attendu 3 mois , covid oblige, je ne m'attendais pas à une telle amélioration sur mon système à base Euphia-Mulidine !
Grave plus propre, espace sonore plus large et plus profond ,la musique est là et grandeur nature ! bravo!
Patrice P.
rapport qualité prix incroyable
léger, puissant, qualitatif, à ce prix c'est imbattable
michel l.
jumper viablue sc-4
bonjour
j'ai acheté il y a peu de temps, les jumper viablue sc 4.
cela ma changé le son de mes enceintes triangle.
les aîgus ,les médiums , et les graves sont vraiment bien séparés,et sont beaucoup plus beaux , mes enceintes s'expriment à cent pour cent .
pour les enceintes bi câblages ,alimenter les enceintes sur le bornier du bas ,puis mettre , les jumpers viablue ,en respectant les pôles ,plus et moins ,et le sens des flèches .
bonne écoute.
Frederic J.
Un produit simple mais qui fait très bien l'affaire. Possibilité de fixation avec adhésif double face et vissage.
Richard D.
Bonne surprise!
Première commande, et première bonne surprise, de ce petit DAC TOPPING DX7S arrivé très rapidement et ce malgré les problèmes de confinement! Encore en rodage, le résultat sonore va donc progresser mais déjà, je découvre un beau potentiel musical, je l'utilise sur l'entrée AES via une interface USB, le tout piloté par mon PC.
Merci à l'équipe d'AUDIOPHONICS pour leurs compétences et réactivité exemplaire surtout par ces temps qui courent!!!
Musicalement Richard.
Stéphane R.
Bon article
L'article n'est pas mauvais, la qualité prix me semble justifié. Les bagues isolantes font leurs boulot. Le filetage semble bien tenir contrairement à un autre article reçu dans la même commande.
Jean T.
Très bon produit. Je recommande fortement.
Jean T.
Marcus K.
Digital Interface Module SRC AK4137 I2S USB Optical 32bit 384kHz DSD256 avec Écran This extremely versatile digital interface module is equipped with an AK4137EQ AKM Sampling Rate Converter (SRC) chip at the heart of its architecture. This chip supports high...
Very good device and worth the money. Changing the Clocks a nobrainer!
A good Power supply is essential in this league!
Philippe H.
Plus efficace qu'il n'y paraît
Pas d'effet "wow", pas la révolution timbrale dans le système, mais un ensemble de qualités fondamentales qu'on oublie un peu au profit du "sensationnel".
En comparaison directe avec mon Wireworld Platinum 7, c'est globalement (un peu) moins ascendant, mais surtout plus plein, plus incarné, avec du poids sur les notes et les transitoires. Les textures dans le bas-médium offrent davantage de matière, sans empâter l'ensemble. Plus différencié aussi, notamment dans l'aigu.
Et au final, toutes ces nuances ont un côté naturel … donc très important ! (PS : prix ultra-raisonnable, bien sûr !)
Elle a tout d'une grande
Amphenol fabrique du materiel militaire et ça transparaît dans cette fiche. La fabrication semble sérieuse et efficace, sobre et bien pensée. Les soudures y sont très faciles à réaliser. Elles acceptent des câbles d'assez fort diamètre (Viablue NF A7) sans problème. Elles permettent un enfichage très bien maintenu. Un bon produit au rapport qualité prix intéressant.
Connecteur aviation GX16
Tres bien pour usage tension élevée (les pins sont assees écartés pour éviter tout arc accidentel, 400v max)
Utilisé pour câble HT (un peu plus de 300v) d'ampi à tubes tubes (boîtier d'alim déporté)
Connecteur aviation GX12
Petits connecteurs sympa, idéal pour se faire un câble maison. Dans mon cas alimentation filaments des tubes d'un petit ampli
Attention a ne pas depasser l'intensité max (les pins sont assez fins et rapprochés)
Pour des tensions élevées je recommande les GX16
Gaine Tressée
Difficile d'y passer 2 fils souples torsades de 0,75 mm2, mais avec une aiguille tire câble d'Électricien ça passe tout seul !
Sinon, bon produit de qualité
Laurent G.
Fait le job, mais qualité globale de fabrication...
Suite de mon message tronqué accidentellement...
Je n'ai pas renvoyé le produit en raison du COVID19. J'ai remplacé l'insert défectueux par un diamètre adéquat. C'est stable et efficace.
Pour mes reproches sur la qualité globale de fabrication. Il est vrai qu'à ce prix, on ne me peut pas demander la lune et puis une fois installé, on ne voit pas les défaut.
Les plans et cotes du produit sont dispos sur le net et permettraient à certains avec compétances de soudeur de fabriquer une version DIY un peu moins cheap.
Laurent G.
Fait le job, mais....
Efficace, bien conçu pour mes colonnes (80kg piece), mais que penser de la qualité globale de construction du produit.
Soudures : chinoises...
Finitions peintures : chinoises...
Construction ; chinoise..
Pour info, les inserts de pointes (M8) enchassés dans les tubes ont posé problème. L'un des huit inserts était au diamètre M10 et incompatible avec une des points. Je n'
Grégory Q.
Coude RCA compact et de bonne qualité, vendue par paire.
Pedro P.
Bof
Avis mitigé sur ce DAC, je l’ai trouvé inférieur au FX-Audio FX01, alors qu’il coûte bien plus cher. Sur mon système haut de gamme (PLLXO sur Youtube) il manque sérieusement d’ouverture dans les médiums (nasillard) et les aigus sont plutôt durs, mes Magnepan ne font pas de cadeaux à ce niveau-là. Ceci comparé à un DAC Yggdrasil (ou un Dacgear), réputé pour son rendu naturel, quasi analogique. Le FX01, malgré un grave trop en avant, présentait des timbres plus réalistes. Sur mon second système, enceintes DIY (double Markaudio Alpair M10.3 en // enceinte MLTL), préampli FX-Audio Tube01 (tubes Russes) alimenté par batterie, amplis monoblocks 3e-audio TPA3255, le grave est spectaculaire, sec, profond et varié, la contrebasse est un régal. Là où cela se gâte c’est à nouveau dans les médiums et les aigus. Les Alpairs ont une tendance montante bien connue, en disposant bien les haut-parleurs, c’est presque « flat ». Avec mon Yggdrasil les médiums sont nettement plus riches, ouverts, spontanés et les aigus absolument pas agressifs. Ce n’est pas le cas avec ce DAC Audiophonics, même si sur mon second système cela se remarque moins. Pour les graves 10/10, les médiums 6/10 et les aigus 6/10. Attention aux voix féminines stridentes ! Sur un système avec un grave légèrement en retrait et avec des tweeters à dôme en tissu, il doit tirer son épingle du jeu.
BRUNO B.
tres bien construit !
surpris au déballage du colis, le pré, emballé avec une feutrine translucide et pas dans un carton spécifique , mais bon, c’était très bien fait ,
bien construit, cela respire la qualité , fiches rca premium , le rendu est tout simplement musical !
dommage, pour la led rouge en façade, en vert ou pas du tout aurai été mieux pour moi ! sinon au regard du prix, on a là ,un pré-ampli de grande qualité ! merci a vous
Impec mais...
Très pratique, ce doit être une nouvelle version car il n'y a plus qu'un seul fil rouge qui sur le PCB et soudé à la fois sur l'alim et l sonde, donc ça f'ait qu'un seul fil à brancher.
En revanche, celui que j'ai reçu a un affichage rouge.
Personnellement je préfère, mais... comment être sûr que lors de la prochaine commande j'en aurai un rouge aussi ???
Embase RCA
Super produit, isolant téflon, j'en achète régulièrement...
installation aisé, perçage du boîtier en 9,5 comme spécifié, bonne isolation...
Remplace avantageusement des modèles "vissage par l'extérieur" pas terribles (je ne me souviens pas du modèle) qui n'accepterait pas une épaisseur panneau de 3mm.
Florian M.
Le Mode EQ
Le mode EQ m'a vraiment laissé septique. Il n'y a aucune explication sur le mode d'emploi imprimé sur l'emballage. J'ai appuyé plusieurs fois sur le bouton. Je n'ai pas noté de changement particulier dans le son. Je me demande si ce mode est vraiment opérant. Bref à oublier. D'autant qu'avec une utilisation sur un ordinateur, on peut modifier le son directement dans son lecteur audio (Vox par exemple).
Florian M.
Top!
J'ai acheté ce petit ampli pour une utilisation desktop avec un ordinateur. La qualité du son est superbe et la puissance bien suffisante (pour ce type de configuration).
Deux choses à noter:
_ L'ampli, l'ordinateur et tous le reste sont branchés sur une multi prise. Dès que j'allume la multi prise, l'ampli s'allume automatiquement. Je dois donc penser à l'éteindre à chaque fois si je ne veux pas l'utiliser.
_ Étant sur Mac, les touches du clavier pour augmenter ou baisser le son fonctionnent parfaitement avec cet ampli! C'est très pratique, surtout que les toutes petites touches de l'ampli ne sont pas très pratique.
En conclusion: très beau design en alu, toute petite taille, très bon son très détaillé (sans être trop analytique). Je recommande!
Adhesive Cable Tie 20x20mm White This adhesive cable tie simply attaches to a wall to allow you to group your cables together. The base of the cable tie is adhesive and can therefore be easily attached to any...
Attache Câble Adhésif 20x20mm Blanc
Un peu plus cher qu'en magasin de bricolage, remplit bien son rôle.
Il serait appréciable de pouvoir les acheter en lot (par exemple 30 unités)
Câble cuivre OFC plaqué Argent
Second achat, retour d'expérience très positif
Produit recommandé
Produit recommandé
Station de Soudure
Utilisant auparavant un fer à souder JBC 25w qui m'a lâché, je me suis fait plaisir et acheté cette petite station au vues des commentaires sur ce produit.
Çà change la vie, montée en température rapide, consigne de chauffe et régulation précise.
Pannes de rechange a 1 euro...
Utilisation aisée, bons résultats.
Vital pour le DIY en ces temps de confinement ;)
Boye L.
Very nice enclosure
Very well made product with excellently fitting parts and a very nice finish.
bernard T.
DAC FX 01
Excellent petit appareil pour relier mon Mac Book sur un ampli HEED Elixir relié à des ProAc tablette Anniversary. le banc d'essai de QOBUZ mérite largement les louanges qui ont été émises. Le son est d'une limpidité incroyable, les timbres sont bien restitués ainsi que la dynamique. j'en ai recommandé un second pour un autre système plus modeste. le rapport qualité prix est invraisemblable.
Didier Q.
VIABLUE UFO XL Vibration Absorbers Black Ø65mm (Set x4) Viablue UFO XL absorbers can dampen harmful vibrations by placing themselves under your speakers or HiFi devices. Due to their optimal pressure on the lower surfaces of the...
Avis absorbeurs Viablue UFO XL
Ces absorbeurs placés sous des enceintes (4 par colonne) ne vont pas transcender la sonorité de votre système mais leur apport est néanmoins perceptible et cela sur toute la largeur du spectre : plus de clarté, plus de précision, meilleur séparation des instruments. Comme souvent avec ce genre d'accessoire le gain est variable d'un enregistrement à l'autre.
Un investissement intéressant pour un prix qui reste accessible au regard d'autres modèles peut-être plus performants mais à des tarifs prohibitifs.
Emmanuèle C.
IKKO OH1 Hybrid In-Ear Monitors IEM 18 Ohm With its OH1s, Ikko offers high-end in-ear monitors at a low price. Indeed, it is a model with a hybrid design with two loudspeakers, usually reserved for products at much...
tellement décevants...
Essayons de trouver quelque chose de positif : la boîte est jolie, et les écouteurs également. Mais je dois avoir des petites oreilles... si bien qu'ils tiennent moyennement, mais surtout, ne coupent ABSOLUMENT pas du bruit ambiant... Moins bien que des écouteurs à 30 euros...
A quoi sert d'avoir un son parfait, s'il est pollué par absolument tout ce qu'il se passe autour ?
Peut-être que des meilleurs embouts seraient la solution, quand on voit que d'autres intras en fournissent de plein de formes et matières différents, ceux ne donnent le choix que de 3, juste 3 tailles différentes, et pour moi, aucune ne coupent du bruit ambiant, d'un appartement loft où tout le monde vaque à ses occupations. (Donc je ne parle pas de bruits de rue, de transport, etc...)
Bref... que faire de ces écouteurs, si le seul endroit où les utiliser est dans un silence totale sans bruits autour ? ... mais dans ce cas, quel intérêt d'avoir des écouteurs ?
Je suis EXTREMEMENT déçue, et suis retrounée à des écouteurs à 30 euros plus performants pour s'isoler et écouter de la musique.
La fonction de bons intras n'est pas de vous isoler du bruit (il existe de très mauvais caques Bluetooth pour ça).
Bien que ce soit possible au moyen d'embouts spécifiques (bi-flange, tri -flange); mais bien de vous apporter un son de la meilleure qualité possible.
Oui certains constructeurs offrent un choix plus large en terme d'embouts mais pas dans cette gamme de prix.
Nous pensons aussi sincèrement que vous ne les enfoncez pas assez dans le conduit auditif, il me parait techniquement impossible qu'ils isolent moins que des écouteurs bouton à 30 € (y compris avec les embouts d'origine).
Guillaume A.
Le câble parfait ?
Câble acheté en remplacement d’un produit low-cost mais en bi-câblage quand même. Montage également en bi-câblage et relativement facile avec tous les composants du même fabricant (splitters, gaine et fiches banane à souder). Attention toutefois à la longueur de la gaine, un coefficient de 1,5 minimum est requis compte tenu du diamètre conséquent de ce câble. Une période d’une trentaine d’heures est nécessaire pour que ce câble révèle tout son potentiel. Utilisé entre un ampli Denon PMA2500NE et des enceintes Klipsch Heresy 3, il se révèle exceptionnel : aigus clairs, cristallins sans jamais être agressifs, médiums bien charpentés, présents et très justes, basses très tendues et nuancées. Un câble très équilibré et sans coloration. La scène sonore c’est élargie et la profondeur est apparue tout en conservant cette dynamique que j’apprécie. Bref, que du très bon pour un prix très raisonnable. Association avec du Klipsch plus que recommandable à mon humble avis
Gianluca C.
Vu les circonstances actuelles , et pourtant confié comme nous tous à la maison ... La poste ne trouve pas mon colis ... donc pour le moment je n'ai aucuns avis sur le colis expédié
